SM05B-GHS-TB (LF)(SN)
    JST
SM05B-GHS-TB (LF)(SN) 数据手册
Crimp 1.25mm GH CONNECTOR Emboss Tape Disconnectable Crimp style connectors (.049") pitch Features –––––––––––––––––––––––– • Secure locking structure This innovative housing lock design achieves a locking device which is easy to handle as well as secure. • Contact lock structure A contact lock provides a good "click feeling" when mated, which prevents improper mating during assembly. • Prevent deformation of contacts Fork-shaped header contacts are supported by grooves on the housing walls designed to prevent deformation of contacts. Developed for PDP, LCD or small electronics equipment. This low insertion type connector realizes easier mating operation. The basic concept of the contact part of this connector is equivalent to the performance proven SHL connector. Specifications ––––––––––––––––––– • Current rating: 1.0A AC, DC (AWG #26) • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/30m Ω max. After environmental testing/50m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: AWG #30 to #26 Insulation O.D./0.8 to 1.0mm (.031" to .039") * Contact JST if Lead-Free product is required. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 26 GH CONNECTOR Contact ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Applicable wire mm2 AWG# Model No. SSHL-002T-P0.2 0.05 to 0.13 Insulation O.D. Q'ty / reel mm(in.) 0.8 to 1.0(.031 to .039) 30 to 26 23,000 4.8(.189) Material and Finish 2.1(.083) 0.6(.024) 0.85(.033) 0.8(.031) 2.3(.091) Phosphor bronze, tin-plated 0.4(.016) Housing ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Circuits 2 3 4 4.15(.163) 5 6 7 5.7(.224) 8 9 10 11 12 2.65(.104) 1.25(.049) 13 A B 14 15 Dimensions mm(in.) A B Model No GHR-02V-S GHR-03V-S GHR-04V-S GHR-05V-S GHR-06V-S GHR-07V-S GHR-08V-S GHR-09V-S GHR-10V-S GHR-11V-S GHR-12V-S GHR-13V-S GHR-14V-S GHR-15V-S Q'ty / box 1.25(.049) 3.75(.148) 4,000 2.50(.098) 5.00(.197) 3,000 3.75(.148) 6.25(.246) 2,500 5.00(.197) 7.50(.295) 2,000 6.25(.246) 8.75(.344) 1,500 7.50(.295) 10.00(.394) 1,500 8.75(.344) 11.25(.443) 1,000 10.00(.394) 12.50(.492) 1,000 11.25(.443) 13.75(.541) 1,000 12.50(.492) 15.00(.591) 1,000 13.75(.541) 16.25(.640) 1,000 15.00(.591) 17.50(.689) 1,000 16.25(.640) 18.75(.738) 500 17.50(.689) 20.00(.787) 500 Material PBT, UL94V-0, natural Shrouded header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––– Top entry type Circuits 4.25(.167) 0.7(.028) 4.05(.159) 2 1.25(.049) 3 4 5 6 0.2(.008) 7 A B 8 9 10 11 Side entry type 4.05(.159) 0.8(.031) 12 4.25(.167) 13 1.25(.049) 0.2(.008) A B 1.75(.069) 14 15 Model No. Top entry type BM02B-GHS-TBT BM03B-GHS-TBT BM04B-GHS-TBT BM05B-GHS-TBT BM06B-GHS-TBT BM07B-GHS-TBT BM08B-GHS-TBT BM09B-GHS-TBT BM10B-GHS-TBT BM11B-GHS-TBT BM12B-GHS-TBT BM13B-GHS-TBT BM14B-GHS-TBT BM15B-GHS-TBT Side entry type SM02B-GHS-TB SM03B-GHS-TB SM04B-GHS-TB SM05B-GHS-TB SM06B-GHS-TB SM07B-GHS-TB SM08B-GHS-TB SM09B-GHS-TB SM10B-GHS-TB SM11B-GHS-TB SM12B-GHS-TB SM13B-GHS-TB SM14B-GHS-TB SM15B-GHS-TB Dimensions mm(in.) A B Q'ty / reel 1.25(.049) 5.75(.226) 2,500 2.50(.098) 7.00(.276) 2,500 3.75(.148) 8.25(.325) 2,500 5.00(.197) 9.50(.374) 2,500 6.25(.246) 10.75(.423) 2,500 7.50(.295) 12.00(.472) 2,500 8.75(.344) 13.25(.522) 2,500 10.00(.394) 14.50(.571) 2,500 11.25(.443) 15.75(.620) 2,500 12.50(.492) 