TMM-113-01-T-D-RA
TMM-113-01-T-D-RA
    SAMTEC(申泰)
    2MM TERMINAL STRIP
TMM-113-01-T-D-RA 数据手册
F-215 TMM–110–01–S–D–SM TMM–112–01–F–S–SM TMM–130–05–L–S–SM (2,00 mm) .0787" TMM SERIES LOW PROFILE SMT HEADER SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?TMM Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1,27 µm) Ni Current Rating: 3.2 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold Voltage Rating: 500 VAC mated with SQW 450 VAC mated with SQT RoHS Compliant: Yes Mates with: CLT, SQT, SQW, ESQT, TLE, SMM, MMS, TCSD (2,00 mm) .0787" pitch OTHER SOLUTIONS ThroughHole Available with optional • Pick & Place Pads • Alignment pins • Tape & reel packaging 2 mm Shunt Specify 2SN–BK–G for 2 mm shunt with Gold plating. Processing: (2,77 mm) .109" Low Profile (4,45) .175 (1,95) .077 (2,00 mm) .0787" pitch (3,99) .157 Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,15 mm) .006" max RECOGNITIONS TMM 1 LEAD STYLE NO. PINS PER ROW PLATING OPTION For complete scope of recognitions see www.samtec.com/quality Specify LEAD STYLE from chart below. 02 thru 40 FILE NO: 090871_0_000 ALSO AVAILABLE LEAD STYLE (MOQ Required) • Other platings Contact Samtec. (1,97) .078 No. of positions x (2,00) .0787 40 01 02 80 A –F = Gold flash on post, Matte Tin on tail –L = 10µ" (0,25 µm) Gold on post, Matte Tin on tail MATES WITH –01 SQT, SQW, (3,20) ESQT, TLE, .126 SMM, MMS, TCSD –04 (1,91) .075 –05 (1,65) .065 –06 (4,27) .168 ROW OPTION –S –A = Single Row = Alignment Pin (Metal or plastic at Samtec’s discretion) (5 positions minimum) (–D only) –D = Double Row –“XXX” = Polarized Position (Specify position of omitted pin) –S = 30µ" (0,76 µm) Gold on post, Matte Tin on tail –M = Metal Pick & Place Pad (4 positions minimum) (-T plating not available) (–D only) –T CLT = Matte Tin CLT-BE –P = Pick & Place Pad (3 positions minimum) (3,94) .155 01 –TR 79 (1,27) .050 TYP (0,50) .020 SQ (1,50) .059 Note: Some lengths, styles and options are non-standard, non-returnable. (2,00) .0787 OTHER OPTION SM A (1,27) .050 = Tape & Reel Packaging (3 thru 36 positions only) (1,27) .050 TYP (6,60) .260 (4,83) .190 –D –S (5,00) .197 x (8,00) .315 (5,08) .200 x (10,16) .400 –P WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (5,72) .225 x (3,56) .140 –M
TMM-113-01-T-D-RA 价格&库存
很抱歉,暂时无法提供与“TMM-113-01-T-D-RA”相匹配的价格&库存,您可以联系我们找货
TMM-113-01-T-D-RA
  • 1+16.128001+2.05410
  • 50+13.8307050+1.76150
  • 100+11.77820100+1.50010
  • 500+10.07560500+1.28330
  • 1000+8.011501000+1.02040
  • 2000+6.565502000+0.83620
  • 5000+5.049505000+0.64310
  • 10000+3.4635010000+0.44110
库存:120
TMM-113-01-T-D-RA
    • 90+10.38617
    • 1000+7.54479
    • 2000+6.74678
    • 5000+4.88477
    • 26700+2.92603
    • 72100+2.75675
    库存:1
