Coding of inserts in hoods/housings
Identification
Part number
Coding system with code pins
Drawing
Dimensions in mm
for hoods/housings with one insert/one frame
standard
09 30 000 99011)
for hoods/housings with tho inserts/two frames
Han-Modular®
09 14 000 99011)
Code pin
+ Normal mounting screw
Coding system with guide pins/
bushes
M - Male insert
F - Female insert
This system is used to guard against angled coupling and decoupling of
the connector. The maximum permitted angle according to DIN EN
175 301-801 is ± 5° (longitudinally).
standard
Guide pin2)
09 33 000 99081)
Guide bushing2)
09 33 000
99091)
Han-Modular®
Guide pin
09 14 000 99081)
Guide bushing
09 14 000 99091)
● Guide pin
○ Bush
Coding pins
Accessories
95
08
for Han E®, Han® EE, Han® Q 5/0,
Han® Q 8/0
for Han D®, Han DD®
with loss of contact
1)
2)
Order 4 pieces for one connector
for application "insert in hood/housing"
M - Male insert
F - Female insert
Use of the coding pin prevents incorrect mating to other connectors of
the same type. The male pin should be omitted from the opposing cavity
in the male insert.
09 33 000 9954
09 33 000 9915
Stock items in bold type
很抱歉,暂时无法提供与“09 33 000 9909”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.920681+1.41288
- 国内价格
- 50+6.17749
- 100+6.02233
- 200+5.93068
