SMM-114-02-S-S-TR
SMM-114-02-S-S-TR
    SAMTEC(申泰)
    2MM SOCKET STRIPS
SMM-114-02-S-S-TR 数据手册
F-215 SMM–135–02–L–D–K SMM–108–02–L–S SMM–115–02–S–D ™ SMM–110–02–L–S SYSTEM (2,00 mm) .0787" SMM SERIES ™ TIGER EYE SOCKET STRIP SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SMM Available with optional Pick & Place Pads Mates with: TMM, TMMH, MTMM, MMT, LTMM, TW, TCMD, PTT, ZLTMM Insulator Material: Black Liquid Crystal Polymer Contact Material: BeCu Plating: Sn or Au over 50µ" (1,27 µm) Ni Current Rating (TMM/SMM): 3.2 A per pin (1 pin powered per row) Voltage Rating: 350 VAC Operating Temp Range: -55°C to +125°C Contact Resistance: 10 mΩ Insertion Depth: (3,05 mm) .120" to (3,25 mm) .128" Insertion Force: (Single contact only) 2.0 oz (0,56 N) average Withdrawal Force: (Single contact only) 1.5 oz (0,42 N) average Max Cycles: 100 with 10µ" (0,25 µm) Au RoHS Compliant: Yes High reliability Tiger Eye™ contacts (Four point redundancy) ™ (3,56 mm) .140" (2,00 mm) .0787" pitch SMM 1 NO. PINS PER ROW PLATING OPTION 02 ROW OPTION OTHER OPTION Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max –F = Gold flash on contact, Matte Tin on tail 02 thru 40 RECOGNITIONS –L For complete scope of recognitions see www.samtec.com/quality = 10µ" (0,25 µm) Gold on contact, Matte Tin on tail No. of positions x (2,00) .0787 (2,00) .0787 (MOQ Required) • Locking clip (Manual placement required) • Other platings Contact Samtec. 01 = 30µ" (0,76 µm) Gold on contact, Matte Tin on tail (2,00) .0787 –S Row (3,81) .150 x (7,62) .300 –D Row (5,71) .225 x (10,01) .394 80 (2,00) (4,00) .0787 .158 –K = (5,50 mm) .217" DIA Polyimide Film Pick & Place Pad (2 positions minimum, –02 thru –05 requires –TR) –P –TR 79 –P 01 (3,56) .140 Note: Some lengths, styles and options are non-standard, non-returnable. –“XX” = Polarized Position = Plastic Pick & Place Pad (–02 thru –05 requires –TR) 02 POLARIZING KEY Specify PK–01–07 for polarizing key (Available in wheels of six each). Also polarizes TCSD Series IDC Cable. –D = Double Row –S 40 ALSO AVAILABLE –S = Single Row (0,51) .020 (4,32) .170 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (6,30) .248 = Tape & Reel Packaging (27 positions maximum)
SMM-114-02-S-S-TR 价格&库存
很抱歉,暂时无法提供与“SMM-114-02-S-S-TR”相匹配的价格&库存,您可以联系我们找货
