LTMM-113-02-L-D-RA
LTMM-113-02-L-D-RA
    SAMTEC(申泰)
    针座连接器 通孔,直角 26 位置 0.079"(2.00mm)
LTMM-113-02-L-D-RA 数据手册
F-215 ZLTMM–112–75–L–D–285 LTMM–113–02–T–D LTMM–110–02–F–D–RA (2,00 mm) .0787" LTMM, ZLTMM SERIES SHROUDED HEADER & STACKER Mates with: SQT, SQW, ESQT, SMM NO. PINS PER ROW 1 LTMM 02 PLATING OPTION TAIL OPTION D OTHER OPTION SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?LTMM or www.samtec.com?ZLTMM Insulator Material: High Temperature Nylon Terminal Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold RoHS Compliant: Yes –“XX” 04, 05, 06, 07, 08, 10, 12, 13, 15, 17, 20, 22, 25 (Standard sizes) 02 04 (6,00) .237 RECOGNITIONS (2,00) .0787 01 03 –SM = Surface Mount –T –K (2,00) .0787 (3,55) .140 (0,51) .020 SQ T/H –SM 1 ZLTMM PLATING OPTION Specify LEAD STYLE from chart. –F (0,51) .020 –L = 10µ" (0,25 µm) Gold on post, Matte Tin on tail (2,00) .0787 x No. of positions + (2,39) .094 –T 02 04 = Matte Tin (6,00) .237 (2,00) .0787 01 03 (3,55) .140 (2,00) .0787 (4,80) .190 (3,18) .125 (0,38) .015 (0,51) .020 SQ D = Gold flash on post, Matte Tin on tail (MOQ Required) (2,29) .090 MIN Note: This Series is non-standard, non-returnable. –TR –RA LEAD STYLE (Standard sizes) = (7,50 mm) .295" DIA Film Pick & Place Pad (-SM only) = Tape & Reel (–SM only) –SM NO. PINS PER ROW (1,52) .060 (2,00) .0787 (7,79) .307 –RA 04, 05, 06, 07, 08, 10, 12, 13, 15, 17, 20, 22, 25 ALSO AVAILABLE (1,27) .050 (4,80) .190 (0,38) .015 (2,29) .090 (0,38) .015 (0,89) .035 (2,97) .117 • Shrouded IDC headers and stackers to mate with TCSD Series. See STMM and ZSTMM Series. • Other sizes • Other platings Contact Samtec. = Locking Clip (-SM only) (Manual placement required) = Right Angle = Matte Tin For complete scope of recognitions see www.samtec.com/quality OTHER SOLUTIONS –LC –RA = 10µ" (0,25 µm) Gold on post, Matte Tin on tail Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max –F = Gold flash on post, Matte Tin on tail –L (2,00) .0787 x No. of positions + (2,39) .094 (0,51) .020 = Polarized Position Leave blank for Through-hole (3,05) .120 BODY HEIGHT (6,35) B .250 (OAL) MIN BODY HEIGHT OTHER OPTION –“XXX” –“XX” = Body Height = Polarized Position LEAD STYLE –75 –62 –65 –73 –63 –66 –69 –74 –70 –71 –72 B (OAL) MAX BODY HEIGHT (9,58) 0.377 (7,42) 0.292 (10,08) 0.397 (7,92) 0.312 (10,49) 0.413 (8,33) 0.328 (12,09) 0.476 (9,93) 0.391 (14,10) 0.555 (11,94) 0.470 (15,09) 0.594 (12,93) 0.509 (15,60) 0.614 (13,44) 0.529 (17,09) 0.673 (14,94) 0.588 (17,60) 0.693 (15,44) 0.608 (21,08) 0.830 (18,92) 0.745 (21,62) 0.851 (19,46) 0.766 Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
LTMM-113-02-L-D-RA 价格&库存
很抱歉,暂时无法提供与“LTMM-113-02-L-D-RA”相匹配的价格&库存,您可以联系我们找货
LTMM-113-02-L-D-RA
  • 1+44.381991+5.72170
  • 25+40.1312025+5.17369
  • 50+37.2851350+4.80678
  • 100+35.51507100+4.57858
  • 500+33.11099500+4.26865
库存:114
