0.25mm pitch, 1.1mm high, Top Contact Single Action Lock, High FPC Retention Force FPC connector
FH62 Series
Dimension diagram : 35 pos.
11.9
6mm
(35 p
os.)
Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1.1mm
4.0mm
0.9mm (width)
0.5mm (guide)
Fig.1
Single action lock
[Before mating]
■Features
1.Space-saving design
・Space saving design with 0.25mm pitch, 4.0mm width.
(Fig.1)
2.Automatic single action lock design
・Easy to use single action lock design by simply
inserting FPC after mounting. (Fig.2) (Release the lock
by operating or opening the lock lever when removing
FPC.)
・Operation of the lock lever is not required at the time of
mating FPC.
Can be operated with one hand.
mating FPC.
Contributes to assembly time reduction.
mating FPC.
Lock lever will not be damaged by operation.
mating FPC.
No lever at insertion eliminates failures due to FPC
movement during locking.
[After mating]
Just insert it!
Fig.2
High FPC retention force through the lock design
[FPC being inserted]
3.High FPC retention force
[FPC inserted]
・The notches on both sides of FPC are held by the lock
lever, generating a high FPC retention force in spite of
the small size. (Fig.3)
4.Easy FPC insertion
・Wide guide for easy FPC insertion easy. (Fig.1)
5.Supports 0.3mm-thick FPC
・The design accommodates a rigid 0.3mm-thick FPC,
which helps to prevent deformation of the FPC upon
insertion.
6.Supports high speed transmission
・Supports high speed transmission with excellent
impedance properties.
By making a differential pair with the same type of
contacts (even number-even number of contacts, odd
number-odd-number of contacts) excellent
transmission characteristics are achieved, supporting
eDP (ver1.4), MIPI (D-PHY) and USB3.0 standards.
(Fig.4)
Disengagement prevention!
Fig.3
Supports high speed transmission (Differential impedance)
130ps rise time (20-80%)
7.Environmental
・Halogen free
*As defined by IEC 61249-2-21.
Br : 900ppm max, Cl : 900ppm max,
Br+Cl : 1,500ppm max
Fig.4
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2017.9②
1
FH62 Series●0.25mm pitch, 1.1mm high, Top Contact Single Action Lock, High FPC Retention Force FPC connector
■Product Specifications
Rated current
0.25A
Rating
Rated voltage
Adaptive FPC/FFC
contact specifications
-55ç to +85°C (Note 1)
Storage temperature range -10ç to +50°C (Note 2)
humidity 90% max.
Operating humidity range Relative
(No condensation)
Storage humidity range
Relative humidity 90% max.
(No condensation)
Thickness : = 0.3±0.03mm Gold plated contact traces
Item
30V AC/DC
Operating temperature range
Specification
Conditions
1. Insulation resistance
50ø min.
100V DC
2. Withstanding voltage
No flashover or insulation breakdown
90V AC rms / 1 minute
3. Contact
resistance
100mø max.
* Including FPC conductor resistance
1mA (AC)
4. Durability
(insertion / withdrawal)
Contact resistance : 100mø max.
No damage, cracks, or parts dislocation
10 cycles
5. Vibration
No electrical discontinuity of 1µs or more
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
10 cycles in each of the 3 directions
6. Shock
Acceleration of 981m/s2, duration of 6ms, sine half-wave
waveform, 3 cycles in each of the 3 axes
7. Humidity
(Steady state)
Insulation resistance : 50Mø min.
96 hours at temperature of 40ç and humidity of 90% to
95%
8. Temperature
cycle
Temperature : -55°C / +15ç to +35ç / +85ç / +15ç to +35ç
Time :
30 /
2 to 3 / 30 / 2 to 3 (Minutes)
5 cycles
9. Resistance to
soldering heat
No deformation of components affecting
performance
Reflow : See recommended temperature profile (Page 8)
Manual soldering: 350 ± 10°C for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range
and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation.
■Materials / Finish
Part
Insulator
Contacts
Material
Color / Finish
LCP
Polyamide
Copper alloy
Beige
Black
Gold plated
■Product Number Structure
Refer to the chart below when datermining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 62 − 35S − 0.25 SHW (10)
❹
Series name:FH
Series No.
:62
Number of contacts:35
Contact pitch:0.25mm
2
❺
❻
Termination type
SHW・
・SMT Horizontal staggered
array mounting type
Specifications
(10):Standard (5,000pcs/reel)
(99):500pcs/reel
Remarks
UL94V-0
■Connector Dimensions
A±0.15
Cavity No.
Connect
No.2
(0.22)
0.5±0.1
0.5±0.1
Lot No.
