QSS-075-01-L-D-RA-WT-LS1 数据手册
F-215
QSS–050–01–L–D–RA–WT
QSS–025–01–L–D–RA
(0,635 mm) .025"
QSS-RA SERIES
RIGHT ANGLE GROUND PLANE SOCKET
Selectively
plated
Right Angle
SPECIFICATIONS
Board Mates:
QTS
For complete specifications and
recommended PCB layouts see
www.samtec.com?QSS-RA
Cable Mates:
SQCD
Insulator Material:
Liquid Crystal Polymer
Contact Material:
Phosphor Bronze
Plating:
Au or Sn over
50µ" (1,27 µm) Ni
Current Rating:
Contact:
2 A per pin
(1 pin powered per row)
Ground Plane:
15.7 A per ground plane
(1 ground plane powered)
Operating Temp:
-55°C to +125°C
Voltage Rating:
275 VAC mated with QTS-RA
RoHS Compliant:
Yes
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max (025-075)
APPLICATIONS
PCB mounting
holes
HORIZONTAL
• Guide posts
• Weld tabs
• PCB mounting holes
• Solder pin option
QSS-RA/QTS-RA
Type
Rated @ 3dB Insertion Loss*
Single-Ended Signaling
–D
4.50 GHz / 9 Gbps
Differential Pair Signaling
–D
4.50 GHz / 9 Gbps
*Performance data includes effects of a non-optimized PCB.
Complete test data available at www.samtec.com?QSS-RA
or contact sig@samtec.com
NO. OF POSITIONS
PER ROW
QSS
Integral metal plane
for power or ground
01
Guide post hole or
optional locking
screw thread
PLATING
OPTION
D
RA
WT
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
–025, –050, –075
= Weld Tab
(Not available
on 25 position)
= Gold Flash on
Signal Pins and Ground Plane,
Matte Tin on tails
(50 total positions per bank)
ALSO AVAILABLE
–L
(MOQ Required)
• 30µ" (0,76 µm) Gold
• Tray Packaging
• Lead style for (2,36 mm)
.093" thick board
• Threaded insert (-MTI) for
mating with SQCD with
captive screws
• –LS1 Locking Screw
Hole for mating with
QTS-RA-LS1
• 100 positions per row
Contact Samtec.
–WT
–F
= 10µ" (0,25 µm) Gold on
Matte Tin on tails
(No. of Positions per Row/25)
x (20,00) .7875 + (13,97) .550
x (20,00) .7875 + (7,62) .300
(6,35) .250 DIA
(3,18) .125 DIA
(6,35)
.250
TYP
APPLICATION
(14,22)
(11,05) .560
.435
(7,11)
.280
(No. of Positions per Row/25) x
(20,00) .7875 + (5,72) .225
(4,71)
.186
01
(6,22)
.245
(8,33)
.328
(0,30)
.012
(0,635)
.025 SQ
(2,03)
.080
02
(3,30)
.130
DIA
(1,50)
.059
(1,47)
.058
(0,25)
.010
Note: Some lengths,
styles and options are
non-standard, non-returnable.
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
QSS-075-01-L-D-RA-WT-LS1 价格&库存
很抱歉,暂时无法提供与“QSS-075-01-L-D-RA-WT-LS1”相匹配的价格&库存,您可以联系我们找货
