LOW PROFILE, EXTREME
HIGH-POWER/SIGNAL COMBO
FEATURES & BENEFITS
• 30 A per power blade and 1 A per signal pin
MAX
• Low 7.5 mm profile design (right-angle) for
improved system airflow and space savings
30
• Double-stacked power blades per bank for
increased density and power
A
m
p
s
• Ideal for coplanar and perpendicular applications
• Rugged guide posts are standard for blind
mating assistance
• Socket available as vertical with press-fit tails
and right-angle through-hole; mates with terminal
or standard .062" (1.60 mm) PCB card
Standard Creepage*
5.63 mm
Standard Clearance*
2.69 mm
*Selectively loading contacts achieves customer
specific creepage and clearance requrements.
Contact asp@samtec.com
KEY SPECIFICATIONS (LPHT/LPHS)
PITCH
INSULATOR
MATERIAL
(12.00 mm) .472" (pwr)
(1.27 mm) .050" (sig)
Black LCP
TERMINAL
MATERIAL
PLATING
Signal: Brass
Au or Sn over
Power: Copper Alloy 50 µ" (1.27 µm) Ni
OPERATING
TEMP RANGE
VOLTAGE
RATING
MATING
CYCLES
LEAD-FREE
SOLDERABLE
40 °C to +105 °C
250 VAC /
500 VDC
250
(MFG Tested)
Yes
(RT1 & RT2
option)
Notes:
Series is rated up to 60 A per power bank.
Some lengths, styles and options are non-standard, non-returnable.
The Molex EXTreme LPHPower™ line is a second source to the Samtec LPHT/LPHS Series.
*EXTreme LPHPower™ is a trademark of Molex Incorporated.
F-224
samtec.com/extreme-lphpower
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
30 A SIGNAL/POWER COMBO SYSTEM
SERIES
LPHT
Terminal
POWER POSITIONS
Total, 2 per power bank
Total
–02, –04,
–06, –08, –10
–12,
–16, –20,
–24, –32
LPHS
Socket
SIGNAL
POSITIONS
PLATING
OPTION
TAIL
–L
GP
–VP1
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
= Vertical Press-fit
(LPHS only)
–RT1
= Right-angle Through-hole
(Use with (1.60 mm) .062" thick board)
–RT2
(Use with (2.36 mm) .093" thick board)
LPHT
Board Mates:
LPHS
POWER POSITIONS
SIGNAL
POSITIONS
A (–02)
A (–04)
A (–06)
A (–08)
A (–10)
–16
(33.97) 1.337
(45.97) 1.810
(57.97) 2.282
(69.97) 2.755
(81.97) 3.227
–20
(36.51) 1.437
(48.51) 1.910
(60.51) 2.382
(72.51) 2.855
(84.51) 3.327
–24
(39.05) 1.537
(51.05) 2.010
(63.05) 2.482
(75.05) 2.955
(87.05) 3.427
–32
(44.13) 1.737
(56.13) 2.210
(68.13) 2.682
(80.13) 3.155
(92.13) 3.627
A
(16.28)
.641
(7.49)
.295
B
(5.08)
View complete specifications at: samtec.com?LPHT
.200
LPHS
POWER POSITIONS
SIGNAL
(18.00)
POSITIONS A (–02)
.709
B (–02) A (–04) B (–04) A (–06) B (–06) A (–08) B (–08) A (–10) B (–10)
Board Mates:
LPHT
–16
(31.64)
1.918
(25.88)
1.019
(43.64)
1.718
(37.88)
1.491
(55.64)
2.191
(49.88)
1.964
(67.64)
2.633
(61.88)
2.436
(79.64)
3.135
(73.88)
2.909
–20
(34.18)
1.346
(28.42)
1.119
(46.18)
1.818
(40.42)
1.591
(58.18)
2.291
(52.42)
2.064
(77.18)
2.763
(64.42)
2.536
(82.18)
3.235
(76.42)
3.009
–24
(36.72)
1.446
(30.96)
1.219
(48.72)
1.918
(42.96)
1.691
(60.72)
2.391
(54.96)
2.164
(72.72)
2.863
(66.96)
2.636
(84.72)
3.335
(78.96)
3.109
–32
(41.80)
1.646
(36.04)
1.419
(53.80)
2.118
(48.04)
1.891
(65.80)
2.591
(60.04)
2.364
(77.80)
3.063
(72.04)
2.836
(89.80)
3.535
(84.04)
3.309
A
B
(7.49)
.295
(5.08)
.200
(18.00)
.709
(21.42)
.843
-VP
View complete specifications at: samtec.com?LPHS
-RT
A
F-224
LPHS-04-24-L-RT1-GP 价格&库存
很抱歉,暂时无法提供与“LPHS-04-24-L-RT1-GP”相匹配的价格&库存,您可以联系我们找货