17.00(.669) 2,500 13.75(.541) 18.25(.719) 2,500 15.00(.591) 19.50(.768) 2,500 16.25(.640) 20.75(.817) 2,500 17.50(.689) 22.00(.866) 2,500 Material and Finish Contact: Phosphor bronze, copper-undercoated, tin-plated Housing: PA9T, UL94V-0, natural Solder tab: Brass, copper-undercoated, tin-plated 27 GH CONNECTOR Taping specifications –––––––––––––––––––––––––––––––––––––––––––––––––––––– Feeding direction Feeding direction 380±2.0(14.961±.079)dia. Carrier tape 2.5 +.098 ( -.039 ) W1+-1.0 Cover tape leader Leader part 100(3.937)min. The end part Connector 160(6.299)min. mounting part 400(15.748)min. 2.0±0.5(.079±.020) [13(.512)dia.] (10 to 15 circuits) 1.55±0.05 4.0±0.1 2.0±0.1 (.061±.002)dia. (.157±.004) (.079±.004) Cover tape 8.0±0.1 (.315±.004) W±0.3(.012) F±0.1(.004) S±0.1(.004) Cover tape W±0.3(.012) F±0.1(.004) 1.75(.069) Feeding direction 1.55±0.05 4.0±0.1 2.0±0.1 (.061±.002)dia. (.157±.004) (.079±.004) Feeding direction 1.75(.069) Top entry type (2 to 9 circuits) Carrier tape 8.0±0.1(.315±.004) Side entry type (2 to 11 circuits) Carrier tape (12 to 15 circuits) 8.0±0.1 (.315±.004) W±0.3(.012) F±0.1(.004) Cover tape S±0.1(.004) F±0.1(.004) 1.75(.069) Cover tape W±0.3(.012) 1.55±0.05 4.0±0.1 2.0±0.1 (.061±.002)dia. (.157±.004) (.079±.004) 1.55±0.05 4.0±0.1 2.0±0.1 (.061±.002)dia. (.157±.004) (.079±.004) 1.75(.069) Feeding direction Feeding direction Carrier tape 8.0±0.1 (.315±.004) Top entry type Side entry type Dimensions mm(in.) Circuits F Carrier tape Reel dimensions Q'ty / mm(in.) reel W1 Dimensions mm(in.) Circuits Reel dimensions Q'ty / mm(in.) reel W1 S W S W 2 7.5(.295) - 16.0( .630) 17.5( .689) 2,500 2 to 5 7.5(.295) - 16.0( .630) 17.5( .689) 2,500 3 to 9 11.5(.453) - 24.0( .945) 25.5(1.004) 2,500 6 to 11 11.5(.453) - 24.0( .945) 25.5(1.004) 2,500 10 to 12 14.2(.559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 2,500 12 to 15 14.2(.559) 28.4(1.118) 32.0(1.260) 33.5(1.319) 2,500 13 to 15 20.2(.795) 40.4(1.591) 44.0(1.732) 45.5(1.791) 2,500 F Note: 1. Specifications conform to JIS C 0806. The tape width, connector loading recess square hole dimensions, etc. are determined by the number of circuits and external shape of the connector to be loaded. 2. Specifications are subject to change without prior notice. 28 GH CONNECTOR PC board layout (viewed from component side) and Assembly layout –––––––––––––––––– Top entry type 0.6±0.05 (.024±.002) Side entry type 1.25±0.05 (.049±.002) 0.6±0.05 (.024±.002) 4.25(.167) 1.25±0.05 (.049±.002) 7.15(.281) 0.25±0.1(.010±.004) 4.35(.171) 2.7±0.1(.106±.004) 3.7±0.1(.146±.004) 7.3(.287) 2.8±0.1(.110±.004) 3.9±0.1(.154±.004) 5.6±0.1(.220±.004) 1.35±0.1(.053±.004) 0.3±0.1(.012±.004) 1.35±0.1(.053±.004) 1.0±0.1(.039±.004) 5.4±0.1(.213±.004) Header outline Header outline 1.0±0.1(.039±.004) Note: 1. Tolerances are non-cumulative: ±0.05mm (±.002") for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. Applicator for the semi-automatic press AP-K2N ––––––––––––––––––––––––––––––– Contact SSHL-002T-P0.2 Crimp applicator MKS-L-10-3 with safety cover without safety cover APLMK SSHL002-02 APLNC SSHL002-02 Compact crimp applicator MKS-LS with safety cover without safety cover – – Strip-crimp applicator MKS-SC with safety cover – 29
SM05B-GHS-TB (LF)(SN) 价格&库存
很抱歉,暂时无法提供与“SM05B-GHS-TB (LF)(SN)”相匹配的价格&库存,您可以联系我们找货
