ZSS-120-09-S-D-1330
ZSS-120-09-S-D-1330
    SAMTEC(申泰)
    CONN HDR .100 40POS
ZSS-120-09-S-D-1330 数据手册
SHROUDED .025" SQ POST HEADERS (2.54 mm) .100" PITCH • TSS/HTSS/ZSS SERIES TSS/HTSS/ZSS SERIES Mates: SSW, SSQ, ESW, ESQ, SSM, BCS SPECIFICATIONS Insulator Material: TSS, ZSS=Black Glass Filled Polyester HTSS=Natural PCT Insulation Resistance: 5000 MΩ min Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Withstanding Voltage: 1000 VRMS - 1 TSS - NO. PINS PER ROW 03 = Connector Strip (TSS only) HTSS 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 = High Temp Connector Strip LEAD STYLE Specify LEAD STYLE from chart - PLATING OPTION –F –L (2.92) .115 –02 (4.19) .165 –03 (14.35) .565 = Matte Tin   –D–RA LEAD STYLE RIGHT ANGLE (B) –04 (3.30) .130 –05 (5.84) .230 PROCESSING = Double Row Right-angle (lead style –04 & –05 only) % Lead–Free Solderable: HTSS=Yes TSS, ZSS=No, Lead Wave only SMT Lead Coplanarity: (0.15 mm) .006" max* *(.004" stencil solution may be available; contact ipg@samtec.com)     $ ALSO AVAILABLE   —D -1 ZSS —DV (HTSS ONLY) - NO. PINS PER ROW 03, 05, 07, 08, 10, 12, 13, 15, 17, 20, 25, 32, 36 MOQ Required Other sizes Other platings Alignment Pins Single Row Locking Leads Polarized (Standard sizes) LEAD STYLE Specify LEAD STYLE from chart (2.54) .100 x No. of Positions + (3.81) .150 (2.54) .100 x No. of Positions + (1.27) .050 - PLATING OPTION (2.29) .090 MIN (2.54) .100 - D - –F –L BODY HEIGHT –“XXXX” = Body Height = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail LEAD STYLE –T –01 (16.00) .630 (13.72) .540 –02 (18.54) .730 (16.26) .640 –03 (21.08) .830 (18.80) .740 –04 (23.62) .930 (21.34) .840 –05 (26.16) 1.030 (23.88) .940 –06 (28.70) 1.130 (26.42) 1.040 –07 (31.24) 1.230 (28.96) 1.140 –08 (33.78) 1.330 (31.50) 1.240 –09 (36.32) 1.430 (34.04) 1.340 = Matte Tin (8.89) .350 —D—RA = Gold flash on post, Matte Tin on tail (9.27) .365 Note: Some lengths, styles and options are non-standard, non-returnable. ZSS is non-standard, non-returnable. –DV = Double Row Surface Mount (lead style –01 only) (HTSS only) –T  [1RRI3RVLWLRQV   –01 –D = Double Row Through-hole (lead style –01, –02 & –03 only) = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail  [1RRI3RVLWLRQV   T/H (A) ROW OPTION = Gold flash on post, Matte Tin on tail (Not available on -DV) (Standard sizes) LEAD STYLE - BODY HEIGHT C (OAL) Note: For added mechanical stability, Samtec recommends mechanical board spacers be used in applications with gold or selective gold plated connectors. Contact ipg@samtec.com for more information. MAX C BODY (OAL) HEIGHT samtec.com?TSS, samtec.com?HTSS or samtec.com?ZSS Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-224
ZSS-120-09-S-D-1330 价格&库存
很抱歉,暂时无法提供与“ZSS-120-09-S-D-1330”相匹配的价格&库存,您可以联系我们找货
ZSS-120-09-S-D-1330
  • 1+96.314221+12.45770
