MTSW-109-08-S-S-130-LA
    SAMTEC(申泰)
    MODIFIED .025 SQUARE POST TERMIN
MTSW-109-08-S-S-130-LA 数据手册
MODIFIED .025" SQ POST HEADERS (2.54 mm) .100" PITCH • MTSW/HMTSW SERIES MTSW/HMTSW SERIES Board Mates: SSW, SSQ, ESW, ESQ, BCS, BSW CES, SLW, HLE, SSM Cable Mates: IDSD, IDSS - MTSW HMTSW Lead–Free Solderable: MTSW: No, Lead Wave Only HMTSW: Yes (2.54) .100 x No. of Positions (2.54) .100 —D (5.08) .200 02 thru 25 = (5.08 mm) .200" Pitch (Every other position filled) PROCESSING OAL (2.48) .098 C LEAD STYLE Specify LEAD STYLE from chart = .100" (2.54 mm) Center Version –2 = Hi-Temp Modified Strip - 01 thru 50 = (2.54 mm) .100" Pitch (All positions filled) Insulator Material: MTSW: Black Glass Filled Polyester HMTSW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin —S NO. PINS PER ROW –1 = Modified Strip SPECIFICATIONS - PIN CENTERS = .200" (5.08 mm) Center Version LEAD STYLE OAL – 05 (8.51) .335 – 06 (7.62) .300 – 07 (10.92) .430 – 08 (13.46) .530 – 09 (18.54) .730 – 10 (21.08) .830 POST (0.00) .000 MIN OVERALL LENGTH (OAL) (2.54) .100 – 11 (23.62) .930 – 12 (26.16) 1.030 – 13 (31.24) 1.230 – 21 (36.32) 1.430 – 22 (16.00) .630 – 23 (11.30) .445 – 24 (12.19) .480 – 27 (33.78) 1.330 – 28 (28.70) 1.130 TAIL (0.00).000 MIN A OAL (5.02) .198 FOR ”A” = (2.29) .090 C A OAL —T (7.62) .300 (7.56) .298 C A OAL —Q (7.62) .300 (7.56) .298 MTSW HMTSW C A Straight Pin Versions: A=OAL–C– (2.54) .100" LEAD STYLE OAL C MAXIMUM STRAIGHT – 05 (8.51) .335 (5.97) .235 – 06 (7.62) .300 (2.79) .110 – 07 (10.92) .430 (6.10) .240 – 08 (13.46) .530 (8.64) .340 – 09 (18.54) .730 (13.72) .540 – 10 (21.08) .830 (16.26) .640 – 11 (23.62) .930 (18.80) .740 – 12 (26.16) 1.030 (21.34) .840 – 13 (31.24) 1.230 (26.42) 1.040 – 21 (36.32) 1.430 (31.50) 1.240 (11.18) .440 – 22 (16.00) .630 – 23 (11.30) .445 (6.48) .255 – 24 (12.19) .480 (7.37) .290 – 27 (23.78) 1.330 (28.96) 1.140 – 28 (28.70) 1.130 (23.88) .940 Note: These Series are non-standard, non-returnable. F-224 (Rev 08DEC23) samtec.com?MTSW or samtec.com?HMTSW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. - - - PLATING OPTION –F ROW OPTION –S = Gold flash on post, Matte Tin on tail = Single Row –L = Double Row POST HEIGHT - “XXXX” –RA or –RE –LL –Q = Double Row .200" (5.08 mm) row space –T –LA = –RA option with –LL Option (Maximum “C” = (13.46 mm) .530") = Matte Tin C (2.54) .100 x No. of Positions —S (3.02) .119 = Polarized (Specify ‘XXX’ as position number) = Locking Lead (not available with –RE, not available in single row 1 or 2 positions) (Available on tails from (2.29 mm) .090" to (10.16 mm) .400" only) = Triple Row = 10 µ" (0.25 µm) Gold on post, Gold flash on balance POLARIZED OPTION “XXX” = Right-angle (HMTSW –S &–D = 36 positions maximum) –T –G - OTHER OPTION = “C” Dimension (Specify post height in INCHES .005" (0.13 mm) increments) –D = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail - D (3.09) .122 –RX OPTION D –RA (1.52) .060 – RE (4.06) .160 E C —D (6.10) .240 (5.56) .219 FOR ”E” = (2.29) .090 MIN FOR –RA & –RE) E C —T (8.12) .320 (8.10) .319 E C —Q (8.12) .320 (8.10) .319 MTSW HMTSW E LEAD STYLE OAL C MAXIMUM with/–RA C MAXIMUM with/–RE – 05 (8.51) .335 Not Available Not Available – 06 (7.62) .300 Not Available Not Available Not Available – 07 (10.92) .430 (3.30) .130 – 08 (13.46) .530 (5.84 .230 (3.30) .130 – 09 (18.54) .730 (10.92 .430 (8.38) .330 – 10 (21.08) .830 (13.46) .530 (10.92) .430 – 11 (23.62) .930 (16.00 .630 (13.46) .530 (16.00) .630 – 12 (26.16) 1.030 (18.54) .730 *– 13 (31.24) 1.230 (23.62) .930 (21.08) .830 *– 21 (36.32) 1.430 (28.70) 1.130 (26.16) 1.030 (5.84) .230 – 22 (16.00) .630 (8.38) .330 *– 23 (11.30) .445 (3.68) .145 *– 24 (12.19) .480 (4.57) .180 *– 27 (23.78) 1.330 (26.16) 1.030 (23.62) .930 *– 28 (28.70) 1.130 (21.08) .830 (18.54) .730 Not Available * Styles –21, –23, –24, –27 not available with –D Right-angle Styles –13, –21, –23, –24, –27, –28 not available with –T or –Q Right-angle Right-Angle Versions (– RA Options): E=OAL–C– (5.33) .210" Right-Angle Versions (– RE Options) Single Row Only: E=OAL–C– (7.87) .310" samtec.com?MTSW or samtec.com?HMTSW F-224 (Rev 08DEC23) Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
MTSW-109-08-S-S-130-LA 价格&库存
很抱歉,暂时无法提供与“MTSW-109-08-S-S-130-LA”相匹配的价格&库存,您可以联系我们找货
