31FXZ-RSM1-G-ETF(LF)(SN)
    JST
    FXZ Series 31 Circuit 0.3 mm Pitch One Touch Operational FPC Connector
31FXZ-RSM1-G-ETF(LF)(SN) 数据手册
0.3mmピッチ FXZ CONNECTOR Emboss Tape 0.3mm pitch/Connectors for FPC Specifications ––––––––––––––––––– • Current rating: 0.2A AC, DC • Voltage rating: 50V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/60m Ω max. After environmental testing/60m Ω max. (variation from initial value) • Insulation resistance: 50M Ω min. • Withstanding voltage: 200V AC/minute • Applicable FPC: Conductor pitch/0.3mm Conductor width/0.3mm Mating part thickness/0.2±0.03mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. This connector realizes space saving and low profile features demanded by the market, and it provides excellent operability. Various number of circuits can be available. • Double ZIF design for easy insertion operation of FPC • Self-lock mechanism enables the cover to close by 'one-touch' operation • Versatile number of circuit PC board layout (viewed from component side) and Assembly layout 0.3±0.05 Circuit No.2 0.8±0.05 A±0.05 0.6±0.03 4.35±0.05 0.3±0.05 0.5±0.05 B±0.05 0.2 0.95±0.05 1.2±0.05 0.6±0.03 Circuit No.1 C±0.05 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. The dimensions above should serve as a guideline. Contact JST for details. 1 1.4 3.95 0.3±0.03 FXZ CONNECTOR Connector A 1.5 0.6 1.2 B D B C D Q'ty / reel 15FXZ-RSM1-GAN-ETF 3.6 4.2 5.8 6.6 2,500 17FXZ-RSM1-GAN-ETF 4.2 4.8 6.4 7.2 2,500 23 23FXZ-RSM1-GAN-ETF 6.0 6.6 8.2 9.0 2,500 25 25FXZ-RSM1-GAN-ETF 6.6 7.2 8.8 9.6 2,500 29 29FXZ-RSM1-GAN-ETF 7.8 8.4 10.0 10.8 2,500 31 31FXZ-RSM1-GAN-ETF 8.4 9.0 10.6 11.4 2,500 35 35FXZ-RSM1-GAN-ETF 9.6 10.2 11.8 12.6 2,500 39 39FXZ-RSM1-GAN-ETF 10.8 11.4 13.0 13.8 2,500 51 51FXZ-RSM1-GAN-ETF 14.4 15.0 16.6 17.4 2,500 53 53FXZ-RSM1-GAN-ETF 15.0 15.6 17.2 18.0 2,500 61 61FXZ-RSM1-GAN-ETF 17.4 18.0 19.6 20.4 2,500 73 73FXZ-RSM1-GAN-ETF 21.0 21.6 23.2 24.0 2,500 Model No. 15 17 1.4 3.95 Dimensions (mm) A Circuits Material and Finish 0.3 Contact: Copper alloy, nickel-undercoated, gold-plated (nickel-stripe) Housing: Heat resisting resin, UL94V-0 Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Cover: Heat resisting resin, UL94V-0 C RoHS compliance This product displays (LF)(SN) on a label. Note: 1. This products listed above are supplied on embossed-tape. 2. Contact JST for tin-plated products. Lead section dimensions of FPC 0.3(N+1)±0.05 0.3(N−1)±0.03 0.3±0.07 0.3±0.07 0.3(N−3)±0.03 0.04 0.3−+0.03 3.6±0.5 0.2±0.03 2.6min 0.6±0.02 Reinforcing layer Note: N --- Number of circuits 2
31FXZ-RSM1-G-ETF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“31FXZ-RSM1-G-ETF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
