TMMH-123-01-G-DV
TMMH-123-01-G-DV
    SAMTEC(申泰)
    2MM LOW PROFILE STRIPS
TMMH-123-01-G-DV 数据手册
F-215 TMMH–125–04–L–DV–EP TMMH–135–04–F–DV–LC (2,00 mm) .0787" FLEXIBLE SMT HEADER SPECIFICATIONS For complete specifications and recommended PCB layouts see www.samtec.com?TMMH Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn or Au over 50µ" (1,27 µm) Ni Current Rating (TMMH/ESQT): 4.5 A per pin (1 pin powered per row) Current Rating (TMMH/SQT): 5.1 A per pin (1 pin powered per row) Operating Temp Range: -55°C to +105°C with Tin; -55°C to +125°C with Gold Voltage Rating: 500 VAC mated with SQW RoHS Compliant: Yes FLEX SHROUD Mates with: CLT, SQT, SQW, ESQT, TLE, SMM, MMS, TCSD OPTIONS –ES OPTION –A OPTION –M OPTION –EP OPTION OTHER SOLUTIONS ThroughHole –EL OPTION –TR OPTION –EC OPTION 2 mm Shunt Specify 2SN–BK–G for 2 mm shunt with Gold plating. (1,95) .077 Processing: Lead–Free Solderable: Yes SMT Lead Coplanarity: (0,10 mm) .004" max TMMH LEAD STYLE NO. PINS PER ROW 1 (4,45) .175 (3,99) .157 PLATING OPTION RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality Specify LEAD STYLE from chart 03 thru 50 –F = Gold flash on post, Matte Tin on tail –L OPTION Z (2,92) .115 (4,70) – EC .185 –EP & –EPC (6,10) .240 –EL & –EBC (4,45) .175 –ES LEAD STYLE A MATES WITH –04 SQT, SQW, (3,20) ESQT, TLE, .126 SMM, MMS, TCSD (1,91) CLT .075 –05 (1,65) .065 –01 = 10µ" (0,25 µm) Gold on post, Matte Tin on tail –T = Matte Tin No. of positions x (2,00) .0787 + Z (2,00) .0787 100 02 (1,40) .055 (6,35) .250 01 (1,09) .043 DIA 99 –A ALSO AVAILABLE (MOQ Required) • Other platings Contact Samtec. No. of positions x (2,00) .0787 (4,00) .157 (2,00) .0787 (10,16) .400 x (6,35) .250 A (0,64) .025 (2,51) .099 Note: Some lengths, styles and options are non-standard, non-returnable. (0,51) .020 SQ (2,00) .0787 (7,04) .277 –M (Shrouded options removed for clarity) WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (1,42) .056 – LC TMMH–118–04–F–DV–EL TMMH–110–01–F–DV–A TMMH–110–01–F–DV TMMH–125–01–L–DV TMMH–114–04–L–DV TMMH SERIES Optional end shrouds with board lock (2,00 mm) .0787" Surface mount (2,00 mm) .0787" (2,00 mm) .0787" Optional alignment pins or locking clips DV OTHER OPTIONS FLEX SHROUD OPTIONS All Flex Shroud options require 9 pins/row minimum (For board-to-board interfaces. Will not mate with TCSD) –“XXX” = Polarized Position. Specify position of omitted pin –ES LEAD STYLE –01 –A = End Shroud (For best cost also see TSH Series) X Y = Alignment Pin (3 positions minimum) (Not available with -LC) –EC (5,84) (4,45) .230 .175 –LC = End Shroud with Locking Clip (For best cost also see TSH Series) (Manual placement required) –04 & (4,50) (3,02) –05 .177 .119 = Locking Clip (5 positions minimum) (Not available with -A) (Manual placement required) –EP (4,00) .157 = End Shroud with Guide Post –M –EL = Pick & Place Pad (5 positions minimum) = End Shroud with Board Lock (Boards are positively locked and cannot be unmated) (1,32) .052 –TR –EBC = End Shroud with Board Lock and Locking Clip (Boards are positively locked and cannot be unmated) (1,41) .056 – EBC –EPC = End Shroud with Guide Post and Locking Clip (Manual placement required) (1,17) .046 (1,91) .075 DIA Y (2,44) .096 – EL ILITY L AVAILAB TAPE & REE (3,20) .126 X = Tape & Reel Packaging (36 positions maximum) (Flex Shroud options not available except –ES, –EP & –EL) (1,32) .052 X – ES – EC – EP arges. No tooling chthe lesser of der is or um m pieces. ini M antity or 125 a full reel quantity above minimum. qu y an r acture. Orde sign, manuf In-house de turn-around. Quick (1,32) .052 ons for specificati Call Samtec ng information. and orderi – EPC WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice.
TMMH-123-01-G-DV 价格&库存
很抱歉,暂时无法提供与“TMMH-123-01-G-DV”相匹配的价格&库存,您可以联系我们找货
TMMH-123-01-G-DV
