S5B-XH-A
S5B-XH-A
    JST
    弯插,P=2.5mm
    线对板针座 间距P=2.50mm 5Pin(1x5P) 弯插
S5B-XH-A 数据手册
Emboss Tape XH CONNECTOR Radial Tape Specifications ––––––––––––––––––– • Current rating: 3A AC, DC (AWG #22) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 V AC/minute • Applicable wire: AWG #30 to #22 • Applicable PC board thickness: 1.6 mm The XH connector was developed based on the high reliability and versatility of our NH series connectors. The connector is very small with a mounting height of 9.8mm. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. • Original folded beam contact • Box-shaped shrouded header • Header with a boss • Interchangeability • Conforming to the HA terminal Standards –––––––––––––––––––––– Recognized E60389 Certified LR20812 J50014297 Through-hole type (viewed from soldering side) Top entry type 5.75 Side entry type ± ± 2.5 0.05 (2.5min) 2.5 (2.5min) 0.05 14.3 6.1 (9.2min) Ø 1 . 0 0 + 2 circuits: 1 0.05 3 circuits or more: 0.9 7 (3.4min) ± Ø Ø 9.8 11.5 0.9+0.1 0 Top entry type with a boss (2 circuits or more) (Single circuit) ± 1.6 0.05 5.75 9.8 1 . 1 Ø 4.35 +0.2 0 7 ± 0.05 2 ± 0.05 0.05 3.4min 2.5 ± 7 . 1 Ø 2.5min +0.1 0 ± Ø Ø +0.1 0 1 . 0 + 9 . 0 Ø 2 circuits: 1 0.05 3 circuits or more: 0.9 Note: 1. Tolerances are non-cumulative: 0.05mm for all centers. 2. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be larger. The dimensions above should serve as a guideline. Contact JST for details. 11 SMT type (viewed from component side) Side entry type End face of wafer on the mating side 2.3 3.9 0.2 6.5 1.3 2.5 1.8 Note: 1. Tolerances are non-cumulative: 0.05mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. TS S C0 18.01(X H) 1 XH CONNECTOR Contact Shape A 1.95 1.6 1.8 Model No. Shape SXH-001T-P0.6N SXH-001T-P0.6 SXH-002T-P0.6 A Shape B 2 B Applicable Wire AWG# mm2 Insulation O.D (mm) Q'ty / reel 5,000 0.13~0.33 26~22 1.3~1.9 0.08~0.33 28~22 0.9~1.9 0.05~0.13 30~26 0.9~1.3 8,000 2.4 2.35 Material and Finish Phosphor bronze, tin-plated (reflow 6.5 6.5 Contact Crimping machine Crimp applicator SXH-001T-P0.6N AP-K2N SXH-001T-P0.6 Applicator Dies RoHS compliance Note: 1. Contact JST if you require gold-plated contacts or contacts made of brass. 2. Contact JST also if you require shielded wires, thin wires or other special wires. 3. SXH-001T-P0.6N is low-insertion force type contact, for easier insertion/ withdrawal, which would be less resistant to the vibration. Crim papplicator withdies MKS-L MK/SXH-001-06N APLMK SXH001-06N *MKS-SC SC/SXH-001-06N APLSC SXH001-06N MKS-L MK/SXH-001-06 APLMK SXH001-06 *MKS-SC SC/SXH-001-06 APLSC SXH001-06 Crimping machine Crimp applicator Contact SXH-002T-P0.6 AP-K2N Applicator Dies Crimp applicator with dies MKS-L MK/SXH-002-06 APLMK SXH002-06 *MKS-SC SC/SXH-002-06 