ZW-20-19-G-T-1000-180
    SAMTEC(申泰)
    CONN BRD STACK .100" 60POS
ZW-20-19-G-T-1000-180 数据手册
ZW–06–13–L–D–787–118 F-218 (Rev 10OCT17) DW–11–20–T–D–825 HW–14–08–G–S–300–100 (2.54 mm) .100" DW, EW, ZW, HW-TH SERIES FLEXIBLE .025" SQ BOARD STACKERS Mates with: SSW, SSQ, ESW, ESQ, CES, SLW, BSW, BCS, SSM, HLE, PHF TYPE STRIP LEAD STYLE NO. PINS PER ROW PLATING OPTION Cable Mates: IDSS, IDSD, SMSD, SMSS DW SPECIFICATIONS Specify LEAD STYLE from chart = (2.79 mm) .110" Tail For complete specifications see www.samtec.com?DW, www.samtec.com?EW, www.samtec.com?ZW or www.samtec.com?HW-TH Insulator Material: DW, EW, ZW: Black Glass Filled Polyester HW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin RoHS Compliant: Yes Lead–Free Solderable: DW, EW, ZW: No, Lead Wave Only HW: Yes POST (0.00).000 MIN (2.79) .110 OVERALL LENGTH EW (OAL) STACKER HEIGHT = (8.38 mm) .330" Tail TAIL (1.40) .055 MIN LEAD STYLE OAL – 07 (10.92) .430 – 08 (13.46) .530 – 09 (18.54) .730 –10 (21.08) .830 –11 (23.62) .930 –12 (26.16) 1.030 –13 (31.24) 1.230 –14 (36.32) 1.430 –15 (16.00) .630 –16 (11.30) .445 –17 (12.19) .480 –19 (33.78) 1.330 –20 (28.70) 1.130 ROW OPTION STACKER HEIGHT OTHER OPTIONS –S –“XXX” –“XXX” Example: –250 = (6.35 mm) .250" Example: –250 = (6.35 mm) .250" = Single Row –D = Double Row –T = Triple Row –Q For complete scope of recognitions see www.samtec.com/quality –LL ZW = Gold flash on contact, Matte Tin on tail = Custom Tail FILE NO. E111594 50 02 TAIL LENGTH Notes: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. This Series is non-standard, non-returnable. HW = High Temp Custom Tail (2.54) .100 x No. of Positions –L 01 (2.54) .100 –S (2.54) .100 –D 100 (5.08) .200 ALSO AVAILABLE • Other platings Contact Samtec. ZW or HW TAIL LENGTH (1.40) .055 MIN –F 01 thru 50 01 99 03 150 (7.52) .296 (5.08) .200 01 –T or –Q* = 10 µ" (0.25 µm) Gold on contact area of longer tail, Matte Tin on tail (2.54) .100 –G = 10 µ" (0.25 µm) Gold on contact area of longer tail, Gold flash on balance –Q* 148 = Same as -T except middle row of pins missing. –T = Matte Tin (2.54) .100 TAIL LENGTH (0.64) .025 SQ TYP Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM = ZW or HW Tail Length (in inches) (1.40 mm) .055" minimum STACKER HEIGHT (5.08) .200 MIN = Double Row .200" (5.08 mm) row space (8.38) .330 RECOGNITIONS (MOQ Required) = Stacker Height (in inches) (5.08 mm) .200" minimum All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. = Locking Lead (Shortest dimension between the tail and the post is the end that will be crimped. Available on tails from (2.29 mm) .090" to (7.87 mm) .310" only.) Single row, 01 & 02 positions & –Q row not available –“XXX” = Polarized Specify omitted pin position
ZW-20-19-G-T-1000-180 价格&库存
很抱歉,暂时无法提供与“ZW-20-19-G-T-1000-180”相匹配的价格&库存,您可以联系我们找货
  • 1+93.295931+12.06570
  • 25+93.2101025+12.05460
  • 50+88.5753550+11.45520
  • 100+80.33578100+10.38960
  • 250+79.04835250+10.22310
  • 500+71.75290500+9.27960
  • 1000+64.199961000+8.30280
