8
512
4-Conductor Modular PCB Connectors
Pin Spacing: 5.75 mm
243 Series
ompact, 4-conductor modular PCB connectors with PUSH WIRE®
C
connection
Can be assembled to connector strips via dovetail joints
Simple push-in termination for solid conductors
Four entries for power supply and potential distribution
uick and easy PCB replacement, without disrupting looped-through
Q
potentials
Technical data:
Pin Spacing
Ratings per
Overvoltage category
Pollution degree
Rated voltage
Rated surge voltage
Nominal current
Approvals per
Use group UL 1059
Rated voltage
Nominal current UL
Nominal current CSA
5.75 mm
0.226 in.
IEC/EN 60664-1
III
III
II
3
2
2
250 V 320 V 630 V
4 kV
4 kV
4 kV
6A
6A
6A
UL/CSA
B
C
D
150 V
150 V
7A
7A
7A
7A
Conductor and solder pin data:
Connection technology
Conductor size: solid
AWG
Strip length
Conductor entry angle
Solder pin: length/diameter
Solder pin: drilled hole diameter
PUSH WIRE®
4 x 0.5 … 1.0 mm Ø
4 x 24 … 18 “sol.”
5 … 6 mm / 0.20 … 0.24 in.
0° to PCB
4.5 mm / 1.0 mm
1.2±0.05 mm
Material data:
Material group
Insulating material
Flammability class per UL 94
Lower/Upper limit temperature
Clamping spring material
Contact plating
243 Series accessory:
I
Polyamide 66 (PA 66)
V0
-60 °C / +105 °C
Copper alloy
tin-plated
Additional approvals and corresponding ratings can be found at www.wago.com.
Marking accessories
For additional technical information, see Section 13.
Page:
570
很抱歉,暂时无法提供与“243-724”相匹配的价格&库存,您可以联系我们找货
