TSM-111-01-S-DH
TSM-111-01-S-DH
    SAMTEC(申泰)
    SMD,P=2.54mm,卧贴
    排针 间距:2.54mm 2x11P 卧贴
TSM-111-01-S-DH 数据手册
F-217 (Rev 30NOV16) TSM–116–02–S–DV–LC 10 YEAR MFG WITH 30 µ" GOLD EXTENDED LIFE PRODUCT TSM–121–01–T–SV HIGH MATING CYCLES (2.54 mm) .100" SMT .025" SQ POST HEADER Board Mates: SSW, SSQ, SSM, BSW, ESW, ESQ, BCS, SLW, CES, HLE TSM NO. PINS PER ROW 1 Cable Mates: IDSS, IDSD, SMSD, SMSS 02 thru 36 SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?TSM Post Height TSM/SSW 4.7 A TSM/SSM 5.4 A TSM/HLE 4.1 A –L = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail .320" (8.13 mm) Post Height –02 = (Mates with SSM -DH) –03 –S = 30 µ" (0.76 µm) Gold on post, Matte Tin on tail = .420" (10.67 mm) Post Height (For Bottom Mount & Pass Through) –T .120" (3.05 mm) Post Height –04 = (Mates with SLW, CES, HLE) = Matte Tin –SV = Single Row Vertical Pin (2.54) .100 x No. of positions 36 (2.54) .100 CURRENT RATING (PER PIN) MATES –F = Gold flash on post, Matte Tin on tail (5.84 mm) Post Height –01 = .230" (Mates with SSW, BCS, SSM, IDSS, IDSD) Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +105 °C with Tin; -55 °C to +125 °C with Gold Voltage Rating: 475 VAC -SV/-DV mated with BCS or SSM RoHS Compliant: Yes Lead–Free Solderable: Yes -DH/-SH Lead Coplanarity: (0.15 mm) .006" max (02-36) -DV/-SV Lead Coplanarity: (0.10 mm) .004" max (02-05) (0.13 mm) .005" max (06-10) (0.15 mm) .006" max (11-36) ROW OPTION PLATING OPTION LEAD STYLE (2.54) .100 (1.14) .045 REF 01 (0.64) .025 SQ Post Height (2.54) .100 1 PIN POWERED PER ROW (3.81) .150 APPLICATIONS RECOGNITIONS SSM –SH TSM = Single Row Horizontal Pin For complete scope of recognitions see www.samtec.com/quality HORIZONTAL FILE NO. E111594 FILE NO: 090871_0_000 (1.40) .055 (1.78) .070 (2.54) .100 x No. of positions 36 01 (3.05) .120 ALSO AVAILABLE (MOQ Required) • Edge Mount and Locking Clips for –SV • Solder Locks for –DH and Shrouds for –DV • Other platings Contact Samtec. Note: Some lengths, styles and options are non-standard, non-returnable. (1.58) .062 DIA (2) Optional Alignment Pin (–A) (No. of positions x (2.54) .100) – (5.08) .200 (0.64) .025 SQ Post Height (2.03) .080 (2.54) .100 –01= (4.57) .180 –02, –03, –04 = (4.82) .190 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. TSM–115–01–T–SH–A TSM–110–01–T–DV TSM–126–02–L–DH–K TSM SERIES OTHER OPTIONS –A = Alignment Pin metal or plastic at Samtec discretion (Not available with –TM or –MT) (02 positions min.) (Not available with –LC) –LC = Locking Clip (Not available with –TM) (3 positions min.) (Not available with –A) (Manual placement required) –K –P = (6.50 mm) .256" DIA Polyimide Film Pick & Place Pad = Plastic Pick & Place Pad (6.86) .270 (6.86) .270 (–DV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–SH: 4 positions minimum without –TR; 2 & 3 positions available with –TR) (–DH: 4 positions minimum without –TR) –SV (–SV: 4 positions minimum without –TR; 2 & 3 positions available with –TR) = Polarized Position –SH & –DH –DV –TM = Double Row Vertical Pin = Triple Row Vertical Mixed Technology (Style –01 only) (2.54) .100 x No. of positions 02 02 thru 30 positions only 72 (2.54) (5.08) .100 .200 01 (2.54) .100 (1.14) .045 REF 71 (0.64) .025 SQ 03 (2.54) .100 X No. of positions 90 (2.54) .100 (2.79) .110 (1.58) .062 DIA (No. of positions -2) x (2.54) .100) –A Option 01 (3.81) .150 –LC Option –MT = Mixed Technology Pin (Style –01, –02 or –03 only) (2.54) .100 x No. of positions 02 72 (2.54) .100 x No. of positions 02 (2.54) .100 01 (1.58) .062 DIA(2) (No. of positions x (2.54) .100) – (5.08) .200 (0.64) .025 72 (6.10) .240 (2.54) (6.10) .100 .240 71 71 01 (1.78) .070 (2.54) .100 (2.54) .100 (0.64) .025 (2.54) .100 Post Height (1.52) .060 (2.54) .100 (2.54) .100 (7.87) .310 (3.56) .140 (11.43) .450 –DH (1.78) .070 (1.40) .055 88 (0.64) .025 SQ (2.54) .100 = Double Row Horizontal Pin (Style –01, –02 or –03 only) Optional Alignment Pin (–A) Post Height (2.54) .100 (7.62) .300 Post Height (2.54) .100 Not available with –MT or –TM (6.35) .250 (6.35) (13.27) x .250 .050 (7.62) x.300 (13.27) .050 (7.62) .300 (–DH: 5 positions minimum without –TR) –“XXX” –TR = Tape & Reel Packaging –SV = 02-22 positions –DV = 02-28 positions –SH = 02-30 positions –DH = 02-29 positions (10.16) .400 (10.16) x .400 (4.06) x.160 (4.06) .160 (3.68) .145 (7.87) .310 (1.16) .046 (1.16) .046 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. Post Height
TSM-111-01-S-DH 价格&库存
很抱歉,暂时无法提供与“TSM-111-01-S-DH”相匹配的价格&库存,您可以联系我们找货
