TCSD-07-D-05.00-01-R 数据手册
F-219
TIGER
EYE
IDC
TCSD
(2.00 mm) .0787"
TMM
.26" (6.6 mm)
TCSD–08–D–02.00–01–N–R
TCSD SERIES
TIGER EYE IDC SOCKET CABLE
Mates with:
TMM, TMMH, STMM,
MMT, TW, MTMM, EHT,
ETMM (-SR), ZSTMM
TYPE
STRIP
END
OPTION
NO. PINS
PER ROW
01
LENGTH
PLATING
OPTION
OTHER
OPTION
N
SPECIFICATIONS
For complete specifications
see www.samtec.com?TCSD
–04, –05,
–06, –07,
–08, –10, –12,
–13, –15, –17,
–20, –22, –25
Insulator Material:
Black Glass Filled Polyester
Contact:
BeCu
Plating:
Au or Sn over 50 µ" (1.27 µm) Ni
Wire:
28 AWG 7/36 Stranded,
Tinned, Copper with
Gray PVC Insulator
Current Rating (TCSD/STMM):
2.8 A per pin
(2 pins powered)
Operating Temp Range:
-40 °C to +105 °C
Lead Size Accepted:
(0.48 mm) .019" to
(0.53 mm) .021"
Insertion Depth:
(2.87 mm) .113" to
(3.17 mm) .125"
RoHS Compliant:
Yes
–N
–“XX.XX”
= Notch Polarization
= Assembled Length
Assembled Length
in INCHES (±1/8")
2 inches minimum
–F = Gold flash on contact
Leave blank for standard plating:
30 µ" (0.76 µm) Gold on contact area
(Standard sizes)
–S
–D
= Single End
= Double End
–P “XX”
= Position Polarization
No. of positions x
(2.00) .0787 + (7.874) .3100
01
RECOGNITIONS
02
TCSD
For complete scope of
recognitions see
www.samtec.com/quality
Specify “XX” as position
number. Same position
will be polarized on
both ends.
= Socket Strip
(1.02)
.040
(3.17)
.125
FILE NO. E111594
Not available with –O, –M,
–R, –DXX or –BXX
–D “XX”
1
–B “XX”
01
(MOQ Required)
Specify PK-01-07 for
polarizing key (Available
in wheels of six each).
Also polarizes SMM
Series socket strips.
Double
Row
Connectors
Outer
Most
(End of
assembly)
4
(5.08)
.200
“XX”
(2.00)
.0787
EJECTOR HEADERS &
LOCKING CLIPS
–R
= Reversed
5"max.
2"min.
Breakout starts with Number 1
lead indicated by brown wire or
red stripe. Shown on top side.
5
2
–RW
–M
= Middle Reverse
= Reverse Wiring
See TMM Series.
Requires –DXX
• Ejector headers
• Locking clips
• Strain relief option
Note:
TCSD Series assemblies are
non-standard, non-returnable.
1/8"
4" minimum
(2.00)
.0787
POLARIZING KEY
“XX”
Specify “XX” as number of
conductors to be broken out.
No. of positions x (2.00) .0787 + (4.00) .157
(1.00) .039
• Other sizes
• Other platings
= Daisy Chain
2"
min.
= Breakout
(4.00)
.158
ALSO AVAILABLE
–SR
= Strain Relief
See EHT Series.
= Outside Reverse
02
Blue or black wire
opposite position #1.
3
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
5
–O
01
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
Requires –DXX
5
TCSD-07-D-05.00-01-R 价格&库存
很抱歉,暂时无法提供与“TCSD-07-D-05.00-01-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+91.940601+11.86876
