PARP-03V-R
PARP-03V-R
    JST
    P=2mm
    1X3P 2MM
PARP-03V-R 数据手册
PA FAMILY/PA•PAF•PAL CONNECTORS 2.0 mm pitch/Wire-to-board (Crimp style/IDC style) / Wire-to-wire (Crimp style/IDC style) Retainer ® PA Socket (Crimp style Standard type) Standards ® ® PA FAMILY/PA•PAF•PAL CONNECTORS Retainer Retainer PAF Socket (IDC style) PA Header (Top entry type) PAF Socket (IDC style) PAL (Crimp style Wire-to-wire) PA Socket (Crimp style   Retainer    mountable type) PA Header (Side entry type) PA Header (Top entry type) Retainer The 2.0 mm pitch PA family consists of the following connectors: ・PA connector (Wire-to-board crimp style) ・PAF connector (Wire-to-board insulation displacement connection (IDC) style) ・PAL connector (Wire-to-wire crimp style) These features enabled a harness with complicated shape for the first time as a 2.0 mm pitch connector with secure locking mechanism. ● Secure locking device ● Interchangeable between crimp and IDC socket ● Secondary retainers ● Harness variation PA connector (Standard type, Retainer mountable type) ● Highly reliable contact ● Insertion guide mechanism ● Flanged press pin PAF connector ● The industryʼs first secure lock IDC connectors ● Metallic strain relief ● Retainer with four locking points PAL connector ● The industryʼs first wire to wire 2.0 mm pitch retainer mountable type connector. ● Either with or without panel lock can be selected according to application. 1 Recognized E60389 Specifications ® ® PA Connector (Standard type) • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: Conductor size/ AWG #28 to #22 Insulation O.D./ 0.76 to 1.5 mm • Applicable PC board thickness: 1.6 mm PA Connector (Retainer mountable type) • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 25 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 V AC/minute • Applicable wire: AWG #26 to #22 PAF Connector • Current rating: 1.0 A AC/DC (AWG #26) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 25 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: UL1061(Contact JST for details regarding other UL wires.) AWG #26 Conductor/ 7 strands, tin-coated annealed copper Insulation O.D./ 0.9 to 1.0 mm PAL Connector • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 100 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 25 mΩ max. • Insulation resistance: Initial/ 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: AWG #28 to #22 • Applicable panel thickness : 0.5 to 2.0 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. PA FAMILY/PA•PAF•PAL CONNECTORS List of combinations Crimp style Standard type Contact SPHD-001T-P0.5 SPHD-002T-P0.5 Header Top entry type Side entry type B( )B-PASK B( )B-PASK-1 PA FAMILY/PA•PAF•PAL CONNECTORS B( )B-PASK-N B( )B-PASK-1N Housing PAP-( )V-S S( )B-PASK-2 Header Bottom type BE( )B-PASK BE( )B-PASK-C Header High box type BH( )B-PASK BH( )B-PASK-1 Crimp style Retainer mountable type Contact Header SPA-001T-P0.5 BM( )B-PASS Housing PARP-( )V SMT type Top