APLSC SXH002-06 Note: *Strip-crimp applicator Housing Circuits 7.75 1 2 2 4.1 3 5.7 4 5 6 Circuit No.1 mark 6 2.5 A B 7 C 9 8 10 Plugged up (2 circuits 10.0mm pitch) 11 12 13 7.75 14 15 16 20 4.1 Model No. Dimensions (mm) B A XHP-1 XHP-2 XHP-2(10.0)-U XHP-3 XHP-4 XHP-5 XHP-6 XHP-6(5.0)-U XHP-7 XHP-8 XHP-9 XHP-10 XHP-11 XHP-12 XHP-13 XHP-14 XHP-15 XHP-16 XHP-20 5.7 C Q'ty / bag - 3.2 4.8 1,000 2.5 5.7 7.3 1,000 10.0 13.2 14.8 1,000 5.0 8.2 9.8 1,000 7.5 10.7 12.3 1,000 10.0 13.2 14.8 1,000 12.5 15.7 17.3 1,000 25.0 28.2 29.8 1,000 15.0 18.2 19.8 1,000 17.5 20.7 22.3 1,000 20.0 23.2 24.8 1,000 22.5 25.7 27.3 1,000 25.0 28.2 29.8 1,000 27.5 30.7 32.3 1,000 30.0 33.2 34.8 1,000 32.5 35.7 37.3 1,000 35.0 38.2 39.8 1,000 37.5 40.7 42.3 1,000 47.5 50.7 52.3 500 Material PA 6, UL94V-0, natural (white) Circuit No.1 mark RoHS compliance Note: 1. XHP-2(10.0)-U is 2 circuits 10.0mm pitch plugged up. Not UL/CSA/TU¨V approved. 2. XHP-6(5.0)-U is 6 circuits 5.0mm pitch plugged up. Not UL/CSA/TU¨V approved. A B C (6 circuits 5.0mm pitch) 7.75 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact ex. 4.1 5.7 Circuit No.1 mark XHP-1-oo(blank)…natural (white) BK…black R…red E…blue Y…yellow L…lemon yellow M…green D…orange N…brown FY…vivid yellow ex. A B XHP-2(10.0)-U-oo(blank)…natural (white) R…red E…blue C 2 TS S C0 18.0 1(X H ) XH CONNECTOR Through-hole type shrouded header The shrouded headers are interchangeable with those of the NR and NRD insulation displacement connectors, and JQ board-to-board connectors. Model No. Top entry type 0.64 Circuits 3.4 7 plugged up 2.45 A (2.35) B 5.75 Top entry type (3 circuits or more) (2 circuits) 0.64 3.4 3.4 7 7 0.64 2.45 A 5.75 B 2.5 A 2.45 (2.35) Top Entry Type S()B-XH-A:9.2 11.5 7 S()B-XH-A-1:7.6 0.64 S2B-XH-A Top Entry Side Entry Type Type B 2.5 7.4 1,000 10.0 14.9 1,000 – 5.0 9.9 1,000 1,000 S4B-XH-A 7.5 12.4 500 500 S5B-XH-A 10.0 14.9 500 500 S6B-XH-A-1 S6B-XH-A 12.5 17.4 500 500 B7B-XH-A S7B-XH-A-1 S7B-XH-A 15.0 19.9 500 250 8 B8B-XH-A S8B-XH-A-1 S8B-XH-A 17.5 22.4 250 250 9 B9B-XH-A S9B-XH-A-1 S9B-XH-A 20.0 24.9 250 250 10 B10B-XH-A S10B-XH-A-1 S10B-XH-A 22.5 27.4 250 250 11 B11B-XH-A S11B-XH-A-1 S11B-XH-A 25.0 29.9 250 250 12 B12B-XH-A S12B-XH-A-1 S12B-XH-A 27.5 32.4 250 200 13 B13B-XH-A S13B-XH-A-1 S13B-XH-A 30.0 34.9 250 200 14 B14B-XH-A S14B-XH-A-1 S14B-XH-A 32.5 37.4 250 200 15 B15B-XH-A S15B-XH-A-1 S15B-XH-A 35.0 39.9 250 100 16 B16B-XH-A - S16B-XH-A 37.5 42.4 200 100 20 B20B-XH-A - - 47.5 52.4 100 – B2B-XH-A 2 B2(10.0)B-XH-A-U - 3 B3B-XH-A S3B-XH-A-1 S3B-XH-A 4 B4B-XH-A S4B-XH-A-1 5 B5B-XH-A S5B-XH-A-1 6 B6B-XH-A 7 - 1,000 Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) RoHS compliance This product displays (LF)(SN) on a label. Note: B2(10.0)B-XH-A-U is 2 circuits 10.0mm