SDL-119-G-12
SDL-119-G-12
    SAMTEC(申泰)
    CONN RCPT .100" 38POS DUAL GOLD
SDL-119-G-12 数据手册
F-215 SL–120–G–10 SDL–125–TT–12 SDL–115–G–19 (2,54 mm) .100" SL, SDL SERIES SL–110–TT–11 LOW PROFILE MACHINED SOCKET STRIPS FEATURES • Achieve low profile without sacrificing insertion depth! • Choice of four precision screw machined lead styles. • Exceptionally low profile, down to (2,11 mm) .083" off of board. • Mates with BBL or BDL for board stacking spaces down to (3,89 mm) .153" SPECIFICATIONS Mates with: TS, TD, HTS, BBS, BBD, BBL, BDL, BHS RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality Note: Some lengths, styles and options are non-standard, non-returnable. 1 NO. PINS PER ROW PLATING OPTION LEAD STYLE SL = Single Row Low Profile Socket Strip SDL = Double Row Low Profile Socket Strip –G (2,54) .100 X No. of Positions + (0,23) .009 = 30µ" (0,76 µm) Gold contact, 10µ" (0,25µm) Gold shell 01 (2,54) .100 thru (2,54) .100 TYP For complete specifications see www.samtec.com?SL or www.samtec.com?SDL Insulator Material: Black Glass Filled Polyester Contact/Shell Materials: BeCu/Brass Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Contact Resistance: 10 mΩ Insertion Force: (Single contact only) Standard = 9 oz (2,50 N) avg., 16 oz (4,45 N) max ((0,43 mm) .017" DIA probe) Low Insertion Force = 2.5 oz (0,70 N) avg., 5.5 oz (1,53 N) max ((0,43 mm) .017" DIA probe) Withdrawal Force: (Single contact only) Standard = 2.5 oz (0,70 N) avg., 1.5 oz (0,42 N) min ((0,43 mm) .017" DIA probe) Low Insertion Force = 2.0 oz (0,56 N) avg., 0.5 oz (0,14 N) min ((0,43 mm) .017" DIA probe) RoHS Compliant: Yes Lead-Free Solderable: Wave only TYPE STRIP (1,27) .050 –T = 30µ"(0,76 µm) Gold contact, Tin shell (2,54) .100 X No. of Positions + (0,23) .009 (5,08) .200 32 01 (2,54) .100 thru (1,27) .050 (2,54) .100 TYP –TT 36 = Tin contact and shell (LIF not available) Low Insertion Force (LIF) Available –12 –11 –10 Low Profile (Hollow Leg) –19 Micro-Socket (Hollow Leg) Low Profile (Standard Mount) Micro-Socket (Hollow Leg) For LIF specify –39 For LIF specify –31 (1,83) .072 DIA (1,83) .072 DIA (3,10) .122 (0,76) .030 (5,84) .230 (1,32) .052 DIA (0,76) .030 DIA Contact Length = (2,11 mm) .083" Lead DIA Accepted = (0,38 mm) .015" to (0,51 mm) .020" Insertion Depth = (2,67 mm) .105" to (4,32 mm) .170" Style 10 Component Part No. = SC-3P1 (6,10) .240 (2,11 mm) Only .0 8b3o”ard above p.c. (1,83) .072 DIA (0,51) .020 (3,35) .132 (4,83) .190 (1,32) .052 DIA (2,41) .095 (0,51) .020 (1,32) .052 DIA (4,19) .165 (4,45) .175 (1,32) .052 DIA (0,74) .029 DIA Micro Socket Contact Length = (1,58 mm) .062" Lead DIA Accepted = (0,41 mm) .016" to (0,51 mm) .020" Insertion Depth = (1,65 mm) .065" to (3,81 mm) .150" Style 12 Component Part No. = SC-5P1 (0,25) .010 (2,11) .083 (0,76) .030 DIA (0,51) .020 DIA Contact Length = (1,58 mm) .062" Lead DIA Accepted = (0,41 mm) .016" to (0,53 mm) .021" Insertion Depth = (2,03 mm) .080" to (2,67 mm) .105" Style 11 Component Part No. = SC-4P1 Style 31 Component Part No. = EZ-4P1 (1,83) .072 DIA Standard Socket (Reference only. Not available with SL & SDL) Contact Length = (1,58 mm) .062" Lead DIA Accepted = (0,41 mm) .016" to (0,51 mm) .020" Insertion Depth = (1,65 mm) .065" to (3,56 mm) .140" Style 19 Component Part No. = SC-8P1 Style 39 Component Part No. = EZ-8P1 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
SDL-119-G-12 价格&库存
很抱歉,暂时无法提供与“SDL-119-G-12”相匹配的价格&库存,您可以联系我们找货
