282-101
282-101
    WAGO(万可电子)
    端子块连接器 2 位置 馈通式 灰色 10-24AWG
282-101 数据手册
Data sheet  |  Item number: 282-101 2-conductor through terminal block; 6 mm²; lateral marker slots; for DIN-rail 35 x 15 and 35 x 7.5; CAGE CLAMP®; 6,00 mm²; gray www.wago.com/282-101 Color: Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 1/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Data Electrical data Ratings per IEC/EN 60664-1 Rated voltage (III / 3) 800 V Rated impulse voltage (III / 3) 8 kV Rated current 41 A Legend (ratings) (III / 3) ≙ Overvoltage category III / Pollution degree 3 Connection data Connection technology CAGE CLAMP® Actuation type Operating tool Connectable conductor materials Copper Solid conductor 0.2 … 6 mm² / 24 … 10 AWG Fine-stranded conductor 0.2 … 6 mm² / 24 … 10 AWG Strip length 12 … 13 mm / 0.47 … 0.51 inch Total number of connection points 2 Total number of potentials 1 Number of levels 1 Type of wiring Side-entry wiring Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 2/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Geometrical Data Width 8 mm / 0.315 inch Height from upper-edge of DIN-35 rail 37 mm / 1.457 inch Depth 46.5 mm / 1.831 inch Mechanical data Design horizontal Type of mounting DIN-35 rail Marking level Side marking Material Data Color gray Insulating material Polyamide 66 (PA 66) Fire load 0.185 MJ Weight 11.4 g Commercial data Packaging type BOX Country of origin DE GTIN 4044918511070 Customs Tariff No. 85369010000 Approvals / Certificates Country specific Approvals Logo Certificate name Approval Additional Approval Text CCA DEKRA Certification B.V. EN 60947 NTR NL7522 CCA DEKRA Certification B.V. EN 60947 2195540.01 Ship Approvals Certificate Logo Approval Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Additional Approval Text name Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 3/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Logo Approval Additional Approval Text name ABS American Bureau of Shipping EN 60947 14HG1293677PDA BV Bureau Veritas S.A. EN 60947 07436/E0 BV DNV GL Det Norske Veritas, Germanischer Lloyd - TAE00001V2 LR Lloyds Register EN 60947 91/20112 (E9) UL-Approvals Logo Approval Additional Approval Text UL UL International Germany GmbH UL 1059 Certificate name 20190731E45172 Compatible products General accessories Item no.: 209-143 Group marker carrier www.wago.com/209-143 Item no.: 209-144 Group marker carrier www.wago.com/209-144 Item no.: 709-310 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com www.wago.com/709-310 Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 4/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Item no.: 709-310 www.wago.com/709-310 B-type test plug module; modular; suitable for all WAGO 282 Series rail-mounted terminal blocks with jumper slots; 6,00 mm²; gray Item no.: 709-311 B-type spacer module; modular; e.g., for bridging commoned terminal blocks; gray www.wago.com/709-311 Item no.: 216-262 Ferrule; Sleeve for 0.75 mm² / 18 AWG; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-262 Item no.: 216-263 Ferrule; Sleeve for 1 mm² / AWG 18; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; red www.wago.com/216-263 Item no.: 216-264 Ferrule; Sleeve for 1.5 mm² / AWG 16; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; black www.wago.com/216-264 Item no.: 216-266 Ferrule; Sleeve for 2.5 mm² / AWG 14; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; blue www.wago.com/216-266 Item no.: 216-267 Ferrule; Sleeve for 4 mm² / AWG 12; insulated; electro-tin plated; electrolytic copper; gastight crimped; acc. to DIN 46228, Part 4/09.90; gray www.wago.com/216-267 Item no.: 210-112 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 25 mm www.wago.com/210-112 Item no.: 210-113 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-113 Item no.: 210-114 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; similar to EN 60715 www.wago.com/210-114 Item no.: 210-115 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; according to EN 60715; "Hole width 18 mm www.wago.com/210-115 Item no.: 210-118 Steel carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715 www.wago.com/210-118 Item no.: 210-196 Aluminum carrier rail; 35 x 8.2 mm; 1.6 mm thick; 2 m long; unslotted; similar to EN 60715; silvercolored www.wago.com/210-196 Item no.: 210-197 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; similar