TSM-110-04-T-SH-A-P
TSM-110-04-T-SH-A-P
    SAMTEC(申泰)
    .025 SQ. TERMINAL STRIPS
TSM-110-04-T-SH-A-P 数据手册
F-218 (Rev 10OCT17) TSM–116–02–S–DV–LC 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT TSM–121–01–T–SV HIGH MATING CYCLES (2.54 mm) .100" SMT .025" SQ POST HEADER Board Mates: SSW, SSQ, SSM, BSW, ESW, ESQ, BCS, SLW, CES, HLE TSM NO. PINS PER ROW 1 Cable Mates: IDSS, IDSD, SMSD, SMSS 02 thru 36 SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?TSM –F = Gold flash on post, Matte Tin on tail (5.84 mm) Post Height –01 = .230" (Mates with SSW, BCS, SSM, IDSS, IDSD) Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 475 VAC -SV/-DV mated with BCS or SSM RoHS Compliant: Yes Post Height –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail .320" (8.13 mm) Post Height –02 = (Mates with SSM -DH) –03 –S = 30 µ" (0.76 µm) Gold on post, Matte Tin on tail = .420" (10.67 mm) Post Height (For Bottom Mount & Pass Through) –T .120" (3.05 mm) Post Height –04 = (Mates with SLW, CES, HLE) MATES CURRENT RATING (PER PIN) TSM/SSW 4.7 A TSM/SSM 5.4 A TSM/HLE 4.1 A ROW OPTION PLATING OPTION LEAD STYLE = Matte Tin –SV = Single Row Vertical Pin (2.54) .100 x No. of positions 36 2 PINS POWERED (2.54) .100 PROCESSING (2.54) .100 Lead–Free Solderable: Yes -DH/-SH Lead Coplanarity: (0.15 mm) .006" max (02-36)* -DV/-SV Lead Coplanarity: (0.10 mm) .004" max (02-05) (0.13 mm) .005" max (06-10)* (0.15 mm) .006" max (11-36)* *(.004" stencil solution may be available; contact IPG@samtec.com) (0.64) .025 SQ Post Height (2.54) .100 SSM –SH TSM = Single Row Horizontal Pin For complete scope of recognitions see www.samtec.com/quality HORIZONTAL (1.40) .055 FILE NO. E111594 (1.78) .070 Note: Some lengths, styles and options are non-standard, non-returnable. (2.54) .100 x No. of positions 36 01 (3.05) .120 ALSO AVAILABLE • Edge Mount and Locking Clips for –SV • Solder Locks for –DH and Shrouds for –DV • Other platings Contact Samtec. (3.81) .150 APPLICATIONS RECOGNITIONS (MOQ Required) (1.14) .045 REF 01 (1.58) .062 DIA (2) Optional Alignment Pin (–A) (No. of positions x (2.54) .100) – (5.08) .200 (0.64) .025 SQ Post Height (2.03) .080 (2.54) .100 –01= (4.57) .180 –02, –03, –04 = (4.82) .190 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. TSM–115–01–T–SH–A TSM–110–01–T–DV TSM–126–02–L–DH–K TSM SERIES OTHER OPTIONS –A = Alignment Pin metal or plastic at Samtec discretion (Not available with –TM or –MT) (02 positions min.) (Not available with –LC) –LC = Locking Clip (Not available with –TM) (3 positions min.) (Not available with –A) (Manual placement required) –K –P = (6.50 mm) .256" DIA Polyimide Film Pick & Place Pad (–DV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) –“XXX” = Polarized Position (–DH: 5 positions minimum without –TR) (6.35) .250 (–SV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) –SH & –DH –DV –TM 02 thru 30 positions only 72 (2.54) (5.08) .100 .200 (1.14) .045 REF 71 (0.64) .025 SQ (2.54) .100 (13.27) .050 = Triple Row Vertical Mixed Technology (Style –01 only) (2.54) .100 x No. of positions 01 Not available with –MT or –TM –SV = Double Row Vertical Pin 02 = Tape & Reel Packaging –SV = 02-22 positions –DV = 02-28 positions –SH = 02-30 positions –DH = 02-29 positions (6.86) .270 (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–DH: 4 positions minimum without –TR) –TR (4.06) .160 = Plastic Pick & Place Pad 03 (2.54) .100 X No. of positions 90 (2.54) .100 (2.54) .100 (2.79) .110 (1.58) .062 DIA (No. of positions -2) x (2.54) .100) –A Option 01 (3.81) .150 –LC Option –MT = Mixed Technology Pin (Style –01, –02 or –03 only) (2.54) .100 x No. of positions 02 72 (2.54) .100 x No. of positions 02 (2.54) .100 01 (1.58) .062 DIA(2) (No. of positions x (2.54) .100) – (5.08) .200 (0.64) .025 72 (6.10) .240 (2.54) (6.10) .100 .240 71 71 01 (1.78) .070 (2.54) .100 (2.54) .100 (2.54) .100 (2.54) .100 (3.68) .145 (2.54) .100 (0.64) .025 Post Height (7.87) .310 (3.56) .140 (11.43) .450 –DH (1.78) .070 (1.40) .055 88 (0.64) .025 SQ (2.54) .100 = Double Row Horizontal Pin (Style –01, –02 or –03 only) Optional Alignment Pin (–A) Post Height (2.54) .100 (7.62) .300 Post Height (1.52) .060 (7.87) .310 (1.16) .046 (1.16) .046 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. Post Height
TSM-110-04-T-SH-A-P 价格&库存
很抱歉,暂时无法提供与“TSM-110-04-T-SH-A-P”相匹配的价格&库存,您可以联系我们找货