entry type BM( )B-PASS-1 SM( )B-PASS SM( )B-PASS-1 Side entry type Retainer PMS-( )V-S IDC style Socket Contact ( )PAF-6S SPAL-001T-P0.5 Retainer PAFS-( )V-S Wire to wire type SPAL-002T-P0.5 Receptacle housing PALR-( )V(F) Retainer PMS-( )V-S 2 PA FAMILY/PA•PAF•PAL CONNECTORS PC board layout and Assembly layout 1.5 ±0.05 +0.1 φ1.1 0 9.9 +0.1 PA Socket (Standard type) + PA Header φ0.7+0.1  0 PA Socket (Standard type) + PA side entry type header Bottom type 1.6 1.6 (10.6) (9.9) (5.8) 0 5.5+0.1  0 PAF Socket + PA side entry type header (10.9) φ0.7+0.1  0 1.6 -0.1 8.2 PA Socket (Retainer mountable type) + PA side entry type header (9.5) A±0.05 (7) (8.4) 8.2 8.2 (9.3) (14.7)retainer included 2.1±0.05 7 2±0.05 ±0.05 (18.9) 1.5±0.05 A±0.05 2 (18.8)retainer included 13.8 (5.8) 1.5+0.1  0 (7.2) +0.1 D 0 Note: Dimensions C and D; Refer to the header bottom type. (5.8) PAF Socket + PA bottom type header PA Socket (Retainer mountable type) + PA bottom type header PA Socket (Standard type) + PA bottom type header C+0.1  0 (14.9) Side entry type PAF Socket + PA Header PA Socket (Retainer mountable type) + PA Header 1.6 1.7±0.05 φ0.7 0 (10.8) 2 ±0.05 (14.9) (14.7)retainer included 5.8 A±0.05 φ1.1+0.1  0 (5.8) 7.2 Top entry type Bottom type with extended length (13.95) +0.1 0 Note: Dimensions C; Refer to the header bottom type. (7.2) PA Socket (Standard type) + PA bottom type header (Extended lenght type) PA Socket (Retainer mountable type) + PA bottom type header (Extended lenght type) Note:  1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. Please contact JST for details as the dimensions shown in the above figure are reference values. 3 (14.9) 1.6 (5.8) 5.5 C (14.7) retainer included (9.9) (5.8) 0 4.65-0.1 +0.1 0 5.5 +0.1 0 2.1 +0.1 0 13.65 (10.8) 13.65 1.6 φ0.75 +0.1 0 (10.6) A±0.05 1.6 2 ±0.05 (5.8) PAF Socket + PA bottom type header (Extended lenght type) PA FAMILY/PA•PAF•PAL CONNECTORS PC board layout and Assembly layout High box type 7.2 7.1 A ±0.05 1.5 ±0.05 2 +0.1 φ1.1  0 ±0.05 1.7 ±0.05 15.9 +0.1 φ0.7  0 20.9 (20.7)retainer included 7.1 PAF Socket + PA high box type header PA Socket (Retainer mountable type) + PA high box type header PA Socket (Standard type) + PA high box type header Note:  1. The above figure is the figure viewed from the connector mounting side.  2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. H  ole dimensions differ according to the type of PC board and piercing method. Please contact JST for details as the dimensions shown in the above figure are reference values. (7.6) (1.4) 2.2 ±0.05 φ0.8+0.1  0 1.45±0.1 11.1 1.8±0.1 PA Socket (Standard type) + PA Header 1.8±0.1 +0.1 φ0.8 0 1.7±0.1 1 min. 2±0.05 2.2±0.05 (1.1) 8.9 (6.2) +0.1 R0.4  0 (1.1)(16)retainer included 11.1 8.9 5.7 3.8±0.1 2.8 2.7 min. 7.8±0.1 1±0.1 (1.1) 1.45±0.1 7.95±0.1 A±0.1 Connector outline PA Socket (Standard type) + PA side entry type header (SMT) (16.2) 8.9 (7.6) Side entry type PAF Socket + PA Header PA Socket (Retainer