IPL1-116-01-L-S-RA-K
    SAMTEC(申泰)
    弯插,P=2.54mm
    线对板针座 间距P=2.54mm 16Pin(1x16P) 弯插
IPL1-116-01-L-S-RA-K 数据手册
F-215 (Rev 24AUG15) IPL1–106–01–L–D–RE1–K IPL1–110–02–L–S–K IPL1–105–02–L–D–K IPL1–120–01–L–D–RA–K (2.54 mm) .100" IPL1 SERIES DISCRETE WIRE HEADER SPECIFICATIONS For complete specifications www.samtec.com?IPL1 Mates with discrete wire cable assemblies Mates with: MMSD, MMSS, MMSDT, MMSST Insulator Material: Natural LCP Terminal Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1.27 µm) Ni Operating Temp Range: -55°C to +125°C Voltage Rating: 675 VAC/954 VDC RoHS Compliant: Yes Keyed Polarization Align & Latch™ Processing: Lead–Free Solderable: Yes –S & –D (–02 Lead Style) SMT Lead Coplanarity: (0.10 mm) .004" max (02-05) (0.13 mm) .005" max (06-10) (0.15 mm) .006" max (11-25) –SH SMT Lead Coplanarity: (0.15 mm) .006" max (02-25) RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality NO. PINS PER ROW LEAD STYLE 02, 03, 04, 05, 06, 08, 10, 12, 15, 16, 20, 25 = Throughhole IPL1 1 –01 –RE1 APPLICATION –02 (Standard sizes) = Surface Mount MMSD –01. –02 & –RA = No. of positions x (2.54) .100 + (1.52) .060 –SH & –RE1 = No. of positions x (2.54) .100 + (4.06) .160 (8.76) .345 IPL1-RE1 (7.04) .277 (9.58) .377 Note: Some lengths, styles and options are non-standard, non-returnable. –S –RA =Right Angle (–01 lead style only) –SH = Single Row Horizontal (–02 lead style only) –D = Double Row (2.54) .100 –K =Keyed Polarization –RE1 (6.86) .270 (2.03) .080 (3.05) .120 –01–D (2.16) .085 –01–S –01–S–RE1 (5.59) .220 (1.02) .040 (7.62) .300 (5.44) .214 –02–SH (8.26) .325 (2.16) .085 (2.54) .100 (8.13) .320 (1.52) .060 (2.54) .100 (2.03) .080 (0.64) .025 SQ –02 –01 –RA K =Right Angle Elevated (–01 lead style only) (–K is a required callout) (5.46) .215 (2.54) .100 (6.35) .250 TAIL OPTION = Single Row –01–S-RA 01 02 –02–D –L = 10µ" (0.25 µm) Gold on contact, Matte Tin on tail (6.10) .240 (5.08) .200 (8.76) .345 • Other sizes • With or without plug polarization • Guide post holes • Other platings • Weld tab Contact Samtec. ROW OPTION 01 02 (MOQ Required) PLATING OPTION (1.52) .060 –02–S ALSO AVAILABLE Surface Mount, Right Angle, Right Angle Elevated and Vertical Through-hole (2.54 mm) .100" pitch –01–D–RA WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –01–D–RE1
IPL1-116-01-L-S-RA-K 价格&库存
很抱歉,暂时无法提供与“IPL1-116-01-L-S-RA-K”相匹配的价格&库存,您可以联系我们找货
