X2510WV-11-N0SN
X2510WV-11-N0SN
    XKB(中国星坤)
    插件,P=2.54mm
    线对板针座 1x11P 直插 间距:2.54mm
X2510WV-11-N0SN 数据手册
3.4[0.134]±0.2 11.4[0.449] 3.0[0.118]±0.15 Specifications: 规格: Voltage rating:250V AC/DC 额定电压:250V AC/DC Current rating: 3A AC / DC 额定电流: 3A AC / DC Withstanding voltage: 1000V AC/minute 耐压电压:1000V AC/minute Temperature range:-25℃~+85℃ 温度范围:-25℃~+85℃ Insulation resistance:≥1000MΩ 绝缘电阻:≥1000MΩ Contact resistance:≤10mΩ 接触电阻:≤10mΩ After environment testing: ≤20mΩ 环境试验后: ≤20mΩ X2510 W V - XX - N0 SN ① ②③ ④ ⑤ ⑥ ①Series No. ②Category: W-WAFER ③Welding Board Angle: V-180° ④Row No.-Pin No. XX-Single Row ⑤Material: N0-PA66 94V-0 ⑥Planting Category SN-Bright Tin Plating 2.54[0.100]±0.08 0.63[0.025] 5.8[0.228]±0.2 A±0.2 XKB: B±0.3 Dimensions(mm) Poles A n-Ø0.9[0.035] 2.54[0.100] PCB PCBLAYOUT X X X MARK DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com REVISED APPROVED B 2 2.54 5.08 3 5.08 7.62 4 7.62 10.16 5 10.16 12.70 6 12.70 7 Dimensions(mm) Poles A B 22.86 25.4 11 25.4 27.94 12 27.94 30.48 13 30.48 33.02 15.24 14 33.02 35.56 15.24 17.78 15 35.56 38.10 8 17.78 20.32 9 20.32 22.86 10 X2510WV-XX-N0SN Nylon 66 UL 94V-0 Brass Tin-Plated X2510H PART N0 Material Material(Pin) Finish(Pin) Mates With XKB Housing ANGLAR L≤ 4 4
X2510WV-11-N0SN 价格&库存
很抱歉,暂时无法提供与“X2510WV-11-N0SN”相匹配的价格&库存,您可以联系我们找货
