TFC-115-11-F-D
TFC-115-11-F-D
    SAMTEC(申泰)
    插件,P=1.27mm
    线对板针座 间距P=1.27mm 30Pin(2x15P) 直插
TFC-115-11-F-D 数据手册
F-215 TFC–120–22–L–D–A ™ TFC–145–02–L–D–A SYSTEM TFC–110–12–L–D–A (1,27 mm) .050" TFC SERIES COST SAVING RELIABLE HEADER SPECIFICATIONS Shrouded body for blind mating Mates with: SFC, SFSD, SFSDT For complete specifications and recommended PCB layouts see www.samtec.com?TFC (1,27 mm x 1,27 mm) .050" x .050" micro pitch MATED HEIGHTS Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50µ" (1,27 µm) Ni Current Rating: 2.9 A per pin (1 pin powered per row) Voltage Rating: 350 VAC mated with SFC Operating Temp Range: -55°C to +125°C RoHS Compliant: Yes LEAD STYLE TFC SFC MATED HEIGHT* – 01 – 11 –T1 – 21 – 31 – 02 – 12 –T2 – 22 – 32 (5,97) .235 (7,75) .305 (9,53) .375 (11,43) .450 Choice of eight body heights (6,35) .250 (8,13) .320 (9,91) .390 (11,81) .465 *Processing conditions will affect mated height. Processing: Surface Mount or Through-hole Alignment pin option available Lead-Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max (03-25) (0,15 mm) .006" max (30-50) RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality TFC 1 NO. PINS PER ROW LEAD STYLE PLATING OPTION OPTION D –X1 FILE NO: 090871_0_000 –RA = Throughhole 03, 04, 06, 08 = Gold flash on post, Matte Tin on tail (Lead Style –01 & –02 only) 05, 07, 10, 15, 20, 25, 30, 35, 40, 45, 50 ALSO AVAILABLE (MOQ Required) –X2 = Surface Mount = 10µ" (0,25 µm) Gold on post, Matte Tin on tail • Other sizes Contact Samtec. (1,14) .045 (1,27) .050 x No. of Positions + (3,18) .125 (1,27) .050 x No. of Positions + (0,64) .025 02 (2,79) .110 (1,27) .050 DIA –A OPTION TH LEAD STYLE –01 –11 (3,94) .155 ILABILITY EL AVA TAPE & RE arges. No tooling chthe lesser of is r de or Minimum antity or 125 pieces. a full reel quantity above minimum. Order any qudesign, manufacture. In-house turn-around. Quick s (5,72) .225 –21 (1,91) .075 ion for specificat Call Samtecring information. and orde 01 (1,27) .050 TYP (1,27) .050 –31 (1,91) .075 (0,51) .020 –RA OPTION (0,46) .018 DIA TYP B A A (1,27) .050 (2,44) .096 SMT LEAD STYLE –02 –12 –22 –32 Note: Some sizes, styles and options are non-standard, non-returnable. –A = Alignment Pin –L (Standard sizes) (3,43) .135 = Right Angle (–01 only) –F (0,36) .014 TYP WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. –LC A B (5,59) .220 (7,37) .290 (9,14) .360 (11,05) .435 (3,38) .133 (3,30) .130 A B (5,72) .225 (7,49) .295 (9,27) .365 (11,18) .440 (3,38) .133 (3,30) .130 = Locking Clip (Manual Placement required) (not available with –RA) –K = (6,75 mm) .266" DIA Polyimide film Pick & Place Pad –P = Plastic Pick & Place Pad ( 5 positions min.) –TR = Tape & Reel (–X2 only)
TFC-115-11-F-D 价格&库存
很抱歉,暂时无法提供与“TFC-115-11-F-D”相匹配的价格&库存,您可以联系我们找货
TFC-115-11-F-D
  • 25+24.1115725+3.11499
