2002-1201
2002-1201
    WAGO(万可电子)
2002-1201 数据手册
Data sheet | Item number: 2002-1201 2-conductor through terminal block; 2.5 mm²; suitable for Ex e II applications; side and center marking; for DIN-rail 35 x 15 and 35 x 7.5; Pushin CAGE CLAMP®; 2,50 mm²; gray www.wago.com/2002-1201 Color: Data Electrical data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 19.05.2021    Page 1/4 Data sheet | Item number: 2002-1201 www.wago.com/2002-1201 Ratings per IEC/EN Ratings per IEC/EN 60947-7-1 Nominal voltage (III/3) 800 V Rated surge voltage (III/3) 8 kV Rated current 24 A Rated current 2 32 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Ratings per UL Approvals per UL 1059 Rated voltage UL (Use Group B) 600 V Rated current UL (Use Group B) 20 A Rated voltage UL (Use Group C) 600 V Rated current UL (Use Group C) 20 A Ratings per CSA Approvals per C22.2 No 158 Rated voltage CSA (Use Group B) 600 V Rated current CSA (Use Group B) 20 A Rated voltage CSA (Use Group C) 600 V Rated current CSA (Use Group C) 20 A Ex information Ratings per ATEX: PTB 03 ATEX 1162 U / IECEx: PTB 03.0004U (Ex eb IIC Gb) Rated voltage EN (Ex e II) 550 V Rated current (Ex e II) 22 A Rated current (Ex e II) with jumper 20 A Connection data Connection technology Push-in CAGE CLAMP® Actuation type Push-in Open Tool Slot Connectable conductor materials Copper Copper Nominal cross-section 2.5 mm² Solid conductor 0.25 … 4 mm² / 22 … 12 AWG Solid conductor; push-in termination 1 … 4 mm² / 18 … 12 AWG Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 19.05.2021    Page 2/4 Data sheet | Item number: 2002-1201 www.wago.com/2002-1201 Solid conductor; push-in termination 1 … 4 mm² / 18 … 12 AWG Fine-stranded conductor 0.25 … 4 mm² / 22 … 12 AWG Fine-stranded conductor; with insulated ferrule 0.25 … 2.5 mm² / 22 … 14 AWG Fine-stranded conductor; with ferrule; push-in termination 1 … 2.5 mm² / 18 … 14 AWG Note (conductor cross-section) Depending on the conductor characteristic, a conductor with a smaller cross-section can also be inserted via push-in termination. Strip length 10 … 12 mm / 0.39 … 0.47 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Wiring type Front-entry wiring Number of jumper slots 2 Physical data Width 5.2 mm / 0.205 inch Height 48.5 mm / 1.909 inch Depth from upper edge of DIN-rail 32.9 mm / 1.295 inch Mechanical data Design horizontal type Mounting type DIN-35 rail Marking level Center/side marking Material data Color gray Insulation material Polyamide (PA66) Fire load 0.109 MJ Weight 5.1 g Commercial data Product Group 22 (TOPJOB S) Packaging type BOX Country of origin DE GTIN 4017332999168 Customs tariff number 85369010000 Required accessories Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 19.05.2021    Page 3/4 Data sheet | Item number: 2002-1201 www.wago.com/2002-1201 Required accessories End plate Item no.: 2002-1291 End and intermediate plate; 0.8 mm thick; gray www.wago.com/2002-1291 Item no.: 2002-1292 End and intermediate plate; 0.8 mm thick; orange www.wago.com/2002-1292 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at 01788 568 008. 19.05.2021    Page 4/4
2002-1201 价格&库存
很抱歉,暂时无法提供与“2002-1201”相匹配的价格&库存,您可以联系我们找货
    • 100+8.29463
    库存:3500
    2002-1201
    • 1+20.548011+2.65820
    • 10+14.7355010+1.90626
    • 25+12.8500325+1.66235
    • 50+11.6399750+1.50581
    • 100+10.62334100+1.37429
    • 250+9.55117250+1.23559
    • 500+8.91961500+1.15389
    • 1000+8.417431000+1.08893
    • 5000+7.630105000+0.98707
    库存:21994
    2002-1201
      • 100+1.69500
      库存:3220
