PCIE-LP-04-01-S-DV-A-WT-TR 数据手册
PCIE–098–02–F–D–EMS2
F-218 (Rev 16NOV17)
PCIE–064–02–F–D–RA
(1.00 mm) .0394"
PCIE SERIES
PCIE–036–02–F–D–TH
PCI EXPRESS CARD SOCKETS
Polarized
Card Mates:
(1.60 mm) .062" card
SPECIFICATIONS
For complete specifications and
recommended PCB layouts see
www.samtec.com?PCIE
Insulator Material:
–TH=Black Nylon
–EMS2 & –RA=LCP
Contact:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
2.2 A per pin
(2 adjacent pins powered)
Operating Temp:
-55 °C to +125 °C
Card Insertion Depth:
(7.65 mm) .301" nominal
RoHS Compliant:
Yes
Lead–Free Solderable:
–RA & –EMS2=Yes
–TH=Wave only
Cable Mates:
PCIEC
Supports one,
four, eight and
sixteen PCI
Express® links
Note:
While optimized for
50 W applications, this
connector with alternative
signal/ground patterns may
also perform well in certain
75 W applications. Contact
Samtec for further information.
Choice of
card–edge mount
or PCB mount
Accepts
1.60 mm
(.062") card
Alignment
pins
HIGH-SPEED CHANNEL PERFORMANCE
14
PCIE
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
(MOQ Required)
Four rows on
2 mm pitch
G b p s
NO. OF
POSITIONS
PCIE
ALSO AVAILABLE
• Other platings
Contact Samtec.
PLATING
OPTION
02
TAIL
OPTION
D
FILE NO. E111594
OTHER
SOLUTIONS
–036, –064, –098, –164
PCI Express® Jumpers &
Extenders call for PCIEC Series
–EMS2
–F
= Edge Mount
= Gold flash on contact,
Tin on tail
–TH
= Through-hole
A
B2
–RA
B1
= Right-angle
(1.00) .03937
B
(1.78) .070
• Loop back Extender
(From one PCIe® slot to
another PCIe® slot)
• Ser-Des Physical Extender
another PCIe® Ser-Des)
• Physical Extender for easy
troubleshooting of PCIe® card
debug and analysis (PCIe®
slot to Emulator or Analyzer)
Contact Samtec.
PCI-SIG®, PCI Express® and
the PCIe® design marks are
registered trademarks and/or
service marks of PCI-SIG.
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
A2
(8.61)
.339
(7.50)
.295
A1
(11.65)
.459
(11.00)
.433
(15.40)
.606
(7.30)
.287
(1.35) .053
C
D
(2.05)
.081
DIA
A
B
(1.80) .071
(2.00)
.079
(2.50)
.098
(10.00)
.394
–TH
B1
(9.45)
.372
(10.00)
.394
(4.50)
.177
(4.50)
.177
–RA
(6.50)
.256
(2.50)
.098
POSITIONS
A
B
C
D
–036 (X1)
(25.00)
.984
(39.00)
1.535
(56.00)
2.205
(89.00)
3.504
(7.65)
.301
(21.65)
.852
(38.65)
1.522
(71.65)
2.821
(6.00)
.236
(20.00)
.787
(37.00)
1.457
(70.00)
2.756
(9.15)
.360
(23.15)
.911
(40.15)
1.581
(73.15)
2.880
–098 (X8)
–164 (X16)
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
(1.50)
.059
–EMS2
–064 (X4)
A1
(1.00) .03937
C
D
(7.65)
.301
(11.05)
.435
(2.31)
.091
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
PCIE-LP-04-01-S-DV-A-WT-TR 价格&库存
很抱歉,暂时无法提供与“PCIE-LP-04-01-S-DV-A-WT-TR”相匹配的价格&库存,您可以联系我们找货
