IPBS-104-02-T-D
IPBS-104-02-T-D
    SAMTEC(申泰)
    SMD,P=4.2mm
    排母 间距:4.2mm 2x4P SMT
IPBS-104-02-T-D 数据手册
ISOLATED POWER SYSTEMS FEATURES & BENEFITS • Individually shrouded contacts for electrical and mechanical protection • .100" (2.54 mm) and .165" (4.19 mm) pitch • Surface mount or through-hole • Vertical and right-angle for parallel, perpendicular and coplanar applications • Locking clip, key polarization and guide post options • Discrete wire assemblies with 16-30 AWG PVC or Teflon™ fluoropolymer wire (see pages 243-245). • Metal or plastic rugged latching system *Teflon™ is a trademark of The Chemours Company FC, LLC used under license by Samtec Selectively loading contacts achieves customer specific creepage and clearance requrements. CREEPAGE & CLEARANCE Flexible standard or high-power stacking systems with Power Eye three-finger BeCu contacts for reliable connection. For available series, visit samtec.com/flexiblestrips CREEPAGE CLEARANCE IPT1/IPS1 MMSS(T)/MMSD(T) 2.54 mm 1.91 mm IPBT/IPBS PMSS(T)/PMSD(T) 4.27 mm 3.05 mm Selectively loading contacts achieves customer specific creepage and clearance requirements. KEY SPECIFICATIONS SERIES PITCH INSULATOR MATERIAL CONTACT MATERIAL PLATING OPERATING TEMP RANGE CURRENT RATING IPT1/IPS1 .100" (2.54 mm) Black LCP Phosphor Bronze Sn or Au over 50 µ" (1.27 µm) Nickel -55 °C to +125 °C 5.9 A (1 pin powerd) 775 VAC Yes IPBT/IPBS .165" (4.19 mm) Black LCP High Copper Alloy (IPBT) Phospher Bronze (IPBS) Sn over 50 µ" (1.27 µm) Nickel -55 °C to +105 °C 10.3 A (2 pins powerd) 400 VAC Yes F-224 VOLTAGE LEAD-FREE RATING SOLDERABLE samtec.com/minimate or samtec.com/powermate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. MAX 10.3 A (4.19 mm) .165" PITCH • ISOLATED POWER CONNECTOR SET IPBT - - NO. OF POSITIONS PER ROW 1 LEAD STYLE 02, 03, 04, 05, 08, 10 - PLATING OPTION –H1 OPTIONS –RA = Single Row = Right-angle (Lead Style –H1 only) –D = Surface Mount (Standard Sizes) s –S = Matte Tin –H2 (–D Only) p - ROW OPTION –T = Through-hole 15 - m –GP = Double Row = Guide Post Holes (Not available with –K) –K = Keyed Polarization (Not available with –GP option, is required callout if –GP not called out) IPBT   Board Mates: IPBS Cable Mates: PMSD, PMSS   –H1–S –H1–D   1RRI3RVLWLRQV[            –H2–S       –GP –H1–S–RA - 1 - NO. OF POSITIONS PER ROW 10.3 A 4 8.4 A 6 7.6 A 8 7.1 A 30 6.0 A       IPBS 2 –H2–D 1RRI3RVLWLRQV[        IPBT/IPBS CURRENT PINS POWERED (PERRATING CONTACT)    - LEAD STYLE 02, 03, 04, 05, 08, 10 –01 = Standard Power 15   –H1–D–RA PLATING OPTION - –T –S = Matte Tin = Guide Post –D = Standard Power Surface Mount (Standard Sizes) OPTION –GP = Single Row –02 (–D Only) - ROW OPTION = Double Row MATED HEIGHT IPBS IPBS Board Mates: IPBT   –01–S –01–D 1RRI3RVLWLRQV[           1RRI3RVLWLRQV[     F-224 MATED HEIGHT   –02–S Note: Some lengths, styles and options are non-standard, non-returnable. IPBT –GP   –02–D IPBT/IPBS LEAD STYLE MATED HEIGHT* H1/–01 (15.25) .600 –H2/–02 (16.84) .663 *Processing conditions will affect mated height. View complete specifications at: samtec.com?IPBT & samtec.com?IPBS samtec.com/powermate Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
IPBS-104-02-T-D 价格&库存
很抱歉,暂时无法提供与“IPBS-104-02-T-D”相匹配的价格&库存,您可以联系我们找货
