LT4HLT8-AC240V
LT4HLT8-AC240V
    OTHER
LT4HLT8-AC240V 数据手册
LT4H/-L Timers DIN 48 SIZE DIGITAL TIMER UL File No.: E122222 C-UL File No.: E122222 LT4H Timers Features 1. Bright and Easy-to-Read Display A brand new bright 2-color back light LCD display. The easy-to-read screen in any location makes checking and setting procedures a cinch. 2. Simple Operation Seesaw buttons make operating the unit even easier than before. 3. Short Body of only 64.5 mm 2.539 inch (screw terminal type) or 70.1 mm 2.760 inch (pin type) With a short body, it is easy to install in even narrow control panels. 4. Conforms to IP66’s Weather Resistant Standards The water-proof panel keeps out water and dirt for reliable operation even in poor environments. 48 1.890 48 1.890 64.5 2.539 mm inch Pin type Screw terminal type RoHS Directive compatibility information http://www.nais-e.com/ 5. Screw terminal (M3.5) and Pin Types are Both Standard Options The two terminal types are standard options to support either front panel installation or embedded installation. 6. Changeable Panel Cover Also offers a black panel cover to meet your design considerations. 7. Compliant with UL, c-UL and CE. Product types Time range Operating mode Output Operating voltage Power down insurance Terminal type 100 to 240 V AC LT4H8-AC240V 11 pins LT4H-AC240V Screw terminal Relay (1 c) 9.999 s (0.001 s~) 99.99 s (0.01 s~) 999.9 s (0.1 s~) 9999 s (1 s~) 99 min 59 s (1 s~) 999.9 min (0.1 min~) 99 h 59 min (1 min~) 999.9 h (0.1 h~) Power ON delay (1) Power ON delay (2) Signal ON delay Signal OFF delay Pulse One-shot Pulse ON-delay Signal Flicker Totalizing ON-delay (8 modes) 24 V AC LT4H8-AC24V 11 pins LT4H-AC24V LT4H-AC24VS 8 pins LT4H8-DC24V 11 pins LT4H-DC24V Screw terminal 100 to 240 V AC 24 V AC LT4H-DC24VS 8 pins LT4HT8-AC240V 11 pins LT4HT-AC240V Screw terminal Transistor (1 a) LT4H-AC240VS 8 pins Screw terminal 12 to 24 V DC Available Part number 8 pins LT4HT-AC240VS 8 pins LT4HT8-AC24V 11 pins LT4HT-AC24V Screw terminal LT4HT-AC24VS 8 pins LT4HT8-DC24V 11 pins LT4HT-DC24V 12 to 24 V DC Screw terminal * A rubber gasket (ATC18002) and a mounting frame (AT8-DA4) are included. All Rights Reserved © COPYRIGHT Matsushita Electric Works, Ltd. LT4HT-DC24VS LT4H/-L UL File No.: E122222 C-UL File No.: E122222 LT4H-L Timers Features 1. Economically priced in anticipation of market needs. • Economically priced to provide excellent cost performance. 2. Display is a bright reflective-type LCD. 3. Inherits all of the characteristics of the LT4H digital timer. • Seesaw switches ensure easy operation. • IP66 environmental protection. • Shortened body (70.1 mm 2.760 inch underhead). 48 1.890 64.5 2.539 48 1.890 mm inch 4. Compliant with UL, c-UL and CE. Product types Product name LT4H-L digital timer Time range Operating mode Power ON delay (1) Power ON delay (2) Signal ON delay Signal OFF delay Pulse One-shot Pulse ON-delay Signal Flicker Totalizing ON-delay (8 modes) 9.999 s (0.001 s~) 99.99 s (0.01 s~) 999.9 s (0.1 s~) 9999 s (1 s~) 99 min 59 s (1 s~) 999.9 min (0.1 min~) 99 h 59 min (1 min~) 999.9 h (0.1 h~) Output Operating voltage Power down insurance Terminal type Part number 100 to 240 V AC LT4HL8-AC240V 24 V AC/DC LT4HL8-AC24V Relay (1 c) LT4HL8-DC24V 12 to 24 V DC Available 8 pins 100 to 240 V AC LT4HLT8-AC240V 24 V AC/DC LT4HLT8-AC24V 12 to 24 V DC LT4HLT8-DC24V Transistor (1 a) Part names Time delay indicator TIMER (Countdown time display) DIP switches Elapsed time display 2 3 4 5 6 7 8 ON 1 Controlled output indicator Set time display Reset indicator OP. RST LOCK RESET Reset switch Lock switch h m s Time units display Lock indicator UP Up keys LOCK LT4H Down keys DOWN (Same for screw terminal type and 8-pin type) All Rights Reserved © COPYRIGHT Matsushita Electric Works, Ltd. LT4H/-L Specifications Type Ralay output type Transistor output type AC type AC/DC type DC type AC type AC/DC type DC type 100 to 240 V