873-902/VE00-5000
873-902/VE00-5000
    WAGO(万可电子)
    2 Pole Push Wire Connector for Luminaire Disconnect
873-902/VE00-5000 数据手册
Data sheet  |  Item number: 873-902 Luminaire disconnect connector; 2-pole; 4,00 mm²; yellow www.wago.com/873-902 Color: Data Electrical data Ratings per IEC/EN 60664-1 Ratings per EN 60998 Nominal voltage (II/2) 400 V Rated surge voltage (II/2) 4 kV Rated current 6  A Ratings per EN 61984 Connection data Connection type (1) Plug Connection technology PUSH WIRE® Actuation type Push-in Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 1/4 Data sheet  |  Item number: 873-902 www.wago.com/873-902 Actuation type Push-in Connectable conductor materials Copper Solid conductor 0,75 … 4 mm² / 18 … 12 AWG Stranded conductor 1,5 … 2,5 mm² / 16 … 12 AWG Strip length 11 … 13 mm / 0.43 … 0.51 inch Pole No. 2 Connection type 2 Socket Solid conductor 2 0,75 mm² / 18 AWG Strip length 2 9 … 11 mm / 0.35 … 0.43 inch Total number of connection points 6 Total number of potentials 2 Geometrical Data Width 13 mm / 0.512 inch Height 13,2 mm / 0.52 inch Depth 42 mm / 1.654 inch Material Data Color yellow Fire load 0.103 MJ Weight 4.8 g Commercial data Product Group 8 (Misc. Chassis Mount Blocks) Packaging type BOX Country of origin CN GTIN 4045454548421 Customs tariff number 85366990990 Approvals / Certificates Country specific Approvals Logo Approval Additional Approval Text Certificate name CCA DEKRA Certification B.V. EN 61984 2178521.01 CCA EN 61984 Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com NTR NL- Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 2/4 Data sheet  |  Item number: 873-902 www.wago.com/873-902 CCA DEKRA Certification B.V. EN 61984 NTR NL7390 CCA DEKRA Certification B.V. EN 60998 NTR NL7391 CCA DEKRA Certification B.V. EN 60998 2178521.02 CSA DEKRA Certification B.V. C22.2 No. 182.3 154112 (LR 18677) Approval Additional Approval Text Certificate name UL UL International Germany GmbH UL 2459 E313353 UL-Approvals Logo Counterpart Downloads Documentation Bid Text 873-902 Feb 19, 2019 xml 3.2 kB Download Feb 21, 2019 docx 15.1 kB Download Apr 3, 2019 pdf 2.1 MB Download GAEB X81 - Datei 873-902 GAEB docx - Datei Additional Information Technical explanations CAD/CAE-Data Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 3/4 Data sheet  |  Item number: 873-902 www.wago.com/873-902 CAD/CAE-Data CAD data 2D/3D Models 873-902 URL Download Handling Instructions Subject to changes. Please also observe the further product documentation! WAGO Kontakttechnik GmbH & Co. KG Hansastr. 27 32423 Minden Phone: +49571 887-0 | Fax: +49571 887-169 Email: info.de@wago.com | Web: www.wago.com Do you have any questions about our products? We are always happy to take your call at +49 (571) 887-44222. 22.05.2020    Page 4/4
873-902/VE00-5000 价格&库存
很抱歉,暂时无法提供与“873-902/VE00-5000”相匹配的价格&库存,您可以联系我们找货
873-902/VE00-5000
  • 1+17.176191+2.22637
  • 10+14.5736810+1.88903
  • 25+13.6634325+1.77104
  • 50+13.0098250+1.68632
  • 100+12.38731100+1.60563
  • 250+11.61119250+1.50504
  • 500+11.05693500+1.43319
  • 1000+10.529121000+1.36478
  • 2500+9.870292500+1.27938
库存:1228