Polarity mark
(180
Contact
No.1
(0.22)
(0.22)
C±0.15
D±0.15
(2.05)
1.1±0.1
(E)
1.015±0.1
7
Figure -1
4 ±0.1
(2.6)
(1.25)
(0.8)
(0.68)
(0.34)
0.31±0.1
2.51±0.1
(FPC:t=0.3)
Number of contacts
(3.69)
0.5±0.1 HRS mark
(Pickup area)
(2.61)
3.71±0.1
0.29±0.1
B±0.15
(0.25)
0.45±0.1
3.125±0.15
0.425±0.1
Position of the contact point
Lock lever tab
Note
1 : The dimension in parentheses are for reference.
2 : Lead co-planarity including reinforced chucking metals shall be 0.1 max.
3 : To be delivered with tape and reel packages.
See the packaging specifications for details.
4 : Note that preventive hole for sink mark or slit could be added for improvement.
5 : The quality remains good, even with the dark spots, which could occasionally occur on molded plastic.
6 : This product satisfies halogen free requirements defined as 900ppm maximum chlorine,
900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine.
7 Figure-1 Shows the state of opened lock cover. FPC can be pulled out by opening the lock lever by 45 degrees or more.
Part No.
FH62-13S-0.25SHW(**)
FH62-15S-0.25SHW(**)
FH62-17S-0.25SHW(**)
FH62-19S-0.25SHW(**)
FH62-21S-0.25SHW(**)
FH62-23S-0.25SHW(**)
FH62-25S-0.25SHW(**)
FH62-27S-0.25SHW(**)
FH62-31S-0.25SHW(**)
FH62-35S-0.25SHW(**)
FH62-39S-0.25SHW(**)
FH62-41S-0.25SHW(**)
FH62-51S-0.25SHW(**)
FH62-55S-0.25SHW(**)
FH62-61S-0.25SHW(**)
HRS No.
Under planning (Note 1)
580-4300-0 **
Units : mm
No. of contacts
13
15
17
19
21
23
25
27
31
35
39
41
51
55
61
A
6.46
6.96
7.46
7.96
8.46
8.96
9.46
9.96
10.96
11.96
12.96
13.46
15.96
16.96
18.46
B
2.5
3
3.5
4
4.5
5
5.5
6
7
8
9
9.5
12
13
14.5
C
3
3.5
4
4.5
5
5.5
6
6.5
7.5
8.5
9.5
10
12.5
13.5
15
D
6
6.5
7
7.5
8
8.5
9
9.5
10.5
11.5
12.5
13
15.5
16.5
18
E
4.43
4.93
5.43
5.93
6.43
6.93
7.43
7.93
8.93
9.93
10.93
11.43
13.93
14.93
16.43
Note 1 : Contact positions without HRS No. are currently under planning.
Please contact hirose for detailed information about product variation.
3
Recommended PCB Mounting Pattern
B
0.8±0.02
(0.25)
(n-1)/2×
0.3 ±0.02
0.5
0.02
X
0.5
Contact No.1
(n+1)/2×
0.02
0.3 ±0.02
C ±0.02
X
X
×4
0.4 ±0.02
F
2.8±0.02
(Connector image)
0.6
0.8±0.02
(0.175)
0.8±0.02
2.8±0.02
Contact No.2
0.02
X
0.67±0.01
Recommended stencil thickness:t=0.1
(Land pattern image)
0.5
(n+1)/2×
0.02
0.25 ±0.01
C ±0.02
Y
Y
×4
0.35 ±0.01
F
Y
0.63±0.01
0.6
(n-1)/2×
0.02
0.25 ±0.01
0.5
3.4±0.01
B
(0.25)
3.4±0.01
(0.3)
0.77±0.01
Recommended Stencil Pattern
0.02
Y
Note 8 : 'n' shows the number of contacts.
Recommended Dimensions of PCB Mounting Pattern and Stencil Pattern
Part No.
HRS No.
580-4300-0 **
No. of contacts
13
15
17
19
21
23
25
27
31
35
39
41
51
55
61
4
B
2.5
3
3.5
4
4.5
5
5.5
6
7
8
9
9.5
12
13
14.5
C
3
3.5
4
4.5
5
5.5
6
6.5
7.5
8.5
9.5
10
12.5
13.5
15
Units : mm
F
6.1
6.6
7.1
7.6
8.1
8.6
9.1
9.6
10.6
11.6
12.6
13.1
15.6
16.6
18.1
Diagram of a recommended FPC dimension (when using plated lead part)
(FPC contact thickness : t=0.30±0.03)
0.25
0.0
0.07±0.02
0.07±0.02
5
0.28±0.03
11
(n+1)/2×
0.02 X
R0.2±0.05
0.3±0.03
(R
0.