mountable type) + PA Header 5.7 2 ±0.05 5 ±0.1 2.9 min. 0.3 Connector outline 3.6±0.1 4.9 ±0.1 R0.4  0 PA Socket (Retainer mountable type) + PA side entry type header (SMT) (6.2) +0.1 A ±0.1 1 min. (1.4) 5.7 1±0.1 (6.2) (16.0)retainer included 1.7 ±0.1 (6.2) (1.4) (16.2) Top entry type PAF Socket + PA side entry type header (SMT) Note: 1 . The above figure is the figure viewed from the connector mounting side. 2. Tolerances for the centers of pattern on PCB is ± 0.05, and shall be not cumulative more than ± 0.1. 3. P  lease contact JST for details as the dimensions shown in the above figure are reference values. (25.8)retainer included (8.9) retainer included (8.4) retainer included PA Socket (Standard type) + PAL Receptacle (26)retainer included PA Socket (Retainer mountable type) + PAL Receptacle (7.6) retainer included (21.5)retainer included PAF Socket + PAL Receptacle 4 PA FAMILY/PA•PAF•PAL CONNECTORS Contact Applicable wire Model No. Insulation O.D. (mm) Q'ty/ reel 26~22 1.0~1.5 8,000 28~24 0.76~1.5 8,000 AWG # SPHD-001T-P0.5 0.13~0.33 SPHD-002T-P0.5 0.08~0.21 1.5 mm2 Material and Finish Phosphor bronze, tin-plated(reflow treatment) RoHS2 compliance 6.5 2.85 1.3 Contact SPHD-002T-P0.5 SPHD-001T-P0.5 Crimping machine Crimp applicator AP-K2N MKS-L-10 Applicator Dies Crimp applicator with dies MK/SPHD-002-05 APLMK SPHD002-05 MK/SPHD-001-05 APLMK SPHD001-05 Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits 2 B A 2 (2) 3 5.8 4.6 4 5 7 8 7.3 6 8 9 Circuit No.1 10 11 12 B A (2) 13 5.8 2 14 4.6 15 B (2) 5.8 2 8 4.6 7.3 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 1,000 8.0 12.0 1,000 10.0 14.0 1,000 12.0 16.0 1,000 14.0 18.0 1,000 16.0 20.0 1,000 18.0 22.0 1,000 20.0 24.0 1,000 22.0 26.0 1,000 24.0 28.0 1,000 26.0 30.0 1,000 28.0 32.0 1,000 30.0 34.0 1,000 RoHS2 compliance Circuit No.1 5 Q'ty/ bag PA 66, UL94V-0, natural (white) Circuit No.1 A PAP-02V-S PAP-03V-S PAP-04V-S PAP-05V-S PAP-06V-S PAP-07V-S PAP-08V-S PAP-09V-S PAP-10V-S PAP-11V-S PAP-12V-S PAP-13V-S PAP-14V-S PAP-15V-S PAP-16V-S Dimensions (mm) A B Material and Finish 8 7.3 16 Model No. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PAP-02V-SS...natural (white) K...black R...red E...blue M...green O...orange N...brown P...purple PK...pink Y...yellow L...lemon yellow FY...vivid yellow LE...light blue H...gray TR...tomato red PA FAMILY/PA•PAF•PAL CONNECTORS Through-hole type header Top entry type Side entry type Circuit No.1 6.5 B (3.4) 11.7 6.1 5.9 1.2 3 8.2 A 7.7 A 5.3 5.9 B 7.7 φ0.8 1.7 1.5 Circuit No.1 B 6.5 (3.4) 5.9 3 1.2 8.2 A 7.7 A 5.3 11.7 B Circuit No.1 6.1 2 5.9 2 7.7 0.5 φ0.8 1.7 1.5 2 Circuit No.1 B A Circuit No.1 5.3 6.5 B (3.4) φ0.8 0.5 2 1.7 1.5 2 Top entry type No. of circuits 2(Note1) 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 11.7 8.2 6.1 5.9 3 1.2 7.7 A 7.7 2 5.9 0.5 Circuit No.1 Side entry type Model Without boss B02B-PAFYK-A B02B-PASK B03B-PASK B04B-PASK B05B-PASK B06B-PASK B07B-PASK B08B-PASK B09B-PASK B10B-PASK