AC, 24 V AC, 100 to 240 V AC, 24 V AC, 12 to 24 V DC 12 to 24 V DC 24 V AC/DC 24 V AC/DC — 50/60 Hz common 50/60 Hz common — Max. 3 W Max. 10 V A Max. 10 V A Max. 3 W 5 A, 250 V AC (resistive load) 100 mA, 30 V DC 9.999 s, 99.99 s, 999.9 s, 9999 s, 99 min 59 s, 999.9 min, 99 h 59 min, 999.9 h (selected by DIP switch) Addition (UP)/Subtraction (DOWN) (2 directions selectable by DIP switch) A (Power ON delay 1), A2 (Power ON delay 2), B (Signal ON delay), C (Signal OFF delay), D (Pulse one-shot), E (Pulse ON delay), F (Signal Flicker), G (Totalizing ON delay) (selectable by DIP switch) Min. input signal width: 1 ms, 20 ms (2 directions by selected by DIP switch) (The 8-pin type does not have a stop input.) Min. input signal width: 20 ms (The 8-pin type does not have a lock input.) Open collector input Input impedance: Max. 1 kΩ; Residual voltage: Max. 2 V Open impedance: 100kΩ or less, Max. energized voltage: 40V DC 7-segment LCD (LT4H, LT4H-L common), Elapsed value (backlight red LED), Setting value (backlight yellow LED) Item Rated operating voltage Rated frequency Rated power consumption Rated control capacity Time range Time counting direction Rating Operation mode Start/Reset/Stop input Lock input Input signal Time accuracy (max.) Contact Indication Power failure memory method Operating time fluctuation Temperature error Voltage error Setting error Contact arrangement Contact resistance (Initial value) Contact material EEP-ROM (Min. 105 overwriting) Mechanical (contact) Breakdown voltage (Initial value) Electrical Insulation resistance (Initial value) Min. 2 × 107 ope. (Except for switch operation parts) — 1.0 × 10 ope. (At rated control voltage) Min. 10 ope. (At rated control voltage) 5 Electrical (contact) Mechanical Operating conditions Functional Destructive Functional Shock resistance Destructive Ambient temperature Ambient humidity Air pressure Ripple rate Vibration resistance Connection Protective construction 7 Max. 0.5 s Max. 65° C — (under the flow of nominal operating current at nominal voltage) 10 to 55 Hz: 1 cycle/min single amplitude of 0.35 mm .014 inch (10 min on 3 axes) 10 to 55 Hz: 1 cycle/min single amplitude of 0.75 mm .030 inch (1 h on 3 axes) Min. 98 m 321.522 ft./s2 (4 times on 3 axes) Min. 294 m 964.567 ft./s2 (5 times on 3 axes) –10° C to 55° C +14° F to +131° F Max. 85 % RH (non-condensing) 860 to 1,060 h Pa — 20 % or less — 20 % or less 8-pin/11-pin/screw terminal IP66 (front panel with rubber gasket) Applicable standard Safety standard EN61812-1 (EMI)EN61000-6-4 Radiation interference electric field strength Noise terminal voltage (EMS)EN61000-6-2 Static discharge immunity RF electromagnetic field immunity EMC ] 85 to 110 % of rated operating voltage 2,000 Vrms for 1 min: Between live and dead metal parts (11-pin) 2,000 Vrms for 1 min: Between live and dead metal parts (Pin type) 2,000 Vrms for 1 min: Between input and output 2,000 Vrms for 1 min: Between input and output 1,000 Vrms for 1 min: Between contacts Between live and dead metal parts Min. 100 MΩ: Between live and dead metal parts (At 500V DC) Min. 100 MΩ: Between input and output (At 500V DC) Between input and output Between contacts Operating voltage reset time Temperature rise Operating voltage: 85 to 110% Temperature: –10 to +55°C +14 to +131°F Min. input signal width: 1ms Timed-out 1 Form A (Open collector) — — Timed-out 1 Form C 100 mΩ (at 1 A 6 V DC) Ag alloy/Au flash Life Allowable operating voltage range [ ± (0.005 % + 50 ms) in case of power on start ± (0.005 % + 20 ms) in case of input signal start EFT/B immunity Surge immunity Conductivity noise immunity Power frequency magnetic field immunity Voltage dip/Instantaneous stop/Voltage fluctuation immunity Pollution Degree 2/Overvoltage Category II EN55011 Group1 ClassA EN55011 Group1 ClassA EN61000-4-2 4 kV contact 8 kV air EN61000-4-3 10 V/m AM modulation (80 MHz to 1 GHz) 10 V/m pulse modulation (895 