F-215
TM
STRIP
40
PET–04–01–L–VT
PES–08–02–L–VT
(6,35 mm) .250"
PES, PET SERIES
40 A HIGH POWER HEADER & SOCKET
PES Mates with:
PET
PET Mates with:
PES, PESS
NO. PINS
PER ROW
PES
LEAD
STYLE
SPECIFICATIONS
For complete specifications
see www.samtec.com?PET
or www.samtec.com?PES
Insulator Material: Black LCP
Terminal Material: Copper Alloy
Plating: Sn or Au over
50µ" (1,27 µm) Ni
Operating Temp Range:
-55°C to +105°C with Tin
-55°C to +125°C with Gold
Voltage Rating:
725 VAC/1025 VDC
Wiping Distance (PES):
(0,38 mm) .015"
RoHS Compliant: Yes
Lead–Free Solderable: Yes
PINS
1
2
3
4
ALL
PET/PES
CURRENT RATING
(PER CONTACT)
58.7 A
48.5 A
41.1 A
38.0 A
29.4 A
–02, –04,
–06, –08
–01
–L
–VT
= 10µ" (0,25 µm)
Gold on contact,
Matte Tin on tail
= Vertical
–02
–T
= Use with
(3,18 mm) .125"
Thick PCB
= Matte Tin
–SD
= Screw
Down
(Right
Angle only)
– RA
= Right Angle
(Screw Down
option required)
(20,80) .819
(3,81) .150 DIA
(20,80)
.819
(12,00) .472
(4,40)
.173
A
(8,30)
.327
(4,44)
.175
(2,54) .100
(12,64)
.497
(5,54)
.218
–RA–SD
(2,54) .100
(0,64)
.025
(0,50) .020
(0,64)
.025
OTHER SOLUTIONS
A
LEAD
STYLE
A
–01
–02
(2,35) .093
(2,54)
.100
–VT
(3,95) .156
• Screw down
(right angle)
• Combination Signal/Power.
See PESC or PETC Series.
PET
NO. PINS
PER ROW
LEAD
STYLE
ALSO AVAILABLE
–01
(MOQ Required)
–02, –04,
–06, –08
• Locking Clip
(Manual placement
required)
• No Latch ears
• Other platings
Contact Samtec.
MATED HEIGHT
OTHER
OPTION
TAIL
OPTION
= Use with
(1,60 mm) .062"
Thick PCB
No. of positions x (6,35) .250 + (16,51) .650
(11,43)
.450
(2,04)
(6,35)
.080
.250
TYP
RECOGNITIONS
For complete scope
of recognitions see
www.samtec.com/quality
PLATING
OPTION
= Use with
(1,60 mm) .062"
Thick PCB
PLATING
OPTION
–L
= Vertical
–T
= Right Angle
(Screw Down
option
required)
(11,43) .450
(6,35)
(2,70) .106
.250 TYP
= Matte Tin
LEAD STYLE
A
–01
–02
(2,35) .093
–SD
= Screw
Down
(Right
Angle only)
– RA
(3,95) .156
(3,81)
.150 DIA
(14,62)
.575
(19 mm)
.748"
OTHER
OPTION
–VT
= 10µ" (0,25 µm)
Gold on contact,
Matte Tin on tail
–02
= Use with
(3,18 mm) .125"
Thick PCB
TAIL
OPTION
(14,50)
.571
A
(2,54)
.100
(0,50) .020
A
(0,64)
.025 (0,64)
.025
Note: Some sizes, styles
and options are non-standard,
non-returnable.
(2,54) .100
–VT
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
(5,69)
.224
(23,50) .925
–RA–SD
(2,54) .100
(5,54) .218