to EN 60715 www.wago.com/210-197 Item no.: 210-198 Copper carrier rail; 35 x 15 mm; 2.3 mm thick; 2 m long; unslotted; according to EN 60715; coppercolored www.wago.com/210-198 Item no.: 210-504 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; slotted; galvanized; according to EN 60715 www.wago.com/210-504 ferrule Carrier rail Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 5/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Item no.: 210-505 Steel carrier rail; 35 x 7.5 mm; 1 mm thick; 2 m long; unslotted; galvanized; according to EN 60715 www.wago.com/210-505 Item no.: 210-506 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; unslotted; galvanized; similar to EN 60715 www.wago.com/210-506 Item no.: 210-508 Steel carrier rail; 35 x 15 mm; 1.5 mm thick; 2 m long; slotted; galvanized; similar to EN 60715 www.wago.com/210-508 Marking accessories Item no.: 2009-115 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; white www.wago.com/2009-115 Item no.: 2009-115/000-002 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; yellow www.wago.com/2009-115 /000-002 Item no.: 2009-115/000-006 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/2009-115 /000-006 Item no.: 2009-115/000-007 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/2009-115 /000-007 Item no.: 2009-115/000-012 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/2009-115 /000-012 Item no.: 2009-115/000-017 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/2009-115 /000-017 Item no.: 2009-115/000-023 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/2009-115 /000-023 Item no.: 2009-115/000-024 WMB-Inline; for Smart Printer; on reel; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/2009-115 /000-024 Item no.: 249-105 Group marker carrier www.wago.com/249-105 Item no.: 793-501 WMB marking card; as card; not stretchable; plain; snap-on type; white www.wago.com/793-501 Item no.: 793-501/000-002 WMB marking card; as card; not stretchable; plain; snap-on type; yellow www.wago.com/793-501 /000-002 Item no.: 793-501/000-005 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 6/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Item no.: 793-501/000-005 WMB marking card; as card; not stretchable; plain; snap-on type; red www.wago.com/793-501 /000-005 Item no.: 793-501/000-006 WMB marking card; as card; not stretchable; plain; snap-on type; blue www.wago.com/793-501 /000-006 Item no.: 793-501/000-007 WMB marking card; as card; not stretchable; plain; snap-on type; gray www.wago.com/793-501 /000-007 Item no.: 793-501/000-012 WMB marking card; as card; not stretchable; plain; snap-on type; orange www.wago.com/793-501 /000-012 Item no.: 793-501/000-017 WMB marking card; as card; not stretchable; plain; snap-on type; light green www.wago.com/793-501 /000-017 Item no.: 793-501/000-023 WMB marking card; as card; not stretchable; plain; snap-on type; green www.wago.com/793-501 /000-023 Item no.: 793-501/000-024 WMB marking card; as card; not stretchable; plain; snap-on type; violet www.wago.com/793-501 /000-024 Item no.: 793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap- www.wago.com/793-5501 on type; white Item no.: 793-5501/000-002 www.wago.com/793-5501 WMB marking card; as card; for terminal block width 5 - 17.5 mm; stretchable 5 - 5.2 mm; plain; snap/000-002 on type; yellow Item no.: 793-5501/000-005 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; red www.wago.com/793-5501 /000-005 Item no.: 793-5501/000-006 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; blue www.wago.com/793-5501 /000-006 Item no.: 793-5501/000-007 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; gray www.wago.com/793-5501 /000-007 Item no.: 793-5501/000-012 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; orange www.wago.com/793-5501 /000-012 Item no.: 793-5501/000-014 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 7/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Item no.: 793-5501/000-014 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; brown www.wago.com/793-5501 /000-014 Item no.: 793-5501/000-017 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; light green www.wago.com/793-5501 /000-017 Item no.: 793-5501/000-023 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; green www.wago.com/793-5501 /000-023 Item no.: 793-5501/000-024 WMB marking card; as card; stretchable 