LST-122-07-T-D
LST-122-07-T-D
    SAMTEC(申泰)
LST-122-07-T-D 数据手册
F-215 SUPPLEMENT LST–112–07–G–D LST–120–07–G–D (2,54 mm) .100" LST SERIES SELF-MATING HERMAPHRODITIC STRIP SPECIFICATIONS Hermaphroditic self-mating combination header/socket system Mates with: LST For complete specifications see www.samtec.com?LST Insulator Material: Black Glass Filled Polyester Terminal Material: Phosphor Bronze Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Operating Temp Range: -55°C to +125°C with Gold -55°C to +105°C with Tin Insertion Depth: (3,68 mm) .145" to (6,35 mm) .250" Insertion Force: (Single contact only) 6 oz (1,67 N) avg Withdrawal Force: (Single contact only) 4 oz (1,11 N) avg Cycles: 100 with 10µ" (0,25 µm) Au RoHS Compliant: Yes Lead–Free Solderable: Wave Only APPLICATION Polarized (13,59) .535 MATED HEIGHT One part number for both socket and terminal (2,54 mm) .100" pitch (0,64 mm) .025" square post TYPE STRIP 1 NO. PINS PER ROW Locking feature increases unmating force and provides audible “click” when properly mated PLATING OPTION 07 RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality LST 02 thru 30 = Standard –F = Gold flash on contact area, Matte Tin on tail –G = 10µ" (0,25 µm) Gold on contact area, Gold flash on balance No. of Positions x (2,54) .100 + (0,51) .020 (2,54) .100 –T 02 = Matte Tin (2,54) .100 Note: Other Gold plating options available. Contact Samtec. (0,64) .025 SQ 01 (8,51) .335 (6,10) .240 (11,05) .435 (2,54) .100 (2,29) .090 (5,08) .200 (5,84) .230 Note: Some lengths, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. D
LST-122-07-T-D 价格&库存
很抱歉,暂时无法提供与“LST-122-07-T-D”相匹配的价格&库存,您可以联系我们找货