pitch plugged up. ¨ V approved. Not UL/CSA/TU As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S3B-XH-A(-1)-oo 2.5 (6.1) S2B-XH-A-1 2 5.75 B A A (2.35) Side entry type 2.45 Q'ty / box Dimensions (mm) Side Entry Type (blank)…natural (white) BK…black R…red E…blue Y…yellow L…lemon yellow M…green D…orange N…brown FY…vivid yellow 3.4 B Through-hole type shrouded header Top entry type of glass-filled nylon 6.4 Circuits Model No. 2 B2B-XH-2 B3B-XH-2 B4B-XH-2 B5B-XH-2 B6B-XH-2 B7B-XH-2 B8B-XH-2 B9B-XH-2 B10B-XH-2 B11B-XH-2 B12B-XH-2 B13B-XH-2 B14B-XH-2 B15B-XH-2 7 (2 circuits) 3.4 3 2.45 4 5 5.75 A B 6 6.75 7 (3 to 8 circuits) 8 9 7 10 11 3.4 12 2.5 13 0.64 2.45 14 5.75 A 15 Dimensions (mm) A B Q'ty / bag 2.5 7.4 1,000 5.0 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 250 20.0 24.9 250 22.5 27.4 250 25.0 29.9 250 27.5 32.4 250 30.0 34.9 250 32.5 37.4 250 35.0 39.9 250 6.75 B Material and Finish (9 circuits or more) 7 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (ivory) 3.4 RoHS compliance This - product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-XH-2-oo 2.5 2.45 0.64 A B TS S C0 18.01(X H) 5.75 (blank)…natural (ivory) C…black R…red E…blue Y…yellow M…green 3 XH CONNECTOR Through-hole type shrouded header The shrouded headers are interchangeable with those of the NR and NRD insulation displacement connectors, and JQ board-to-board connectors. Circuits Top entry type with a boss 0.64 (1 circuit) 1 2 7 3 4 6 3.4 2.7 5 (2.35) 4.9 1.5 7 4.35 8 9 5.75 10 (2 circuits) 12 0.64 Model No. *B1B-XH-AM B2B-XH-AM B3B-XH-AM B4B-XH-AM B5B-XH-AM B6B-XH-AM B7B-XH-AM B8B-XH-AM B9B-XH-AM B10B-XH-AM B12B-XH-AM Dimensions (mm) A Q'ty / box B - - 1,000 2.5 7.4 1,000 5.0 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 250 20.0 24.9 250 22.5 27.4 250 27.5 32.4 250 Material and Finish 2.45 (2.35) 1.6 A RoHS compliance This product displays (LF)(SN) on a label. ¨ V approved. Note: *Marked product is not UL/CSA/TU 1 Ø 3.4 1.5 7 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) B As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 2 5.75 ex. B1B-XH-AM-oo(blank)…natural (white) BK…black R…red E…blue Y…yellow L…lemon yellow M…green 3.4 1.5 7 (3 circuits or more) 1 Ø 0.64 2.5 1.6 A 2.45 (2.35) 2 5.75 B SMT type shrouded header 0.64 Dimensions (mm) A B Q'ty / reel S3B-XH-SM4-TB 5.0 12.5 500 S4B-XH-SM4-TB 7.5 15.0 500 S6B-XH-SM4-TB 12.5 20.0 500 Circuits Model No. 3 4 6 5.5 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 6T, UL94V-0, natural (ivory) Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 2.5 3.75 RoHS compliance This product displays (LF)(SN) on a label. Note: The products listed above are supplied on embossed-tape. A B 7 (3) As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 6 ex. 4 S3B-XH-SM4-oo-TB(blank)…natural (ivory) M…green R…red E…blue L…lemon yellow TS S C0 18.0 1(X H ) XH CONNECTOR Through-hole type shrouded header on radial-tape TV4 type 2-TV4 type (3 to 4 circuits) 2-TV4 type (2 circuits) (3 to 8 circuits) B B A 6.75 A 2.45 2.5 2 3 4 5 6 7 8 7 7 6.75 ) 7 . 