B11B-PASK B12B-PASK B13B-PASK B14B-PASK B15B-PASK B16B-PASK No. With a boss B02B-PAFYK-1A B02B-PASK-1 B03B-PASK-1 B04B-PASK-1 B05B-PASK-1 B06B-PASK-1 B07B-PASK-1 B08B-PASK-1 B09B-PASK-1 B10B-PASK-1 B11B-PASK-1 B12B-PASK-1 B13B-PASK-1 B14B-PASK-1 B15B-PASK-1 B16B-PASK-1 Dimensions (mm) Q'ty/ box A B 2.0 6.0 1,000 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 1,000 8.0 12.0 500 10.0 14.0 500 12.0 16.0 500 14.0 18.0 500 16.0 20.0 500 18.0 22.0 500 20.0 24.0 250 22.0 26.0 250 24.0 28.0 250 26.0 30.0 250 28.0 32.0 250 30.0 34.0 250 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) (Note1) PA 66, vivid yellow RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. B02B-PASKS...natural (white) K...black R...red E...blue M...green O...orange N...brown P...purple PK...pink Y...yellow L...lemon yellow FY...vivid yellow LE...light blue H...gray TR...tomato red No. of circuits 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Model No. S02B-PASK-2 S03B-PASK-2 S04B-PASK-2 S05B-PASK-2 S06B-PASK-2 S07B-PASK-2 S08B-PASK-2 S09B-PASK-2 S10B-PASK-2 S11B-PASK-2 S12B-PASK-2 S13B-PASK-2 S14B-PASK-2 S15B-PASK-2 S16B-PASK-2 Dimensions (mm) A B Q'ty/ box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 500 8.0 12.0 500 10.0 14.0 500 12.0 16.0 250 14.0 18.0 250 16.0 20.0 250 18.0 22.0 250 20.0 24.0 250 22.0 26.0 250 24.0 28.0 200 26.0 30.0 200 28.0 32.0 200 30.0 34.0 200 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. S03B-PASK-2S...natural (white) K...black R...red E...blue M...green O...orange N...brown P...purple PK...pink Y...yellow L...lemon yellow LE...light blue H...gray TR...tomato red 6 PA FAMILY/PA•PAF•PAL CONNECTORS Through-hole type header N type N type No. of circuits Circuit No.1 B A 2 5.3 3 5 1.2 5.9 7.7 4 6 3 7 φ0.8 0.5 2 8 1.7 9 1.5 10 11 Circuit No.1 B 12 13 5.3 A 14 16 1.2 5.9 7.7 15 3 2 No. With a boss B02B-PASK-1N B03B-PASK-1N B04B-PASK-1N B05B-PASK-1N B06B-PASK-1N B07B-PASK-1N B08B-PASK-1N B09B-PASK-1N B10B-PASK-1N B11B-PASK-1N B12B-PASK-1N B13B-PASK-1N B14B-PASK-1N B15B-PASK-1N B16B-PASK-1N Dimensions (mm) Q'ty/ box A B 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 1,000 8.0 12.0 500 10.0 14.0 500 12.0 16.0 500 14.0 18.0 500 16.0 20.0 500 18.0 22.0 500 20.0 24.0 250 22.0 26.0 250 24.0 28.0 250 26.0 30.0 250 28.0 32.0 250 30.0 34.0 250 Material and Finish φ0.8 0.5 Model Without boss B02B-PASK-N B03B-PASK-N B04B-PASK-N B05B-PASK-N B06B-PASK-N B07B-PASK-N B08B-PASK-N B09B-PASK-N B10B-PASK-N B11B-PASK-N B12B-PASK-N B13B-PASK-N B14B-PASK-N B15B-PASK-N B16B-PASK-N Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural 1.7 1.5 RoHS2 compliance This product displays (LF)(SN) on a label. Circuit No.1 B A 5.9 3 1.2 7.7 5.3 1.7 φ0.8 0.5 2 1.5 Bottom type Bottom type No. of circuits Circuit No.1 B 9 A 5 0.5 5.3 2 8 11 7.7 5.9 (2.5) 3 12 A No. of circuits 4 2 5.3 8.0 12.0 12.4 5.5 300 14.0 18.0 18.4 5.5 200 20.0 24.0 24.4 12.0 150 22.0 26.0 26.4 12.0 150 Bottom type with extended lenght 5 12.05 1.6 