0.45±0.05
1)
0.45±0.05
R0
.05
R0.2±0
0.28±0.03
0.15±0.02
0.15±0.02
Contact No.2
(n-1)/2×
0.02 X
10
G±0.05
Note
9 Dimension R must be 0.5mm minimum.
10 Indicated tolerance is applicable to the exposed conductor.
11 Both end sides of contact pad on FPC cannot be used for signal transmission.
Recommended FPC dimension (when not using plated lead part)
0.7±0.07
B
0.07±0.02
0.43±0.03
11
(n+1)/2×
0.02 Y
(R
R0.2±0.05
.1
5
R0 ±0.
.15 05
±0
.05
0±0.07
0.1
0.15±0.02
0.15±0.02
0.45±0.05
0.28±0.03
0.3±0.03
Contact No.1
0.45±0.05
Contact No.2
9 R
3.2±0.3 Stiffener
0.25
Y
0.23±0.1
0.27±0.1
0.5±0.1
0.82±0.1
1.5±0.1
1.65±0.1
0.18±0.02
0.82±0.1
0.65±0.05
0.4±0.02
0.07±0.02
1.35±0.05
G±0.05
C±0.02
0.7±0.07
0.285±0.02
0.15±0.02
0.07±0.07
R0
2.2±0.3
(exposed part of the conductor)
5
0.0
.2±
R0
X
9 R
3.2±0.3 Stiffener
2.2±0.3
.1
5
R0 ±0 (exposed part of the conductor)
1.35±0.05
5± 5
0.
0.65±0.05
05
0±0.07
.2±
0.7±0.07
B
0.27±0.1
0.5±0.1
0.82±0.1
1.5±0.1
1.65±0.1
G±0.05
C±0.02
0.7±0.07
0.215±0.02
0.07±0.07
R0
Contact No.1
R0
.2
±0
(n-1)/2×
0.02 Y .05
10 G±0.05
Note
5
Recommended FPC Dimensions
Units : mm
Part No.
HRS No.
No. of contacts
B
C
G
13
2.5
3
4.4
15
3
3.5
4.9
17
3.5
4
5.4
19
4
4.5
5.9
21
4.5
5
6.4
23
5
5.5
6.9
25
5.5
6
7.4
27
6
6.5
7.9
31
7
7.5
8.9
580-4300-0 **
35
8
8.5
9.9
39
9
9.5
10.9
41
9.5
10
11.4
51
12
12.5
13.9
55
13
13.5
14.9
61
14.5
15
16.4
FPC Construction (Recommended Specifications)
MATERIAL NAME
Covering film layer
Cover adhesive
Surface
treatment
MATERIAL
Polyimide 1mil
1μm to 6μm nickel underplated
0.2μm gold plated
Copper foil
Cu 1oz
Base adhesive Heat-hardened adhesive
Base film
Polyimide 1mil
Reinforcement
material adhesive
Stiffener
Polyimide 7mil
THICKNESS (μm)
25
25
(4)
35
25
25
35
175
3. Caution
1. Material composition of FPC is a reference example. Please adjust the thickness of the FPC mating section
to 0.3±0.03mm in reference to the material composition.
2. For the details of the material composition, please contact each FPC manufacturer.
6
Packaging Specifications
1.75±0.1
4±0.1
(2)
M±0.1
1
0.
+ 0
L±0.1
K±0.3
K
M±0.1
(1.35)
(0.3)
.5
CL
+0.15
Direction of unreeling
+0.1
1.7
●Reel Dimensions
CL
●Leader, Trailer Dimensions
(N:Reel inner width)
Direction of
unreeling
(Ø80)
400mm MIN(Leader)
(Ø380)
(Ø
13)
8±0.1
Ø1
1
0.
+ 0
.5
Ø1
4±0.1
(2)
+0.3
-0.1
8±0.1
(1.35)
(0.3)
●Embossed Carrier Tape Dimensions
(Tape width 32mm and over)
1.75±0.1
(Tape width up to 24mm)
Top cover tape
Embossed carrier tape
160mm MIN
100mm MIN
(Trailer, empty components)
(empty components)
(P:Reel outer width)
Units : mm
Part No.
HRS No.
No. of contacts
K
L
M
N
P
13
16
7.5
17.4
21.4
15
17
19
21
23
25
24
11.5
25.4
29.4
27
31
580-4300-0 **
35
39
41
51
55
32
28.4
14.2
33.4
37.4
61
7
Temperature Profile
MAX 250℃
Applicable Conditions
Temperature(℃)
245
Reflow method
220℃
Solder
200
: IR/Hot air
Reflow environment : Room air
: Paste type Sn/3.0Ag/0.5Cu
(M705-GRN360-K2-V made by Senju
180℃
Metal Industry Co.)
