SMM-116-02-SM-D-K
SMM-116-02-SM-D-K
    SAMTEC(申泰)
    2MM SOCKET STRIPS
SMM-116-02-SM-D-K 数据手册
F-218 (Rev 05OCT17) SMM–135–02–L–D–K SMM–108–02–L–S SMM–115–02–S–D SMM–110–02–L–S (2.00 mm) .0787" SMM SERIES TIGER EYE SOCKET STRIP ™ Available with optional Pick & Place Pads Board Mates: TMM, TMMH, MTMM, MMT, LTMM, TW, PTT, ZLTMM SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?SMM High-reliability Tiger Eye™ contacts (Four point redundancy) Cable Mates: TCMD Insulator Material: Black Liquid Crystal Polymer Contact Material: BeCu Plating: Sn or Au over 50 µ" (1.27 µm) Ni Current Rating (TMM/SMM): 3.2 A per pin (2 pins powered) Voltage Rating: 350 VAC Operating Temp Range: -55 °C to +125 °C Insertion Depth: (3.05 mm) .120" to (3.25 mm) .128" Max Cycles: 100 with 10 µ" (0.25 µm) Au RoHS Compliant: Yes 10 YEAR MFG WITH 30 µ" GOLD (3.56 mm) .140" EXTENDED LIFE PRODUCT HIGH MATING CYCLES (2.00 mm) .0787" pitch PROCESSING Lead–Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max SMM 1 NO. PINS PER ROW 02 PLATING OPTION ROW OPTION OTHER OPTION RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality –F = Gold flash on contact, Matte Tin on tail 02 thru 40 –L FILE NO. E111594 = 10 µ" (0.25 µm) Gold on contact, Matte Tin on tail No. of positions x (2.00) .0787 ALSO AVAILABLE • Locking clip (Manual placement required) • Other platings Contact Samtec. (2.00) .0787 01 POLARIZING KEY = 30 µ" (0.76 µm) Gold on contact, Matte Tin on tail (2.00) .0787 –S Row (3.81) .150 x (7.62) .300 –D Row (5.71) .225 x (10.01) .394 80 (2.00) (4.00) .0787 .158 79 (3.56) .140 (0.51) .020 (4.32) .170 (6.30) .248 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM –K = (5.50 mm) .217" DIA Polyimide Film Pick & Place Pad (2 positions minimum, –02 thru –05 requires –TR) –P –TR –P 01 (0.38) .015 –“XX” = Polarized Position = Plastic Pick & Place Pad (–02 thru –05 requires –TR) 02 Specify PK–01–07 for polarizing key (Available in wheels of six each). Also polarizes TCSD Series IDC Cable. Note: Some lengths, styles and options are non-standard, non-returnable. –D = Double Row –S 40 (MOQ Required) –S = Single Row All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. = Tape & Reel Packaging (27 positions maximum)
SMM-116-02-SM-D-K 价格&库存
很抱歉,暂时无法提供与“SMM-116-02-SM-D-K”相匹配的价格&库存,您可以联系我们找货