5 - 5.2 mm; plain; snap-on type; violet www.wago.com/793-5501 /000-024 Item no.: 210-103 Wire commoning chain; insulated; 50 connections; black www.wago.com/210-103 Item no.: 210-123 Wire commoning chain; insulated; 50 connections www.wago.com/210-123 Item no.: 282-402 Adjacent jumper; insulated; Nominal current 41 A www.wago.com/282-402 Item no.: 282-409 Alternate jumper; insulated; Nominal current 41 A; gray www.wago.com/282-409 Item no.: 282-422 Adjacent jumper; insulated; Nominal current 41 A; yellow-green www.wago.com/282-422 Item no.: 282-424 Adjacent jumper; insulated; Nominal current 41 A; orange www.wago.com/282-424 Item no.: 284-413 Step-down jumper; insulated; from 10/6 mm² to 6/4 mm²; Nominal current 30 A; gray www.wago.com/284-413 Item no.: 284-414 Step-down jumper; insulated; from 10/6 mm² to 4/2.5/1.5 mm²; Nominal current 15 A; gray www.wago.com/284-414 Item no.: 709-110 Wire commoning chain; insulated; 4 connections; 3 x 110 mm; black www.wago.com/709-110 Item no.: 709-111 Wire commoning chain; insulated; 3 connections; 2 x 120 mm; black www.wago.com/709-111 Item no.: 709-112 Wire commoning chain; insulated; 3 connections; 2 x 170 mm; black www.wago.com/709-112 Item no.: 282-301 End and intermediate plate; 4 mm thick; gray www.wago.com/282-301 Jumper End plate Item no.: 282-302 Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 8/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Item no.: 282-302 End and intermediate plate; 4 mm thick; orange www.wago.com/282-302 Item no.: 282-322 Separator plate; 2 mm thick; oversized; orange www.wago.com/282-322 Item no.: 282-332 Separator plate; 2 mm thick; oversized; gray www.wago.com/282-332 Item no.: 284-333 Step-down cover plate; 1 mm thick; gray www.wago.com/284-333 Item no.: 284-343 Step-down cover plate; 1 mm thick; orange www.wago.com/284-343 Protective Warning Marker Item no.: 282-405 Protective warning marker; with high-voltage symbol, black; for 5 terminal blocks; yellow www.wago.com/282-405 Item no.: 209-106 Mounting carrier; for isolated mounting on DIN 35 rails; gray www.wago.com/209-106 Item no.: 709-153 Cover; Type 1; suitable for cover carrier, type 1; 1 m long; transparent www.wago.com/709-153 Item no.: 210-721 Operating tool; Blade: 5.5 x 0.8 mm; with a partially insulated shaft www.wago.com/210-721 Item no.: 209-170 Test plug adapter; 8.3 mm wide; for 4 mm Ø test plugs; suitable for 1.5 mm² - 10 mm² tbs; gray www.wago.com/209-170 assembling tools check Downloads Documentation Bid Text 282-101 Feb 19, 2019 xml 3.3 kB Download Jun 12, 2017 doc 24.6 kB Download Apr 3, 2019 pdf 2.1 MB Download X81 - Datei 282-101 doc - Datei Additional Information Technical explanations Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 9/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 CAD/CAE-Data CAD data 2D/3D Models 282-101 URL Download CAE data EPLAN Data Portal 282-101 Download WSCAD Universe 282-101 Download Installation Notes Snapping side-entry rail-mount terminal blocks onto the carrier rail. Quick assembly keys prevent reverse mounting. Removing a terminal block from the assembly. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 10/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 CAGE CLAMP® connection Inserting a conductor. With ferruled conductors, it is necessary to use a terminal block one size larger than the conductor’s nominal cross-section. Commoning using an adjacent jumper (280‑402). Push jumper down until fully inserted. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 11/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 Commoning side-entry rail-mount terminal blocks via step-down jumpers. Commoning from 6 mm²/10 AWG (282 Series) to 1.5 mm²/16 AWG (279 Series) railmount terminal blocks via step-down jumpers. Step down jumper down until fully inserted. Testing with a test plug (picture shows 209‑170 Test Plug Adapter). Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 12/13 Data sheet  |  Item number: 282-101 www.wago.com/282-101 When operating the handles beyond the locked position, the ratchet allows the tool to open and be removed from the terminal block. Labeling via WMB Multi Marking System. Subject to changes. WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 29.12.2019    Page 13/13
282-101 价格&库存
很抱歉,暂时无法提供与“282-101”相匹配的价格&库存,您可以联系我们找货
  • 1+66.098471+8.55576
    • 50+9.00610
    库存:4000