0 Ø ( Circuits 2.5 2.45 ) 7 . 0 Ø ( ) 7 . 0 Ø ( 0.64 2.8 0.64 6.75 Model No. TV4 2-TV4 B2B-XH-2-TV4 B3B-XH-TV4 B3B-XH-2-TV4 B4B-XH-TV4 B4B-XH-2-TV4 B5B-XH-2-TV4 B6B-XH-2-TV4 B7B-XH-2-TV4 B8B-XH-2-TV4 0.64 Dimensions (mm) B A RoHS compliance This product displays (LF)(SN) on a label. Q'ty / box - 1,000 5.0 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 500 - 2.8 2.5 7 2.45 7.4 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B2B-XH-2-TV4-oo(blank)…natural (TV4 type/white, 2-TV4 type/ivory) C…black (glass-filled) BK…black R…red E…blue Y…yellow M…green Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: TV4 type/ PA 66, UL94V-0, natural (white) 2-TV4 type/ Glass-filled PA 66, UL94V-0, natural (ivory) Taping specification Packaging specifications D 2 and 3 circuits:12.7 4 to 8 circuits:25.4 6.75 H 20 W 9 6 Distance between the end of the tape and the first connector's center line (either end) Leader tape 18 Tall tape Ø 2 circuits: 5.1 3 to 8 circuits: 3.85 4 2 circuits: 2.5 3 to 8 circuits: 5 12.7 Note: Conforms to JIC C 0806 of "Tape packaging of components with unidirectional leads on continuous tapes". Package type Distance between folds Box size Flat pack (zigzag folded) 24 indexing holes per fold (304.8mm) 316(W)X45(D)X330(H)mm Distance between the end of the tape and the first connector’s center line (either end) Quantity 2,3 circuits 4~8 circuits 19.05mm 1,000 pcs. / box 500 pcs. / box Note: Products of different packaging specifications are also available. Contact JST for details. TS S C0 18.01(X H) 5 XH CONNECTOR Unit for wire-to-wire connection Circuits 2 3 4 5 6 B 2.45 5.75 7 8 A 11 2.5 1.55 0.64 12 Model No. B2B-XH-TW B3B-XH-TW B4B-XH-TW B5B-XH-TW B6B-XH-TW B7B-XH-TW B8B-XH-TW B11B-XH-TW B12B-XH-TW Dimensions (mm) Q'ty / box A B 2.5 7.4 12,000 5.0 9.9 9,000 7.5 12.4 9,000 10.0 14.9 12,000 12.5 17.4 6,000 15.0 19.9 4,500 17.5 22.4 4,500 25.0 29.9 2,400 27.5 32.4 2,400 Material and Finish Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) 6 14 13.6 RoHS compliance This product displays (LF)(SN) on a label. TS S C0 18.0 1(X H )
S5B-XH-A 价格&库存
很抱歉,暂时无法提供与“S5B-XH-A”相匹配的价格&库存,您可以联系我们找货
S5B-XH-A
  • 1+2.215711+0.28601
  • 10+1.9117210+0.24677
  • 100+1.62347100+0.20956
  • 500+1.44852500+0.18698
  • 1000+1.379301000+0.17804
  • 5000+1.231145000+0.15892
  • 10000+1.1723710000+0.15133
库存:12256
S5B-XH-A
    • 500+0.93940
    库存:1020
    S5B-XH-A
      • 500+0.51700
      库存:2000
      S5B-XH-A
        • 500+0.59400
        库存:4887
