MMTD-10-20-L-09.00-S
    SAMTEC(申泰)
    RMINAL DISCRETE CABLE ASSEMBLY
MMTD-10-20-L-09.00-S 数据手册
F-224 SUPPLEMENT T1M74–L–01–F IPM1–08–D MMTD–06–20–F–03.25–D–TUS (2.54 mm) .100" MMTD, MMTDT, MMTS, MMTST, IPM1, T1M74-L, T1M74-R SERIES DISCRETE WIRE COMPONENTS & TOOLING Mates with: MMSD(T), MMSS(T) –TXS Mates with: IPL1 SPECIFICATIONS For complete specifications see www.samtec.com?MMTD, www.samtec.com?MMTDT, www.samtec.com?MMTS or www.samtec.com?MMTST Insulator Material: Nylon, White Contact Material: Phosphor Bronze Wire: 20 to 30 AWG Plating: Au over 50 µ" (1.27 µm) Ni Operating Temp Range: -10 °C to +105 °C (20-26 AWG) -10 °C to +80 °C (28-30 AWG) -40 °C to +125 °C (*Teflon™ Fluoropolymer) Voltage Rating: 600 VAC RoHS Compliant: Yes *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec. RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality PINS PER ROW TYPE –02, –03, MMTD –04, –05, = Double Row –06, –08, PVC Cable –10, –12, MMTDT –15, –16, = Double Row –20, –25 Blue *Teflon ™ Fluoropolymer (Standard sizes) Cable MMTD(T) (20. 24, 28 & 30 (7.62) Wire Gauge only) .300 MMTS = Single Row (7.62) .300 PVC Cable (8.89) .350 MMTST = Single Row (8.89) ™ Blue *Teflon .350 Fluoropolymer Cable (20, 24, 28 & 30 Wire Gauge only) –20 –20C = Color Coded Cable (MMTD & MMTS only) –22 –24 –24C = Color Coded Cable (MMTD & MMTS only) –26 –28 –28C PLATING OPTION –F = Gold flash on contact –L = 10 µ" (0.25 µm) Gold on contact Assembly Length ± (3.18) .125 ASSEMBLY LENGTH END OPTION –“XX.XX” = Single End = Assembly Length in Inches –S= (76.2 mm) 03.00" min. –D= (82.6 mm) 03.25" min. –S 01 No. of positions x (2.54) .100 + (1.78) .070 (2.54) .100 20 .100 –TDS 10 = Socket on End 2, latch down (2.54) 20 –24C, .100 –28C –20C, CABLE COLOR CODING (PVC CABLE ONLY) PIN COLOR 1 2 3 4 5 6 7 8 9 10 ETC (17.53) .690 –30 –TUS = Socket on End 2, latch up APPLICATION (2.54) (2.54) .100 (Only available with –D) = Double End 10 11 11 OPTION –D Note: No. of positions x (2.54) .100 Some lengths, styles and options + (1.78) .070 are non-standard, non-returnable. 01 = Color Assembly (7.62) Coded Cable Length .300 (MMTD & ± (3.18) .125 MMTS only) (7.62) Note: .300 *Teflon™ Fluoropolymer Cable is intended for crimp only. Contact Samtec for solderable cable applications. FILE NO. E111594 WIRE GAUGE (5.08) .200 MMTS(T) (17.53) BROWN .690 RED ORANGE YELLOW GREEN BLUE VIOLET GRAY WHITE BLACK REPEAT (5.08) .200 SPECIFICATIONS For complete specifications see www.samtec.com?IPM1, www.samtec.com?T1M74-L or www.samtec.com?T1M74-R TOOLING • Hand Tool: CAT-HT-174-2030-13 • Mini Applicator (20-24 AWG): CAT-MC-174-2024-XX-01 • Mini Applicator (26-30 AWG): CAT-MC-174-2630-XX-01 TYPE POSITIONS PER ROW –02, –03, –04, IPM1 –05, –06, –08, = Body, –10, –12, –15, Loose –16, –20, –25 (Standard sizes) (7.62) .300 ROW OPTION –S = Single Row –D = Double Row (5.08) .200 (17.53) .690 –01 = 26 to 30 AWG T1M74-L –02 = Contact, Loose = 20 to 24 AWG T1M74-R = Contact, Full Reel (15,300 Parts per Reel) –F = Gold flash on contact –L = 10 µ" (0.25 µm) Gold on contact (19.33) .761 (1.57) .062 DIA (1.91) .075 • Extraction Tool: CAT-EX-74-01 PLATING OPTION WIRE GAUGE TYPE (3.81) .150 –D (3.17) .125 –S WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MMTD-10-20-L-09.00-S 价格&库存
很抱歉,暂时无法提供与“MMTD-10-20-L-09.00-S”相匹配的价格&库存,您可以联系我们找货
