QMS-078-01-S-D-RA-PC8-K 数据手册
F-219
QMS–052–01–SL–D–RA–MG
QMS–016–01–SL–D–DP–RA–MG
(0.635 mm) .025"
QMS-RA SERIES
RIGHT-ANGLE GROUND PLANE HEADER
SPECIFICATIONS
Board Mates:
QFS
Integral metal plane
for power or ground
For complete specifications and
recommended PCB layouts see
www.samtec.com?QMS-RA
Insulator Material:
Liquid Crystal Polymer
Terminal & Ground
Plane Material:
Phosphor Bronze
Plating:
Au over 50 µ" (1.27 µm) Ni
(Tin on Ground Plane Tail)
Voltage Rating:
300 VAC
Operating Temp:
-55 °C to +125 °C
RoHS Compliant:
Yes
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (026-052)
(0.15 mm) .006" max (078)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
RECOGNITIONS
• Increased
insertion depth
• Integral guide post
• PCB mounting pins
HIGH-SPEED CHANNEL PERFORMANCE
QMS-RA/QFS-RA
Rating based on Samtec reference channel.
For full SI performance data visit Samtec.com
or contact SIG@samtec.com
QMS
PINS PER ROW
NO. OF PAIRS
14
G b p s
01
Metal guide post
option
PLATING
OPTION
RA
TYPE
OTHER
OPTION
MG
For complete scope of
recognitions see
www.samtec.com/quality
FILE NO. E111594
–026, –052, –078
(52 total pins per bank = –D)
–016, –032, –048
(16 pairs per bank = –D–DP)
–SL
= 10 µ" (0.25 µm)
Gold on Signal Pins
and Ground Plane,
Matte Tin on tails
–D
= Single-Ended
–D–DP
–MG
= Metal
Guide
Post
= Differential Pair
–TR
= Tape & Reel
(–016, –026,
–032 & –052
positions only)
OTHER
SOLUTIONS
Combination Signal/Power
See QMS-RA-PC Series or
QFS-RA-PC Series
ALSO AVAILABLE
No. of Banks x (21.34) .840 + (12.45) .490
(MOQ Required)
(11.87)
.467
(5.72)
.225
Other platings
Plastic Guide Post option
–02 lead style for (2.36 mm) .093" thick board
64 (-DP) and 104 positions per row
No. of Banks x (21.34) .840 + (5.33) .210
01
(8.13)
.320
02
(0.30)
.012
No. of Banks x (21.34) .840 + (6.10) .240
(0.64) .025 SQ
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–K
= Polyimide film
Pick &
Place Pad
(1.40)
.055
(0.89)
.035
DIA
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
(1.57)
.062
DIA
QMS-078-01-S-D-RA-PC8-K 价格&库存
很抱歉,暂时无法提供与“QMS-078-01-S-D-RA-PC8-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 16+419.5260116+52.49028
