(0.80 mm) .0315" PITCH • QRM8/QRF8 SERIES
QRM8
QRM8
Board Mates:
QRF8
QRF8
PINS PER ROW
NO. OF PAIRS
–018,
–036, –054
Cable Mates:
EQRD
(18 pairs per bank =
–D–DP)
SPECIFICATIONS
= Guide
Post
–GP
Leave blank for
Tray Packaging
–D-DP
–K
= Tape & Reel
–TR
= (5.00 mm)
.197" DIA
Polyimide
Film Pick &
Place Pad
LEAD
STYLE
1RRI%DQNV[
1RRI%DQNV[
–GP OPTION
–FR
= Full Reel
Tape & Reel
(must order
maximum
quantity per reel;
contact Samtec
for quantity
breaks)
A
B
–02
(4.81) (6.12)
.189 .241
–05
(7.81)
.307
–07
(9.78) (11.12)
.385 .438
(9.12)
.359
View complete specifications at: samtec.com?QRM8
QRF8
PINS PER ROW
NO. OF PAIRS
–026,
–052, –078
(52 total pins per
bank = –D)
–018,
–036, –054
(18 pairs per bank
= –D–DP)
LEAD
STYLE
–05.0
= 5 mm
Body
Height
–07.0
= 7 mm
Body
Height
PLATING
OPTION
–L
–S
= 30 µ" (0.76 µm)
Gold on contact,
Matte Tin on tail
TYPE
A
–D
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
OTHER
OPTIONS
= Differential
Pair
–05
(5.01)
.197
(1.04)
.041
–07
(7.01)
.276
No. of Banks x (24.80) .976 + (5.25) .206
–GP OPTION
View complete specifications at: samtec.com?QRF8
–TR
= Tape & Reel
(Not available
with –054 &
–078 positions)
= (5.00 mm)
.197" DIA
Polyimide
Film Pick &
Place Pad
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
(Not available
with –054 &
–078 positions)
MATED HEIGHT*
No. of Banks x (24.80) .976 - (2.00) .078
A
Leave blank for
Tray Packaging
–K
–D-DP
(4.60)
.181
LEAD
STYLE
”X”R
= Guide Post
No. of Banks x (24.80) .976 + (3.57) .140
(1.25) A
.049
–GP
= SingleEnded
(4.60)
.181
HIGH MATING
CYCLES
F-224
”X”R
10 YEAR MFG
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
= SingleEnded
= Differential
Pair
–S
OTHER
OPTIONS
1RRI%DQNV[
EXTENDED LIFE
PRODUCT
(1.20 mm)
.047"
Nominal
Wipe
A
= 30 µ"
(0.76 µm)
Gold on
contact,
Matte Tin
on tail
–07.0
PROCESSING
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max
(018-026)
(0.15 mm) .006" max
(036-078)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
Board Stacking:
For applications requiring
more than two connectors
contact ipg@samtec.com
–05.0
= 5 mm Body
Height
TYPE
–D
= 10 µ"
(0.25 µm)
Gold on
contact,
Matte Tin
on tail
= 7 mm Body
Height
Insulator Material:
Black LCP
QRM8 Terminal Material:
Phosphor Bronze
QRF8 Contact Material:
BeCu
Ground Plane Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Current Rating:
Contact:
2.2 A per pin (2 pins powered)
Ground Plane:
8.5 A per ground plane
(1 ground plane powered)
Operating Temp Range:
-55 °C to +125 °C
Voltage Rating:
215 VAC
Max Cycles:
100
–L
= 2 mm
Body Height
Not available
with –054
& –078
Positions)
(52 total pins per
bank = –D)
QRM8/QRF8
PLATING
OPTION
–02.0
–026,
–052, –078
Board Mates:
QRM8
LEAD
STYLE
QRM8 LEAD STYLE
QRF8
LEAD
STYLE
-02.0
-05.0
-07.0
–05
(7.00) .276
(10.00) .394
(12.00) .472
–07
(9.00) .354
(12.00) .472
(14.00) .551
*Processing conditions will affect mated height.
See SO Series for board space tolerances.
samtec.com/QRate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
QRF8-052-07.0-L-D-A 价格&库存
很抱歉,暂时无法提供与“QRF8-052-07.0-L-D-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+156.002331+20.19228
- 10+147.6975710+19.11735
- 25+142.1599325+18.40058
- 50+138.7228050+17.95569
- 100+137.47015100+17.79356
