Data sheet | Item number: 279-907
2-conductor ground terminal block; 1.5 mm²; center marking; for DIN-rail 35
x 15 and 35 x 7.5; CAGE CLAMP®; 1,50 mm²; green-yellow
www.wago.com/279-907
Color:
Data
Connection data
Subject to changes.
WAGO Kontakttechnik GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
29.12.2019 Page 1/13
Connection technology
CAGE CLAMP®
Actuation type
Operating tool
Connectable conductor materials
Copper
Solid conductor
0.08 … 1.5 mm² / 28 … 16 AWG
Fine-stranded conductor
Strip length
8 … 9 mm / 0.31 … 0.35 inch
Total number of connection points
2
Total number of potentials
1
Number of levels
1
Type of wiring
Front-entry wiring
Geometrical Data
Width
4 mm / 0.157 inch
Height from upper-edge of DIN-35 rail
27 mm / 1.063 inch
Depth
54 mm / 2.126 inch
Mechanical data
Design
horizontal
Type of mounting
DIN-35 rail
Marking level
Center marking
Material Data
Color
green-yellow
Insulating material
Polyamide 66 (PA 66)
Fire load
0.076 MJ
Weight
7.9 g
Commercial data
Packaging type
BOX
Country of origin
DE
GTIN
4045454084479
Customs Tariff No.
85369010000
Approvals / Certificates
Country specific Approvals
Certificate
Logo
Approval
Subject to changes.
Hansastr. 27
32423 Minden
Additional Approval Text
name
29.12.2019 Page 2/13
Logo
Approval
name
CCA
DEKRA Certification B.V.
EN 60947
NTR NL7081
KEMA/KEUR
EN 60947
2160584.04
Approval
ABS
American Bureau of Shipping
14HG1293677PDA
BV
Bureau Veritas S.A.
EN 60947
07436/E0 BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE00001V2
LR
Lloyds Register
EN 60947
91/20112
(E9)
Ship Approvals
Logo
Certificate
name
UL-Approvals
Logo
Approval
Certificate
name
UR
Underwriters Laboratories Inc.
UL 1059
E45172
Compatible products
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 3/13
Insulation stop
Item no.: 279-470
Insulation stop; 0.08 - 0.2 mm² "s" (0.14 mm² "f-st"); 5 pieces/strip; white
www.wago.com/279-470
Item no.: 279-471
Insulation stop; 0.25 mm²; 5 pieces/strip; dark gray
www.wago.com/279-471
Item no.: 209-170
Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs; gray
www.wago.com/209-170
Item no.: 280-404
Test plug adapter; 5 mm wide; for test plug 210-137 (2.3 mm Ø); suitable for 1.5 mm² - 4 mm² tbs; gray
www.wago.com/280-404
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; uninsulated; electro-tin plated
www.wago.com/216-101
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20; uninsulated; electro-tin plated
www.wago.com/216-102
Item no.: 216-103
Ferrule; Sleeve for 1 mm² / AWG 18; uninsulated; electro-tin plated
www.wago.com/216-103
Item no.: 216-201
Ferrule; Sleeve for 0.5 mm² / 20 AWG; insulated; electro-tin plated; white
www.wago.com/216-201
Item no.: 216-202
Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; gray
www.wago.com/216-202
Item no.: 216-203
Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; red
www.wago.com/216-203
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
www.wago.com/216-301
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; insulated; electro-tin plated; green
www.wago.com/216-302
Item no.: 279-325
End and intermediate plate; 2 mm thick; gray
www.wago.com/279-325
Item no.: 279-326
Separator plate; 2 mm thick; oversized; gray
www.wago.com/279-326
check
ferrule
End plate
Item no.: 279-328
Subject to changes.
Hansastr. 27
32423 Minden
www.wago.com/279-328
29.12.2019 Page 4/13
Item no.: 279-328
End and intermediate plate; 2 mm thick; orange
Item no.: 279-329
Separator plate; 2 mm thick; oversized; orange
www.wago.com/279-329
Item no.: 209-106
Mounting carrier; for isolated mounting on DIN 35 rails; gray
www.wago.com/209-106
Item no.: 709-153
Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent
www.wago.com/709-153
assembling
Carrier rail
Item no.: 210-112
www.wago.com/210-112
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm
Item no.: 210-113
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-113
Item no.: 210-114
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715
www.wago.com/210-114
Item no.: 210-115
www.wago.com/210-115
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm
Item no.: 210-118
Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715
www.wago.com/210-118
Item no.: 210-196
www.wago.com/210-196
Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silver-colored
Item no.: 210-197
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715
www.wago.com/210-197
Item no.: 210-198
Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored
www.wago.com/210-198
Item no.: 210-504
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715
www.wago.com/210-504
Item no.: 210-505
Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715
www.wago.com/210-505
Item no.: 210-506
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715
www.wago.com/210-506
Item no.: 210-508
Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715
www.wago.com/210-508
Protective Warning Marker
Item no.: 279-415
Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow
www.wago.com/279-415
Jumper
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 5/13
Jumper
Item no.: 249-123
Push-in type wire jumper; insulated; wire length 180 mm; Conductor cross section 0.75 mm²
www.wago.com/249-123
Item no.: 249-125
Push-in type wire jumper; insulated; wire length 60 mm; Conductor cross section 0.75 mm²
www.wago.com/249-125
Item no.: 249-126
Push-in type wire jumper; insulated; wire length 110 mm; Conductor cross section 0.75 mm²
www.wago.com/249-126
Item no.: 249-127
Push-in type wire jumper; insulated; wire length 250 mm; Conductor cross section 0.75 mm²
www.wago.com/249-127
Item no.: 279-402
Adjacent jumper; insulated; Nominal current 15 A; gray
www.wago.com/279-402
Item no.: 279-409
