SFMH-145-02-L-D
SFMH-145-02-L-D
    SAMTEC(申泰)
    .050'' X .050 SOCKET STRIP ASSEM
SFMH-145-02-L-D 数据手册
FSH–120–04–F–RA–SL F-224 SUPPLEMENT (Rev 10JAN24) FSH–110–04–L–DH–SL SFMH–130–02–L–D–LC SFMH–105–02–L–D–LC (1.27 mm) .050" FSH–120–04–F–DH SFMH–120–02–L–D FSH, SFMH SERIES HIGH-RELIABLE HORIZONTAL FSH Mates with: SFMH SFMH Mates with: FTSH, FSH 1 FSH SPECIFICATIONS NO. PINS PER ROW 04 05, 10, 15, 20, 25, 30, 35, 40, 45 Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: FSH = Sn or Au over 50 µ" (1.27 µm) Ni SFMH = Au over 50 µ" (1.27 µm) Ni Current Rating (FSH/SFMH): 2.6 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth: SFMH = (3.35 mm) .132" to (4.57 mm) .180" RoHS Compliant: Yes (3.68) .145 Lead-Free Solderable: Yes (FSH) SMT Lead Coplanarity: (0.10 mm) .004" max (SFMH) (0.15 mm) .006" max (FSH)* *(.004" stencil solution may be available; contact ipg@samtec.com) (1.27) .050 (5.21) .205 –FR –RA = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (Not available with -RA) (3.94) .155 (3.43) .135 PROCESSING = Tape & Reel (Not available with –RA) (2.29) .090 (3.68) .145 2 4 (1.27) .050 13 (1.27) .050 (1.27) (1.27) .050 .050 No. of positions + 2 x (1.27) .050 –DH (0.89) .035 (0.71) .028 (1.27) .050 (2.16) .085 –RA = (4.50 mm) .177" DIA Polyimide film Pick & Place Pad (10 positions minimum) not available with –RA option –TR (2.51) .099 (0.41) .016 SQ –C = Right-angle (Through-hole) (No. of positions + 4) x (1.27) .050 (6.58) .259 = Solder Locks –RA –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (–RA Option) (Standard sizes) –SL = Double Row Horizontal (Surface Mount) = Gold flash on post, Matte Tin on tail (–DH Option) OPTIONS –DH –F 05, 10, 15, 20, 25 For complete specifications see www.samtec.com?FSH or www.samtec.com?SFMH ROW OPTION PLATING OPTION –DH RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality SFMH 1 NO. PINS PER ROW PLATING OPTION 02 D –L FILE NO. E111594 –LC = 10 µ" (0.25 µm) Gold on contact, Gold flash on tail 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 = Locking Clip (Manual placement required) (0.64) .025 TYP (2.03) .080 APPLICATIONS SFMH FSH HORIZONTAL (0.41) .016 –WT No. of Positions x (1.27) .050 + (2.92) .115 04 Note: Some sizes, styles and options are non-standard, non-returnable. –WT (1.65) .065 (4.57) .180 (1.27) .050 02 03 01 (1.50) .059 = Weld Tab (Not available with 35, 40, 45, 50 positions) –TR = Tape & Reel –FR (1.65) (3.43) .065 .135 No. of Positions x (1.27) .050 + (1.65) .065 OPTION (1.41) .056 DIA (1.02) .040 = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) –LC WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
SFMH-145-02-L-D 价格&库存
很抱歉,暂时无法提供与“SFMH-145-02-L-D”相匹配的价格&库存,您可以联系我们找货
