TST-108-04-L-D-LA
TST-108-04-L-D-LA
    SAMTEC(申泰)
    CONN HEADER R/A 16POS 2.54MM
TST-108-04-L-D-LA 数据手册
ZST–113–03–F–D–0735 F-218 (Rev 10OCT17) HTST–125–01–L–DV (2.54 mm) .100" TST, HTST, ZST SERIES SHROUDED .025" SQ POST IDC HEADERS Mates with: IDSD, SMSD SPECIFICATIONS For complete specifications www.samtec.com?TST, www.samtec.com?HTST or www.samtec.com?ZST TST = Cable Strip Insulator Material: TST, ZST: Black Glass Filled Polyester HTST: Natural LCP Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Current Rating (IDSD/TST): 3.4 A per pin (2 pins powered) Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Flammability Rating: UL 94V-O Withstanding Voltage: 1000 VRMS RoHS Compliant: Yes 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 Specify LEAD STYLE from chart. = Gold flash on post, Matte Tin on tail (Not available on –DV) (Standard sizes) –F –L (2.92) .115 (4.19) .165 (14.35) .565 –01 –02 –03 = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail (2.54) .100 x No. of Positions + (7.62) .300 (2.54) .100 x No. of Positions + (5.08) .200 LEAD T/H STYLE (A) –T = Matte Tin 02 A (2.54) .100 (2.54) .100 01 For complete scope of recognitions see www.samtec.com/quality FILE NO. E111594 –DV (HTST ONLY) NO. PINS PER ROW 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 OTHER SOLUTIONS (Standard sizes) • Shrouded board-to-board headers and stackers to mate with SSW, SSQ, ESW, ESQ, SSM and BCS Series. See TSS, HTSS and ZSS Series. (2.54) .100 x No. of Positions + (7.62) .300 (2.54) .100 x No. of Positions + (5.08) .200 02 ALSO AVAILABLE LEAD STYLE PLATING OPTION Specify LEAD STYLE from chart. = Gold flash on post, Matte Tin on tail –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail –T (2.54) .100 = Matte Tin (2.54) .100 (6.35) .250 (8.89) .350 (2.29) .090 MIN (0.38) .015 (0.64) .025 SQ TYP –D Surface Mount (lead style –01 only) (HTST only) = Double Row Through-hole (lead style –01, –02 & –03 only) –P –DV = Pick & Place Pad = Double Row Surface Mount (lead style –01 only) (HTST only) –TR = Tape & Reel Packaging –D–RA = Double Row Right-angle (lead style –04 & –05 only) B (5.08) .200 (2.54) .100 –D–RA –“XXXX” = Body Height LEAD STYLE –01 –02 –03 –04 –05 –06 –07 –08 –09 C (OAL) MAX BODY HEIGHT (16.00) .630 (13.72) .540 (18.54) .730 (16.26) .640 (21.08) .830 (18.80) .740 (23.62) .930 (21.34) .840 (26.16) 1.030 (23.88) .940 (28.70) 1.130 (26.42) 1.040 (31.24) 1.230 (28.96) 1.140 (33.78) 1.330 (31.50) 1.240 (36.32) 1.430 (34.04) 1.340 BODY HEIGHT C (OAL) Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM BODY HEIGHT D –F (9.27) .365 01 OTHER OPTION (11.18) .440 (0.64) .025 SQ TYP 1 ZST ROW OPTION (6.35) .250 (10.16) .400 (0.38) .015 –D LEAD RIGHTSTYLE ANGLE (B) –04 (3.30) .130 –05 (5.84) .230 (9.27) .365 (8.89) .350 RECOGNITIONS Note: Some lengths, styles and options are non-standard, non-returnable. ZST is non-standard, non-returnable. PLATING OPTION = High Temp Cable Strip Lead–Free Solderable: HTST: Yes TST, ZST: Wave Only SMT Lead Coplanarity: (0.10 mm) .004" max (05-15) (0.15 mm) .006" max (17-36)* *(.004" stencil solution may be available; contact IPG@samtec.com) • Other platings & sizes • Alignment Pins • Single Row • Locking Leads • Polarized Contact Samtec. LEAD STYLE HTST PROCESSING (MOQ Required) NO. PINS PER ROW 1 TYPE STRIP All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
TST-108-04-L-D-LA 价格&库存
很抱歉,暂时无法提供与“TST-108-04-L-D-LA”相匹配的价格&库存,您可以联系我们找货
TST-108-04-L-D-LA
  • 20+34.1230420+4.43438