Q'ty/ bag 7.7 (2.5) 3 5.9 A D 0.5 5.3 Circuit No.1 C RoHS2 compliance This product displays (LF)(SN) on a label. Note: Dimemsions C and D; Refer to the PCB layout bottom type (page 3). Bottom type with extended lenght B B Material and Finish 9 2 BE05B-PASK BE08B-PASK BE11B-PASK BE12B-PASK Dimensions (mm) A Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural Circuit No.1 B Model No. 6 4.75 Model No. BE04B-PASK-C BE05B-PASK-C BE06B-PASK-C Dimensions (mm) A B C Q'ty/ box 6.0 10.0 10.4 1,050 8.0 12.0 12.4 875 10.0 14.0 14.4 750 Material and Finish 0.5 7 7.7 (2.5) 3 5.9 Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural RoHS2 compliance This product displays (LF)(SN) on a label. Note: 1. Dimemsions C; Refer to the PCB layout bottom type (page 3). 2. Unlisted in UL. PA FAMILY/PA•PAF•PAL CONNECTORS Header 7.1 B A B 7.1 A 5.3 5.3 3 3 13.9 13.9 2 Circuit No.1 Circuit No.1 B 7.1 2 A 5.3 7.1 5.3 2 3 3 13.9 13.9 B A Circuit No.1 Circuit No.1 B 7.1 2 A 5.3 7.1 5.3 2 3 3 13.9 13.9 B A Circuit No.1 No. of circuits 2 3 4 5 6 7 8 9 10 11 12 15 Model No. Without a boss BH02B-PASK BH03B-PASK BH04B-PASK BH05B-PASK BH06B-PASK BH07B-PASK BH08B-PASK BH09B-PASK BH10B-PASK BH11B-PASK BH12B-PASK BH15B-PASK With a boss BH02B-PASK-1 BH03B-PASK-1 BH04B-PASK-1 BH05B-PASK-1 BH06B-PASK-1 BH07B-PASK-1 BH08B-PASK-1 BH09B-PASK-1 BH10B-PASK-1 BH11B-PASK-1 BH12B-PASK-1 BH15B-PASK-1 Circuit No.1 Dimensions(mm) Q'ty/ box A B 2.0 6.0 900 4.0 8.0 675 6.0 10.0 525 8.0 12.0 450 10.0 14.0 375 12.0 16.0 325 14.0 18.0 300 16.0 20.0 250 18.0 22.0 225 20.0 24.0 225 22.0 26.0 200 28.0 32.0 150 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PBT, UL94V-0, natural (white) RoHS2 compliance This product displays (LF)(SN) on a label. 8 PA FAMILY/PA•PAF•PAL CONNECTORS B A 1.8 5.7 7.1 SMT type header Top entry type Side entry type Circuit No.1 B B A AB 2 A2 5.7 5.7 1.8 5.7 7.1 7.1 7.1 1.8 1.8 2 Circuit No.1 Circuit No.1 B Circuit No.1 B AB A 2 A 2 5.7 5.7 2 7.1 7.1 7.1 1.8 1.8 1.8 5.7 Circuit No.1 Circuit No.1 Circuit No.1 B B A A 2 5.7 2 7.1 7.1 1.8 1.8 5.7 Circuit No.1 Circuit No.1 Top entry type No. of circuits 2 3 4 5 6 7 8 9 10 11 12 13 15 Side entry type Model No. Without a boss BM02B-PASS-(*) BM03B-PASS-(*) BM04B-PASS-(*) BM05B-PASS-(*) BM06B-PASS-(*) BM07B-PASS-(*) BM08B-PASS-(*) BM09B-PASS-(*) BM10B-PASS-(*) BM11B-PASS-(*) BM12B-PASS-(*) BM13B-PASS-(*) BM15B-PASS-(*) With a boss BM02B-PASS-1-(*) BM03B-PASS-1-(*) BM04B-PASS-1-(*) BM05B-PASS-1-(*) BM06B-PASS-1-(*) BM07B-PASS-1-(*) BM08B-PASS-1-(*) BM09B-PASS-1-(*) BM10B-PASS-1-(*) BM11B-PASS-1-(*) BM12B-PASS-1-(*) BM13B-PASS-1-(*) BM15B-PASS-1-(*) Dimensions(mm) Q'ty/ reel A B 2.0 8.0 500 2 4.0 10.0 500 3 6.0 12.0 500 4 8.0 14.0 500 5 10.0 16.0 500 6 12.0 18.0 500 7 14.0 20.0 500 8 16.0 22.0 500 9 18.0 24.0 500 10 20.0 26.0 500 11 22.0 28.0 500 12 24.0 30.0 500 13 28.0 34.0 500 15 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: (*): T  F...taping product TFT...taping product with suction tape. 9 