F-218 (Rev 10OCT17)
TSM–116–02–S–DV–LC
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
TSM–121–01–T–SV
HIGH MATING
CYCLES
(2.54 mm) .100"
SMT .025" SQ POST HEADER
Board Mates:
SSW, SSQ, SSM, BSW, ESW,
ESQ, BCS, SLW, CES, HLE
TSM
NO. PINS
PER ROW
1
Cable Mates:
IDSS, IDSD, SMSD, SMSS
02 thru 36
SPECIFICATIONS
For complete specifications
and recommended PCB layouts
see www.samtec.com?TSM
–F
= Gold flash on post,
Matte Tin on tail
(5.84 mm) Post Height
–01 = .230"
(Mates with SSW, BCS, SSM, IDSS, IDSD)
Insulator Material:
Black Liquid Crystal Polymer
Terminal Material:
Phosphor Bronze
Plating:
Au or Sn over
50 µ" (1.27 µm) Ni
Operating Temp Range:
-55 °C to +105 °C with Tin;
-55 °C to +125 °C with Gold
Voltage Rating:
475 VAC -SV/-DV mated with
BCS or SSM
RoHS Compliant: Yes
Post
Height
–L
= 10 µ" (0.25 µm) Gold on post,
Matte Tin on tail
.320" (8.13 mm) Post Height
–02 = (Mates
with SSM -DH)
–03
–S
= 30 µ" (0.76 µm) Gold on post,
Matte Tin on tail
= .420" (10.67 mm) Post Height
(For Bottom Mount & Pass Through)
–T
.120" (3.05 mm) Post Height
–04 = (Mates
with SLW, CES, HLE)
MATES
CURRENT RATING
(PER PIN)
TSM/SSW
4.7 A
TSM/SSM
5.4 A
TSM/HLE
4.1 A
ROW
OPTION
PLATING
OPTION
LEAD
STYLE
= Matte Tin
–SV
= Single Row Vertical Pin
(2.54) .100 x No. of positions
36
2 PINS POWERED
(2.54)
.100
PROCESSING
(2.54)
.100
Lead–Free Solderable: Yes
-DH/-SH Lead Coplanarity:
(0.15 mm) .006" max (02-36)*
-DV/-SV Lead Coplanarity:
(0.10 mm) .004" max (02-05)
(0.13 mm) .005" max (06-10)*
(0.15 mm) .006" max (11-36)*
*(.004" stencil solution
may be available; contact
IPG@samtec.com)
(0.64)
.025
SQ
Post
Height
(2.54)
.100
SSM
–SH
TSM
= Single Row
Horizontal Pin
For complete scope
of recognitions see
www.samtec.com/quality
HORIZONTAL
(1.40)
.055
FILE NO. E111594
(1.78)
.070
Note: Some lengths,
styles and options are
non-standard, non-returnable.
36
01
(3.05)
.120
ALSO AVAILABLE
• Edge Mount and
Locking Clips for –SV
• Solder Locks for –DH and
Shrouds for –DV
• Other platings
Contact Samtec.
(3.81)
.150
APPLICATIONS
RECOGNITIONS
(MOQ Required)
(1.14)
.045
REF
01
(1.58)
.062
DIA
(2)
Optional Alignment Pin (–A)
(No. of positions x (2.54) .100) – (5.08) .200
(0.64)
.025
SQ
Post
Height
(2.03)
.080
(2.54)
.100
–01= (4.57) .180
–02, –03, –04 = (4.82) .190
Due to technical progress, all designs, specifications and components are subject to change without notice.
WWW.SAMTEC.COM
All parts within this catalog are built to Samtec’s specifications.
Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply.
TSM–115–01–T–SH–A
TSM–110–01–T–DV
TSM–126–02–L–DH–K
TSM SERIES
OTHER OPTIONS
–A
= Alignment Pin
metal or plastic
at Samtec discretion
(Not available
with –TM or –MT)
(02 positions min.)
(Not available with –LC)
–LC
= Locking Clip
(Not available with –TM)
(3 positions min.)
(Not available with –A)
(Manual placement
required)
–K
–P
= (6.50 mm) .256" DIA
Polyimide Film
Pick & Place Pad
(–DV: 4 positions minimum
without –TR; 2 & 3 positions
available with –TR)
(–SH: 4 positions
minimum without –TR;
2 & 3 positions
available with –TR)
–“XXX”
= Polarized
Position
(–DH: 5 positions
minimum without –TR)
(6.35)
.250
(–SV: 4 positions
2 & 3 positions
available with –TR)
–SH & –DH
–DV
–TM
02 thru 30 positions only
72
(2.54) (5.08)
.100 .200
(1.14)
.045
REF
71
(0.64) .025 SQ
(2.54) .100
(13.27)
.050
= Triple Row Vertical Mixed Technology (Style –01 only)
01
Not available with –MT or –TM
–SV
= Double Row Vertical Pin
02
= Tape & Reel Packaging
–SV = 02-22 positions
–DV = 02-28 positions
–SH = 02-30 positions
–DH = 02-29 positions
(6.86)
.270
(–SH: 4 positions
2 & 3 positions
available with –TR)
(–DH: 4 positions
minimum
without –TR)
–TR
(4.06)
.160
= Plastic Pick & Place Pad
03
(2.54) .100 X No. of positions
90
(2.54)
.100
(2.54)
.100
(2.79)
.110
(1.58) .062 DIA
(No. of positions -2) x (2.54) .100)
–A Option
01
(3.81)
.150
–LC Option
–MT
= Mixed Technology Pin
(Style –01, –02 or –03 only)
02
72
02
(2.54)
.100
01
(1.58)
.062 DIA(2)
(No. of positions x
(0.64)
.025
72
(6.10)
.240
(2.54) (6.10)
.100 .240
71
71
01
(1.78)
.070
(2.54)
.100
(2.54)
.100
(2.54)
.100
(2.54)
.100
(3.68)
.145
(2.54)
.100
(0.64)
.025
Post
Height
(7.87)
.310
(3.56)
.140
(11.43)
.450
–DH
(1.78)
.070 (1.40)
.055
88
(0.64) .025 SQ
(2.54) .100
= Double Row Horizontal Pin
Optional
Alignment
Pin (–A)
Post
Height
(2.54)
.100 (7.62)
.300
Post
Height
(1.52)
.060
(7.87)
.310
(1.16) .046
(1.16) .046
WWW.SAMTEC.COM
Post
Height
TSM-119-02-L-SH-A-P 价格&库存
很抱歉,暂时无法提供与“TSM-119-02-L-SH-A-P”相匹配的价格&库存,您可以联系我们找货