MHz to 905 MHz) EN61000-4-4 2 kV (power supply line) 1 kV (signal line) EN61000-4-5 1 kV (power line) EN61000-4-6 10 V/m AM modulation (0.15 MHz to 80 MHz) EN61000-4-8 30 A/m (50 Hz) EN61000-4-11 10 ms, 30% (rated voltage) 100 ms, 60% (rated voltage) 1,000 ms, 60% (rated voltage) 5,000 ms, 95% (rated voltage) All Rights Reserved © COPYRIGHT Matsushita Electric Works, Ltd. LT4H/-L (units: mm inch) Tolerance: ±1.0 ±.039 Dimensions • LT4H digital timer Screw terminal type (Flush mount) 48 1.890 Pin type (Flush mount/Surface mount) 64.5 2.539 5.5 .217 5.5 .217 55.6 2.189 14.5 .571 TIMER OP. RST LOCK h m 44.5 1.752 s 44.5 1.752 UP RESET LOCK LT4H DOWN 7.5 .295 7.5 .295 • Dimensions for embedded installation (with adapter installed) Screw terminal type Pin type Rubber gasket ATC18002 (supplied) Panel Mounting frame for flush mount AT8-DA4 (supplied) TIMER 48 1.890 OP. RST LOCK h m 44.5 1.752 66 2.598 48 1.890 OP. RST LOCK UP RESET DOWN LT4H RESET Mounting frame 8-pin type for flush mount (8p cap AD8-RC AT8-DA4 (supplied) sold separately) 11-pin type (11p cap AT8-DP11 sold separately) TIMER 50 1.969 s Panel Rubber gasket ATC18002 (supplied) h m 50 1.969 s 66 2.598 UP LOCK LOCK LT4H 1 .039 48 1.890 63.5 2.500 • Dimensions for front panel installations 48 1.890 90 3.543 • For connected installations The standard panel cut-out dimensions are shown below. Use the mounting frame (AT8-DA4) and rubber gasket (ATC18002). 45+0.6 0 45+0.6 0 1.772+.024 0 80 min. 3.150 1.772+.024 0 A A = (48 × n – 2.5) +0.6 0 +.024 0 45 1.772 Device installation rail AT8-DLA1 (sold separately) ( 1 .039 • Installation panel cut-out dimensions DIN rail terminal block (8-pin type AT8-DF8K sold separately) (11-pin type AT8-DF11K sold separately) 95.5 (90.0) 3.760 (3.543) DOWN +0.6 0 Note) 1: The installation panel thickness should be between 1 and 5 mm .039 and .197 inch. Note) 2: For connected installations, the waterproofing ability between the unit and installation panel is lost. 80 min. 3.150 ) dimension is for 8-pin type. Terminal layouts and Wiring diagrams • 8-pin type Relay output type Transistor output type N.C. N.O. 4 5 Reset 3 2 – 3 2 1 8 1 8 Operating voltage – + 8 9 10 N.C. 1 + 2 Operating voltage – 3 4 5 + Transistor output type N.C. 5 6 7 4 3 2 – 1 11 8 9 10 Operating voltage + N.O. Reset Start Stop Lock 5 6 7 4 3 2 – 1 11 8 9 10 Operating voltage + Transistor output type N.O. 7 6 7 Operating voltage • Screw terminal type Relay output type 6 4 5 Reset 6 7 Reset Start Stop Lock Reset Start Stop Lock Start Start • 11-pin type Relay output type Reset Start Stop Lock 6 7 8 9 10 1 2 3 4 5 Operating + voltage – Note) For connecting the output leads of the transistor output type, refer to 5) Transistor output on page 48. All Rights Reserved © COPYRIGHT Matsushita Electric Works, Ltd. LT4H/-L Setting the operation mode, time range, and time Setting procedure 1) Setting the operation mode and time range Set the operation mode and time range with the DIP switches on the side of the LT4H timer. Table 1: Setting the operation mode DIP switches DIP switch OFF ON Item 1 2 3 Operation mode *4 Minimum input reset, start, and stop signal width DIP switch No. 1 2 3 ON ON ON OFF OFF OFF ON OFF OFF OFF ON OFF ON ON OFF OFF OFF ON ON OFF ON OFF ON ON Refer to table 1 20 ms 1 ms 5 Time delay direction Addition Subtraction 6 Time range Refer to table 2 7 8 * The 8-pin type does not have the stop input, so that the dip switch can be changed over between reset and start inputs. The signal range of the lock input is fixed (minimum 20 ms). Table 2: Setting the time range DIP switch No. Time range 6 7 8 ON ON ON 0.001 s to 9.999 s OFF OFF OFF 0.01 s to 99.99 s ON OFF OFF 0.1 s to 999.9 s OFF ON OFF 1 s to 9999 s ON ON OFF 0 min 01 s to 99 min 59 s OFF OFF ON 0.1 min to 999.9 min ON OFF ON 0 h 01 min to 99 h 59 min OFF ON ON 0.1 h to 999.9 h Notes: 1) Set the DIP switches before installing the timer. 