LOW PROFILE
SMT HEADER
8
G b p s
(2.00 mm) .0787" PITCH • TMM SERIES
TMM
Board Mates:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS
Cable Mates:
TCSD
SPECIFICATIONS
TMM
-1
NO. PINS
PER ROW
02 thru 40
LEAD
STYLE
Specify
LEAD
STYLE
from
chart
PLATING
OPTION
ROW
OPTION
–F
–S
= Gold flash
on post,
Matte Tin on tail
= Alignment Pin
(Metal or plastic
at Samtec’s
discretion)
(5 positions
minimum)
(–D only)
–D
–L
OTHER
OPTION
–A
= Single
Row
= Double
Row
= 10 µ" (0.25 µm)
Gold on post,
Matte Tin on tail
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50 µ" (1.27 µm) Ni
Current Rating:
3.2 A per pin
(2 pins powered)
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
281 VAC mated with SQW;
250 VAC mated with SQT
- SM -
–“XXX”
–S
= Polarized
Position
(Specify
position of
omitted pin)
= 30 µ" (0.76 µm)
Gold on post,
Matte Tin on tail
–T
–P
= Matte Tin
= Pick &
Place Pad
(3 positions
minimum)
–TR
= Tape & Reel
(3 thru 36
positions only)
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.15 mm) .006" max*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
–FR
1RRISRVLWLRQV[
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact
Samtec for
quantity breaks)
(3 thru 36
positions only)
ALSO AVAILABLE
Other plating
(MOQ Required)
–P
LEAD
STYLE
A
MATES
WITH
–01
(3.20) .126
SQT, SQW, ESQT,
TLE, SMM, MMS, TCSD
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–04
(1.91) .075
–05
(1.65) .065
–06
(4.27) .168
CLT
CLT-BE
–D
–S
samtec.com?TMM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
F-224
很抱歉,暂时无法提供与“TMM-119-01-F-D-038”相匹配的价格&库存,您可以联系我们找货
