SSW-116-02-G-D-RA
SSW-116-02-G-D-RA
    SAMTEC(申泰)
    CONN RCPT .100" 32PS DL R/A GOLD
SSW-116-02-G-D-RA 数据手册
F-218 (Rev 10OCT17) SSW–125–01–G–S SSQ–116–03–L–T (2.54 mm) .100" THROUGH-HOLE .025" SQ POST SOCKET SPECIFICATIONS For complete specifications see www.samtec.com?SSW or www.samtec.com?SSQ Insulator Material: Black Liquid Crystal Polymer (-S & -D) or Black High Temperature Thermoplastic (-T) Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (SSW/TSM): 4.7 A per pin (2 pins powered) Current Rating (SSQ/TSW): 6.3 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" Normal Force: Standard= 125 grams (4.4 N) Max Cycles: 100 with 10 µ" (0.25 µm) Au Voltage Rating: 465 VAC / 655 VDC RoHS Compliant: Yes Mates With: TSW, MTSW, MTLW, EW, ZW, TSS, ZSS, TSM, TSSH, HTSS 1 SSW = Solder Tail –1 = (2.54 mm) .100" Centers SSQ = Square Tail (2.54) .100 2 49 50 (2.41) .095 (2.54) .100 x No. of Positions + (0.51) .020 100 98 4 2 (2.54) (4.95) .100 .195 –D 99 97 150 147 3 (2.54) .100 6 1 3 (2.54) .100 (5.08) .200 –T RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality PIN CENTERS –S PROCESSING Lead–Free Solderable: Yes: -S and -D row option Wave only: -P, -T and -Q row option TYPE STRIP 148 145 150 147 1 4 6 (7.49) .295 3 (5.08) .200 –Q (7.49) .295 01 thru 50 FILE NO. E111594 148 145 4 1 (8.51) .335 Note: Some lengths, styles and options are non-standard, non-returnable. (2.54) .100 x No. of Spaces –RA Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. NO. PINS PER ROW SSW–125–02–G–D–RA SSW–130–01–G–S SSW–113–02–T–T–RA LEAD STYLE SSW–118–22–F–T ROW OPTION PLATING OPTION –F TAIL OPTION –LL = Locking Lead = Right-angle (Leave blank for straight pin version) = Single Row –P –L OTHER OPTION –RA –S = Gold flash on contact, Matte Tin on tail SSW, SSQ SERIES Two leads per strip crimped in opposite directions on or near centerline. Available on tails from (2.29 mm) .090" to (7.87 mm) .310" only. N/A with single row 1 or 2 positions. = Single Row (36 pins max) = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail –D –G –“XXX” = Double Row = 20 µ" (0.51 µm) Gold on contact, Gold flash on tail = Polarized (Specify “XXX” as position number) –T –T = Triple Row = Matte Tin (-T N/A on LIF contacts) ALSO AVAILABLE –Q (MOQ Required) • Other platings • Notch option Contact Samtec. = Double Row .200" (5.08 mm) row space (Outer rows filled only) Straight Pin Versions (Specify “LEAD STYLE” from chart) Standard Insertion Force Low Insertion Force* –01 –02 –03 –04 –21 –22 –23 –24 Not Available –06** –S & –P SINGLE DOUBLE OR TRIPLE LEAD STYLE –T –D –Q A (2.64) .104 (4.93) .194 (10.00) .394 A (14.83) .584 (2.54) .100 (3.15) .124 SSW (0.41) x (0.79) .016 .031 * LIF not available with Tin Plating **Style –06 Not available with SSQ (5.08) .200 (2.54) .100 SSQ (0.64) SQ .025 (5.08) .200 Right-Angle Versions (Specify “LEAD STYLE” from chart) Standard Low Insertion Insertion Force Force* –T –D –S & –P LEAD STYLE –Q SINGLE DOUBLE TRIPLE (–S ) (–D) A A A (2.54) .100 (2.54) .100 (7.62) .300 Not Available –02 –22 (2.54) .100 –03 –23 (7.62) .300 –04 –24 (12.45) .490 (–T & –Q) Not Not Available Available (1.52) .060 A SSW SSQ (0.41) x (0.79) (0.64) .016 .031 .025 SQ A A (2.54) .100 *LIF not available with Tin Plating (2.54) .100 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. A (5.08) .200
SSW-116-02-G-D-RA 价格&库存
很抱歉,暂时无法提供与“SSW-116-02-G-D-RA”相匹配的价格&库存,您可以联系我们找货
SSW-116-02-G-D-RA
  • 1+62.279891+7.99122
