F-215
TMMH–125–04–L–DV–EP
TMMH–135–04–F–DV–LC
(2,00 mm) .0787"
FLEXIBLE SMT HEADER
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?TMMH
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Sn or Au over
50µ" (1,27 µm) Ni
Current Rating (TMMH/ESQT):
4.5 A per pin
(1 pin powered per row)
Current Rating (TMMH/SQT):
5.1 A per pin
Operating Temp Range:
-55°C to +105°C with Tin;
-55°C to +125°C with Gold
Voltage Rating:
500 VAC mated with SQW
RoHS Compliant:
Yes
FLEX SHROUD
Mates with:
CLT, SQT, SQW, ESQT,
TLE, SMM, MMS, TCSD
OPTIONS
–ES OPTION
–A OPTION
–M OPTION
–EP OPTION
OTHER SOLUTIONS
ThroughHole
–EL OPTION
–TR OPTION
–EC OPTION
2 mm Shunt
Specify 2SN–BK–G for
2 mm shunt with Gold plating. (1,95)
.077
Processing:
Lead–Free Solderable:
Yes
SMT Lead Coplanarity:
(0,10 mm) .004" max
TMMH
LEAD
STYLE
NO. PINS
PER ROW
1
(4,45)
.175
(3,99)
.157
PLATING
OPTION
RECOGNITIONS
For complete scope of
recognitions see
www.samtec.com/quality
Specify
LEAD STYLE
from chart
03 thru 50
–F
= Gold flash
on post,
Matte Tin on tail
–L
OPTION
Z
(2,92)
.115
(4,70)
– EC
.185
–EP & –EPC (6,10)
.240
–EL & –EBC (4,45)
.175
–ES
LEAD
STYLE
A
MATES
WITH
–04
SQT, SQW,
(3,20) ESQT, TLE,
.126 SMM, MMS,
TCSD
(1,91)
CLT
.075
–05
(1,65)
.065
–01
= 10µ" (0,25 µm)
Gold on post,
Matte Tin on tail
–T
= Matte Tin
No. of positions x (2,00) .0787 + Z
(2,00)
.0787
100
02
(1,40)
.055
(6,35)
.250
01
(1,09)
.043
DIA
99
–A
ALSO AVAILABLE
(MOQ Required)
• Other platings
Contact Samtec.
(4,00)
.157
(2,00)
.0787
(10,16)
.400
x
(6,35)
.250
A
(0,64)
.025
(2,51)
.099
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
(0,51)
.020
SQ
(2,00) .0787
(7,04)
.277
–M
(Shrouded options removed for clarity)
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
(1,42)
.056
– LC
TMMH–118–04–F–DV–EL
TMMH–110–01–F–DV–A
TMMH–110–01–F–DV
TMMH–125–01–L–DV
TMMH–114–04–L–DV
TMMH SERIES
Optional end shrouds
with board lock
(2,00 mm)
.0787"
Surface mount
(2,00 mm)
.0787"
(2,00 mm) .0787"
Optional alignment pins
or locking clips
DV
OTHER OPTIONS
FLEX SHROUD OPTIONS
All Flex Shroud options require 9 pins/row minimum
(For board-to-board interfaces. Will not mate with TCSD)
–“XXX”
= Polarized Position. Specify position of omitted pin
–ES
LEAD
STYLE
–01
–A
= End Shroud
(For best cost also see TSH Series)
X
Y
= Alignment Pin
(3 positions minimum)
(Not available with -LC)
–EC
(5,84) (4,45)
.230 .175
–LC
= End Shroud with Locking Clip
(Manual placement required)
–04 & (4,50) (3,02)
–05 .177 .119
= Locking Clip
(5 positions minimum)
(Not available with -A)
–EP
(4,00)
.157
= End Shroud with Guide Post
–M
–EL
= Pick & Place Pad
= End Shroud with Board Lock
(Boards are positively locked and cannot be unmated)
(1,32)
.052
–TR
–EBC
= End Shroud with Board Lock and Locking Clip
(1,41)
.056
– EBC
–EPC
= End Shroud with Guide Post and Locking Clip
(1,17)
.046
(1,91)
.075
DIA
Y
(2,44)
.096
– EL
ILITY
L AVAILAB
TAPE & REE
(3,20)
.126
X
= Tape & Reel Packaging
(36 positions maximum)
(Flex Shroud options not available
except –ES, –EP & –EL)
(1,32)
.052
X
– ES
– EC
– EP
arges.
No tooling chthe lesser of
der is
or
um
m
pieces.
ini
M
antity or 125
a full reel quantity above minimum.
qu
y
an
r
acture.
Orde
sign, manuf
In-house de turn-around.
Quick
(1,32)
.052
ons
for specificati
Call Samtec ng information.
and orderi
– EPC
WWW.SAMTEC.COM