Alternate jumper; insulated; Nominal current 15 A; gray
www.wago.com/279-409
Item no.: 279-422
Adjacent jumper; insulated; Nominal current 15 A; yellow-green
www.wago.com/279-422
Item no.: 279-482
Comb-style jumper bar; insulated; 2-way; IN = IN terminal block; gray
www.wago.com/279-482
Item no.: 279-483
Comb-style jumper bar; insulated; 3-way; IN = IN terminal block; gray
www.wago.com/279-483
Item no.: 279-490
Comb-style jumper bar; insulated; 10-way; IN = IN terminal block; gray
www.wago.com/279-490
Item no.: 279-492
Alternate comb-style jumper bar; insulated; 2-way; IN = IN terminal block; gray
www.wago.com/279-492
Marking accessories
Item no.: 2009-114
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; white
www.wago.com/2009-114
Item no.: 2009-114/000-002
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 2009-114/000-005
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; red
/000-005
Item no.: 2009-114/000-006
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; blue
/000-006
Item no.: 2009-114/000-007
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; gray
/000-007
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 6/13
Item no.: 2009-114/000-012
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; orange
/000-012
Item no.: 2009-114/000-023
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; green
/000-023
Item no.: 2009-114/000-024
WMB-Inline; for Smart Printer; on reel; stretchable 4 - 4.2 mm; plain; snap-on type; violet
/000-024
Item no.: 209-128
Adaptor
www.wago.com/209-128
Item no.: 209-140
Group marker carrier
www.wago.com/209-140
Item no.: 209-141
www.wago.com/209-141
Item no.: 209-142
www.wago.com/209-142
Item no.: 209-185
Adaptor
www.wago.com/209-185
Item no.: 249-105
www.wago.com/249-105
Item no.: 793-4501
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; white
www.wago.com/793-4501
Item no.: 793-4501/000-002
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; yellow
/000-002
Item no.: 793-4501/000-005
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; red
/000-005
Item no.: 793-4501/000-006
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; blue
/000-006
Item no.: 793-4501/000-007
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; gray
/000-007
Item no.: 793-4501/000-012
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; orange
/000-012
Item no.: 793-4501/000-014
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 7/13
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; brown
/000-014
Item no.: 793-4501/000-017
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; light green
/000-017
Item no.: 793-4501/000-023
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; green
/000-023
Item no.: 793-4501/000-024
WMB marking card; as card; stretchable 4 - 4.2 mm; plain; snap-on type; violet
/000-024
Item no.: 210-647
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft
www.wago.com/210-647
Item no.: 210-648
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short
www.wago.com/210-648
Item no.: 210-719
www.wago.com/210-719
tools
Downloads
Documentation
Bid Text
279-907
Feb 19, 2019
xml
3.1 kB
Download
Feb 28, 2017
doc
24.1 kB
Download
Apr 3, 2019
pdf
2.1 MB
Download
URL
Download
X81 - Datei
279-907
doc - Datei
Additional Information
Technical explanations
CAD/CAE-Data
CAD data
2D/3D Models 279-907
CAE data
Subject to changes.
Hansastr. 27
32423 Minden
Download
29.12.2019 Page 8/13
Download
EPLAN Data Portal 279-907
WSCAD Universe 279-907
Download
Installation Notes
Assembly
By snapping a ground conductor terminal
block onto the carrier rail, a direct electrical
connection is automatically made to the rail.
Quick assembly keys prevent reverse
mounting.
Removing a terminal block from the
assembly.
Inserting a conductor
CAGE CLAMP® connection
CAGE CLAMP®-Anschluss
Inserting a conductor.
Leiter lösen.
With ferruled conductors, it is necessary to
use a terminal block one size larger than the
conductor’s nominal cross-section.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 9/13
Inserting insulation stops.
Jumpered
Commoning ground conductor terminal
blocks with through terminal blocks is
possible in one direction only (via rear side
of terminal block) using adjacent jumpers. In
addition to the required marking of these
blocks, use yellow-green adjacent jumpers.
Brücken mit Brückungskämmen
Brückungskämme bis zum Anschlag
hinunterdrücken.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 10/13
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 11/13
Wire jumpers
When installing machines or control
systems, it is often necessary to make an
additional connection between two terminal
blocks that are not next to each other on the
rail. In such cases, WAGO’s touch-proof,
push-in type wire jumpers are the ideal
solution.
These jumpers are compatible with the
following rail-mount terminal blocks:
279 Series (1.5 mm²/16 AWG),
280/775/780 Series (2.5 mm²/14
AWG)
281/769/776/777/781 and 880
Series (4 mm²/12 AWG)
They are available in three conductor
lengths (60, 110 and 250 mm), allowing up to
60 terminal blocks to be commoned
depending on their width (see table on the
right).
Compared with the 279 Series, the 280/775
/780 and 281/776/777/781 Series can also
accommodate two wire jumpers, allowing
the use of commoning chains. Furthermore,
the 280/769/775/780/880 and 281/776/777
/781 Series allow both wire jumper and
adjacent jumper to be simultaneously
plugged into a same terminal block.
Testing
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 12/13
Testing with a test plug
(picture shows 209‑170 Test Plug Adapter).
Marking
Marking via WMB Multi Marking System.
Subject to changes.
Hansastr. 27
32423 Minden
29.12.2019 Page 13/13
很抱歉,暂时无法提供与“279-907”相匹配的价格&库存,您可以联系我们找货