150
Test PCB
150℃
: PCB material and size
Glass epoxy 32.85×18.3×0.8mm
Land size, per recommended on page 4.
100
Metal mask
20 to 40
sec.
50
25℃
Per recommended on page 4.
Peak temperature
This temperature profile is based on the above conditions.
120±5 sec.
60 to 90 sec.
It may vastly depending on solder paste type, manufacturer,
Preheating time
Soldering time
PCB size and mounting materials. Please use only after
checking the mounting conditions.
Start
Time(sec.)
8
: Thickness and opening size
Connector operation and points to note
[Operation method]
As this connector is a small-sized, thin product, care needs to be taken when handling.
Please check the following before use.
1. Initial condition
❶The product is delivered with the lock lever closed, you do not need to operate it except for when removing
the FPC.
2. How to insert FPC
❶Insert FPC with the conductor surface facing upwards, horizontal to the board surface.
[Caution]
・During FPC insertion, do not twist the FPC to up and down, right and left or an angle. It may cause
deformation of the contacts and contact failure.
Lock lever (closed)
FPC (horizontal)
Lock lever (closed)
FPC (horizontal)
NG
NG
NG
Lock lever (closed)
Lock lever (open)
FPC diagonal
FPC (diagonal)
3. Check the inserted state of FPC
When FPC is completely inserted, visually inspect the status.
OK
The outer shapes of FPC and the lock lever are
parallel and inserted to the end.
NG
FPC is not inserted deep enough.
NG
FPC is inserted diagonally.
9
[Operation method]
4. How to remove FPC
❶Push up the lock lever slowly, and release the lock.
[Caution]
・The lock lever can't be opened over 180°.
・After releasing the lock lever, do not touch the contact.
・Do not raise, pull, or twist the lock lever.
OK
NG
NG
NG
180°
Do not touch the contact.
Rotational axis
Excessive load is
applied to the lock lever.
Load is concentrated
on the rotation axis,
and leads to breakage.
❷After releasing the lock lever, remove the FPC in the horizontal direction.
❸After remove of the FPC, close the lock lever.
[Caution]
・Do not pull out FPC while the lock lever is not opened to 45° or more.
・Ensure both ends of the lock lever are closed.
OK
Lock lever (open)
45° or more
45°
FPC can be removed without letting
the lock lever interfere with FPC.
OK
OK
Close the both ends of
the lock lever.
NG
FPC diagonal
FPC diagonal
10
[Operation methods]
5. FPC routing after connection
qDepending on a FPC rounding, a load is applied to connector, and a contact failure may occur.
To prevent a failure, take the following notes into a consideration during mechanism design.
[Caution]
• Make sure that FPC and stiffener do not contact chassis.
• Avoid applying forces to FPC in vertical or horizontal directions.
In addition, avoid pulling up and down on the FPC.
• When fixing FPC after FPC cabling, avoid pulling FPC, and route the wire FPC with slack.
In this regard, the stiffener is parallel to the PCB.
• Do not mount other components touching to the FPC underneath the FPC stiffener.
OK
NG
NG
NG
Stiffener
Stiffener
The state where a load is applied to FPC
Mounting parts interfer with FPC
[Cautions when Mounting PCB]
SWarp of PCB
Minimize warp of the PCB as much as possible.
Lead co-planarity including reinforced metals is 0.1mm or less.
Too much wrap of the PCB may result in a soldering failure.
SFlexible board design
Please make sure to put a stiffener on the backside of the flexible board.
We recommend a glass epoxy material with the thickness of 0.3mm MIN.
SLoad to Connector
Do not add 1.0N or greater external force when unreel or pick and place the connector etc,
or it may get broken.
In addition, do not insert the FPC or operate the connector before mounting.
SLoad to PCB
• Splitting a large PCB into several pieces
• Screwing the PCB
Avoid the handling described above so that no force is
exerted on the PCB during the assembly process.
Otherwise, the connector may become defective.
Connector
FPC
(for mounting connector)
SInstructions on manual soldering
Follow the instructions shown below when soldering
the connector manually during work, etc.
❶Do not perform any reflow or hand soldering operation while FPC is inserted in the connector.
❷Do not apply extreme heat, or allow the soldering iron to touch anything other than the connector lead.
This could cause the connector to be deformed or melted.
❸Do not supply excessive solder (flux).
If excessive solder (flux) is applied to the contact, the solder or flux could adhere on the contact point and
cause contact failure.
11
Powered by TCPDF (www.tcpdf.org)
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7350
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
12
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 09/2017. Contents are subject to change without notice for the purpose of improvements.
