USB-A-S-S-W-VU-RC
USB-A-S-S-W-VU-RC
    SAMTEC(申泰)
    USB
USB-A-S-S-W-VU-RC 数据手册
F-224 SUPPLEMENT STANDARD & RUGGED USB 2.0 USB-A/USBR-A/USB-AM SERIES SPECIFICATIONS Insulator Material: High Temperature Thermoplastic Contact Material: Phosphor Bronze Plating: Gold on Contacts, Nickel on Shell, Tin on Tails Operating Temp Range: -50 °C to +85 °C Voltage Rating: 30 VAC Cycles: 1500 (max tested) Packaging: Packaged and shipped in Bulk Packaging Trays; Trays suitable for automation available Lead–Free Solderable: –TH & –VU=Yes (Wave Solder only) TID Numbers (USB-A): USB-A-D-X-X-TH (61001199) USB-A-S-X-X-TH (61001180) USB-A-S-X-X-SM2 (61001152) TID Number (USB-AM): USB-AM-S-X-X-SM (61001154) - SERIES A - - SHELL TYPE USB –S = Standard Connector USBR COLOR –F = Single = Double (–TH option only) –SM2 –W = Surface Mount (USB only) –VU –O = Upright, Through-hole = Orange (USBR only) (12.50) .492 (5.72) .225 (5.12) .202 (6.90) .272 = Through-hole = White (USB only) = 30 µ" (0.76 µm) Gold on Mating Area, Tin on Tails —SM2 TERMINATION –TH = Black (USB only) –S (16.40) .646 - –B = Gold Flash on Mating Area, Tin on Tails –D = Increased Retention Connector (Complies with Class 1, DIV II minimum withdrawal requirement of 15N.) - PLATING (6.90) .272 —TH (12.50) .492 (19.20) .756 (5.12) .202 (14.40) .567 (13.62) .536 (14.50) .571 (15.49) .610 (5.12) .202 (7.10) .280 —VU —D (Requires —TH) View complete specifications at: samtec.com?USB-A or samtec.com?USBR-A USB - TYPE - –AM SHELL TYPE - –S = A Type (Plug) = Single - PLATING COLOR –F –B = Gold Flash on Mating Area, Tin on Tails = Black –W = White –S = 30 µ" (0.76 µm) Gold on Mating Area, Tin on Tails (18.70) .736 - TERMINATION –TH = Through-hole –SM1 = Surface Mount (18.80) .740 (4.52) .178 (4.50) .177 (14.70) .579 (14.60) .575 (12.00) .472 (12.00) .472 (12.00) .472 (12.50) .492 —TH —SM1 View complete specifications at: samtec.com?USB-AM WWW.SAMTEC.COM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
USB-A-S-S-W-VU-RC 价格&库存
很抱歉,暂时无法提供与“USB-A-S-S-W-VU-RC”相匹配的价格&库存,您可以联系我们找货