No. of circuits Model No. Without a boss SM02B-PASS-(*) SM03B-PASS-(*) SM04B-PASS-(*) SM05B-PASS-(*) SM06B-PASS-(*) SM07B-PASS-(*) SM08B-PASS-(*) SM09B-PASS-(*) SM10B-PASS-(*) SM11B-PASS-(*) SM12B-PASS-(*) SM13B-PASS-(*) SM15B-PASS-(*) With a boss SM02B-PASS-1-(*) SM03B-PASS-1-(*) SM04B-PASS-1-(*) SM05B-PASS-1-(*) SM06B-PASS-1-(*) SM07B-PASS-1-(*) SM08B-PASS-1-(*) SM09B-PASS-1-(*) SM10B-PASS-1-(*) SM11B-PASS-1-(*) SM12B-PASS-1-(*) SM13B-PASS-1-(*) SM15B-PASS-1-(*) Dimensions(mm) Q'ty/ reel A B 2.0 8.0 1,000 4.0 10.0 1,000 6.0 12.0 1,000 8.0 14.0 1,000 10.0 16.0 1,000 12.0 18.0 1,000 14.0 20.0 1,000 16.0 22.0 1,000 18.0 24.0 1,000 20.0 26.0 1,000 22.0 28.0 1,000 24.0 30.0 1,000 28.0 34.0 1,000 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural (ivory) Solder tab: Copper alloy, copper-undercoated, tin-plated (reflow treatment) RoHS2 compliance This product displays (LF)(SN) on a label. Note: (*): TB...taping product TBT...taping product with suction tape. PA FAMILY/PA•PAF•PAL CONNECTORS Contact Applicable wire mm2 AWG # Insulation O.D. (mm) Q'ty/ reel 0.13~0.33 26~22 0.9~1.5 10,000 Model No. 1.5 SPA-001T-P0.5 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 8.4 2.85 1.3 RoHS2 compliance 2.2 Contact SPA-001T-P0.5 Crimping machine Crimp applicator AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SPA-001-05 APLMK SPA001-05 Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits B B A A 7.2 7.2 2 2 3 4 11.4 11.4 5 Circuit No.1 6 7 Circuit No.1 8 B 9 10 B A A 7.2 11 7.2 2 2 12 13 11.4 11.4 15 Model No. PARP-02V PARP-03V PARP-04V PARP-05V PARP-06V PARP-07V PARP-08V PARP-09V PARP-10V PARP-11V PARP-12V PARP-13V PARP-15V Dimensions (mm) A B Q'ty/ bag 2.0 5.4 1,000 4.0 7.4 1,000 6.0 9.4 1,000 8.0 11.4 1,000 10.0 14.0 1,000 12.0 16.0 1,000 14.0 18.0 1,000 16.0 20.0 1,000 18.0 22.0 1,000 20.0 24.0 500 22.0 26.0 500 24.0 28.0 500 28.0 32.0 500 Material and Finish Circuit No.1 Circuit No.1 PA 66, UL94V-0, natural (white) RoHS2 compliance Note: Contact JST for Glow Wire compliant connectors. B B A A 7.2 7.2 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PARP-02V-oo- 2 11.4 11.4 2 Circuit No.1 (blank)...natural (white) R...red E...blue M...green Y...yellow Circuit No.1 Retainer No. of circuits 2 3 2 4 5 B A A B 2 6 7 8 9 2.4 3.1 2.4 1.5 7 2.85 1.5 7 10 11 12 13 15 Model No. PMS-02V-S PMS-03V-S PMS-04V-S PMS-05V-S PMS-06V-S PMS-07V-S PMS-08V-S PMS-09V-S PMS-10V-S PMS-11V-S PMS-12V-S PMS-13V-S PMS-15V-S Dimensions (mm) A B Q'ty/ bag 2.0 7.3 1,000 4.0 9.3 1,000 6.0 11.3 1,000 8.0 13.3 1,000 10.0 11.55 1,000 12.0 13.55 1,000 14.0 15.55 1,000 16.0 17.55 1,000 18.0 19.55 1,000 20.0 21.55 1,000 22.0 23.55 1,000 24.0 25.55 1,000 28.0 29.55 1,000 Material and Finish Glass-filled PA 66, UL94V-0, natural (ivory) RoHS2 compliance 10 PA FAMILY/PA•PAF•PAL CONNECTORS Receptacle No. of circuits Model No. 02PAF-6S 03PAF-6S 04PAF-6S 05PAF-6S 06PAF-6S 07PAF-6S 08PAF-6S 09PAF-6S 10PAF-6S 11PAF-6S 12PAF-6S 13PAF-6S 14PAF-6S 15PAF-6S 16PAF-6S 2 3 4 5 6 7 B 2 A 8 13 9 2 10 12 3.1 5.1 11 13 14 8 Circuit No.1 15 *16 Dimensions (mm) A B Q'ty/ box 2.0 6.0 1,000 4.0 8.0 1,000 6.0 10.0 500 8.0 12.0 500 10.0 14.0 500 12.0 16.0 500 14.0 18.0 250 16.0 20.0 250 18.0 22.0 250 20.0 24.0 250 22.0 26.0 250 24.0 28.0 250 26.0 30.0 250 28.0 32.0 250 30.0 34.0 250 Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, natural (white) RoHS2 compliance Note*: Unlisted in UL. