SIB-126-02-F-S-LC
SIB-126-02-F-S-LC
    SAMTEC(申泰)
    .100 SINGLE INTERFACE BEAM ASSEM
SIB-126-02-F-S-LC 数据手册
F-215 (Rev 07AUG15) SIR1–15–L–S–A SIB–120–02–F–S (2.54 mm) .100" SIB, SIR1 SERIES ONE PIECE INTERFACES SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SIB SIB 1 Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1.27 µm) Ni Current Rating: 2.6 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +125°C RoHS Compliant: Yes NO. OF POSITIONS PLATING OPTION 02 S OPTION –LC –F 02 thru 30 = Locking Clip (Manual placement required) = Gold flash on contact, Matte Tin on tail (Per Row) No. of positions x (2.54) .100 (4.45) .175 (1.13) .044 (8.51) .335 Processing: Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (02-19) (0.15 mm) .005" max (20-30) 01 (1.42) .056 (0.38) .015 – LC RECOGNITIONS (2.54) .100 For complete scope of recognitions see www.samtec.com/quality Note: The SIB Series is intended for vertical mating only. (5.27) .207 (3.81) .150 Note: Some sizes, styles and options are non-standard, non-returnable. SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SIR1 SIR1 Insulator Material: Black LCP Contact Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1.27 µm) Ni Current Rating: 2.8 A per pin (1 pin powered per row) Weld Tab: Phosphor Bronze RoHS Compliant: Yes OPTION –A = Alignment Pin = 10µ" (0.25 µm) Gold on contact, Matte Tin on tail (Per Row) –S = 30µ" (0.76 µm) Gold on contact, Matte Tin on tail No. of positions x (2.54) .100 + (2.54) .100 –K = (4.00 mm) .157" DIA Polyimide Film Pick & Place Pad –TR (5.08) .200 Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max For complete scope of recognitions see www.samtec.com/quality S –L –03, –05, –10, –15 Processing: RECOGNITIONS PLATING OPTION NO. OF POSITIONS = Tape & Reel 01 (2.54) .100 (2.54) .100 (6.00) .236 (0.25) .010 (4.45) .175 No. of positions x (2.54) .100 + (1.016) .040 (0.50) .020 (1.40) .055 (2.25) .089 WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. Note: Some sizes, styles and options are non-standard, non-returnable.
SIB-126-02-F-S-LC 价格&库存
很抱歉,暂时无法提供与“SIB-126-02-F-S-LC”相匹配的价格&库存,您可以联系我们找货
SIB-126-02-F-S-LC
  • 8+93.318618+12.06136
