F-215 (Rev 24AUG15)
IPL1–106–01–L–D–RE1–K
IPL1–110–02–L–S–K
IPL1–105–02–L–D–K
IPL1–120–01–L–D–RA–K
(2.54 mm) .100"
IPL1 SERIES
DISCRETE WIRE HEADER
SPECIFICATIONS
For complete specifications
www.samtec.com?IPL1
Mates with
discrete wire cable
assemblies
Mates with:
MMSD, MMSS,
MMSDT, MMSST
Insulator Material:
Natural LCP
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50µ" (1.27 µm) Ni
Operating Temp Range:
-55°C to +125°C
Voltage Rating:
675 VAC/954 VDC
RoHS Compliant:
Yes
Keyed
Polarization
Align &
Latch™
Processing:
Lead–Free Solderable:
Yes
–S & –D (–02 Lead Style)
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-05)
(0.13 mm) .005" max (06-10)
(0.15 mm) .006" max (11-25)
–SH SMT Lead Coplanarity:
(0.15 mm) .006" max (02-25)
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
NO. PINS
PER ROW
LEAD
STYLE
02, 03, 04, 05, 06, 08,
10, 12, 15, 16, 20, 25
= Throughhole
IPL1
1
–01
–RE1
APPLICATION
–02
(Standard sizes)
= Surface
Mount
MMSD
–01. –02 & –RA =
No. of positions x
(2.54) .100 + (1.52) .060
–SH & –RE1 =
No. of positions x
(2.54) .100 + (4.06) .160
(8.76)
.345
IPL1-RE1
(7.04)
.277
(9.58)
.377
Note: Some lengths, styles
and options are non-standard,
non-returnable.
–S
–RA
=Right Angle
(–01 lead
style only)
–SH
= Single Row
Horizontal
(–02 lead
style only)
–D
= Double Row
(2.54)
.100
–K
=Keyed
Polarization
–RE1
(6.86)
.270
(2.03)
.080
(3.05)
.120
–01–D
(2.16)
.085
–01–S
–01–S–RE1
(5.59)
.220
(1.02) .040
(7.62)
.300
(5.44)
.214
–02–SH
(8.26)
.325
(2.16)
.085
(2.54) .100
(8.13)
.320
(1.52)
.060
(2.54)
.100
(2.03)
.080
(0.64) .025 SQ
–02
–01
–RA
K
=Right Angle
Elevated
(–01 lead
style only)
(–K is a required
callout)
(5.46)
.215
(2.54)
.100
(6.35)
.250
TAIL
OPTION
= Single Row
–01–S-RA
01 02
–02–D
–L
= 10µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
(6.10)
.240
(5.08)
.200
(8.76)
.345
• Other sizes
• With or without plug
polarization
• Guide post holes
• Other platings
• Weld tab
Contact Samtec.
ROW
OPTION
01
02
(MOQ Required)
PLATING
OPTION
(1.52)
.060
–02–S
ALSO AVAILABLE
Surface Mount, Right Angle,
Right Angle Elevated
and Vertical Through-hole
(2.54 mm)
.100" pitch
–01–D–RA
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–01–D–RE1
很抱歉,暂时无法提供与“IPL1-120-02-L-S-K”相匹配的价格&库存,您可以联系我们找货