2) When the DIP SW setting is changed, turn off the power once. 3) The DIP switches are set as ON before shipping. DIP switches 2 3 4 5 6 7 8 ON 1 Operation mode A: Power on delay 1 A2: Power on delay 2 B: Signal on delay C: Signal off delay D: Pulse One shot E: Pulse On delay F: Signal Flicker G: Totalizing On delay (Same for screw terminal type) Setting procedure 2) Setting the time Set the set time with the keys (UP and DOWN keys) on the front of the LT4H timer. Front display section I UP keys Q Elapsed time display 3 TIMER Changes the corresponding digit of the W Set time display 1 set time in the addition direction E Time delay indicator 4 2 (upwards) R Controlled output indicator OP. O DOWN keys 5 RST T Reset indicator Y Lock indicator U Time units display LOCK h m s 6 RESET UP 7 8 10 LOCK 11 9 LT4H DOWN Changes the corresponding digit of the set time in the subtraction direction (downwards) P RESET switch Resets the elapsed time and the output { LOCK switch Locks the operation of all keys on the unit • Changing the set time 1. It is possible to change the set time with the up and down keys even during time delay with the timer. However, be aware of the following points. 1) If the set time is changed to less than the elapsed time with the time delay set to the addition direction, time delay will continue until the elapsed time reaches full scale, returns to zero, and then reaches the new set time. If the set time is changed to a time above the elapsed time, the time delay will continue until the elapsed time reaches the new set time. 2) If the time delay is set to the subtraction direction, time delay will continue until “0” regardless of the new set time. 2. If the set time is changed to “0,” the unit will operate differently depending on the operation mode. 1) If the operation mode is set to A (power on delay 1) or A2 (power on delay 2), the output will turn on when the power supply is turned on. However, the output will be off while reset is being input. 2) In the other modes, the output turns on when the start is input. When the operation mode is C (signal off delay), D (Pulse one shot), or F (Signal flicker), only when the start input is on does the output turn on. Also, when the reset is being input, the output is off. • Power failure memory The EEPROM is used for power failure memory. It has a life of Min. 105 over-writings. The EEPROM is overwriting with the following timing. Output mode Power ON delay (2) A2 Addition G Other modes Overwrite timing When power is OFF Change of preset value or start, reset input When power is OFF after being ON When power is OFF after changing preset value * Be aware that the contents of EEPROM for all modes will be overwritten when power is turned OFF during input to external lock terminals R to E and 7 to 6 . Such an action does not exist by doing lock operation from the front. All Rights Reserved © COPYRIGHT Matsushita Electric Works, Ltd. LT4H/-L T: Set time t1, t2, t3, tata+tb T t1+t2=T T>t ta tb t Notes: 1) Each signal input (start, reset, stop, and lock) is applied by shorting their input terminal to the common terminal (terminal Q for the 8-pin type, terminal E for the 11-pin type, and terminal 6 for the screw terminal type). 2) The 8-pin type does not have a stop input or lock input. All Rights Reserved © COPYRIGHT Matsushita Electric Works, Ltd. LT4H/-L T: Set time t1, t2, t3, tata T t1 T ta t2 t T=t1+t2 T t1 t2 T=t1+t2 T T t1 t2 ta t1 t2 T T=t1+t2 T>ta T T=t1+t2+t3 T T t1 t2 T>ta t3 ta Notes: 1) Each signal input (start, reset, stop, and lock) is applied by shorting their input terminal to the common terminal (terminal Q for the 8-pin type, terminal E for the 11-pin type, and terminal 6 for the screw terminal type). 2) The 8-pin type does not have a stop input or lock input. All Rights Reserved © COPYRIGHT Matsushita Electric Works, Ltd.
LT4HLT8-AC240V 价格&库存
很抱歉,暂时无法提供与“LT4HLT8-AC240V”相匹配的价格&库存,您可以联系我们找货