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 02PAF-6SS...natural (white) R...red E...blue M...green Y...yellow Retainer No. of circuits Model No. PAFS-02V-S PAFS-03V-S PAFS-04V-S PAFS-05V-S PAFS-06V-S PAFS-07V-S PAFS-08V-S PAFS-09V-S PAFS-10V-S PAFS-11V-S PAFS-12V-S PAFS-13V-S PAFS-14V-S PAFS-15V-S 2 3 4 5 6 2 7 * 9 A B 8 *10 *11 *12 *13 *14 *15 4.1 8.9 Dimensions (mm) A B 2.0 7.4 1,000 4.0 9.4 1,000 6.0 11.4 1,000 8.0 13.4 1,000 10.0 15.4 1,000 12.0 17.4 1,000 14.0 19.4 1,000 16.0 21.4 1,000 18.0 23.4 1,000 20.0 25.4 1,000 22.0 27.4 1,000 24.0 29.4 1,000 26.0 31.4 1,000 28.0 33.4 1,000 Material and Finish Glass-filled PA 66, UL94V-0, natural (ivory) RoHS2 compliance Note*: Unlisted in UL. 11 Q'ty/ bag PA FAMILY/PA•PAF•PAL CONNECTORS Contact Applicable wire 0.5 1.6 Model No. Insulation O.D. (mm) Q'ty/ reel mm2 AWG # SPAL-001T-P0.5 0.13~0.33 26~22 1.0~1.5 10,000 SPAL-002T-P0.5 0.08~0.21 28~24 0.9~1.5 10,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 12.8 RoHS2 compliance 2.85 1.3 0.5 Contact SPAL-001T-P0.5 2.4 SPAL-002T-P0.5 Applicator Crimping machine Crimp applicator MKS-L AP-K2N Dies Crimp applicator with dies MK/SPAL-001-05 APLMK SPAL001-05 MK/SPAL-002-05 APLMK SPAL002-05 Note: Contact JST for fully automatic crimping applicator. Housing No. of circuits Without panel locks B A 6.3 3.4 3.7 A 2 2 PALR-02VF PALR-03VF PALR-04VF PALR-05VF PALR-06VF PALR-07VF PALR-08VF 2 3 6.3 B 4 3.4 3.7 5 6 7 2.0 9.4 1,000 4.0 11.4 1,000 6.0 13.4 1,000 8.0 15.4 1,000 10.0 17.4 1,000 12.0 19.4 1,000 14.0 21.4 1,000 PA 66, UL94V-0, natural (white) Circuit No.1 4.7 Q'ty/ bag Material and Finish 11.2 20 20 8 Circuit No.1 Dimensions (mm) A B Model No. RoHS2 compliance 4.4 With panel locks 3.2 3.7 3.4 No. of circuits 1 20 Model No. PALR-02V PALR-03V PALR-04V PALR-06V PALR-07V PALR-08V 2 Panel layout 4.6 ±0.05 A 2 6.3 3 4 6 6.5 +0.1 0 B 7 8 C+0.1 0 D±0.1 D Q'ty/ bag 2.0 9.4 9.8 13.4 1,000 4.0 11.4 11.8 15.4 1,000 6.0 13.4 13.8 17.4 1,000 10.0 17.4 19.8 21.4 1,000 12.0 19.4 21.8 23.4 1,000 14.0 21.4 23.8 25.4 1,000 4 RoHS2 compliance 3.2 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PALR-02V(F)-oo- 6.3 3.4 Panel layout 20 5.1±0.05 3.7 6.5 +0.1 0 B 2 C PA 66, UL94V-0, natural (white) A B Material and Finish Circuit No.1 3.25 Dimensions (mm) A (blank)...natural (white) R...red E...blue M...green Y...yellow C+0.1 0 5.8 D±0.1 5.15 Circuit No.1 1.6 4.4 Retainer Retainers are interchangeable with those of the PA crimp style retainer mountable type. 12
PARP-03V-R 价格&库存
很抱歉,暂时无法提供与“PARP-03V-R”相匹配的价格&库存,您可以联系我们找货
