BSW-135-04-L-D-S
BSW-135-04-L-D-S
    SAMTEC(申泰)
    BOTTOM MOUNT STRIPS
BSW-135-04-L-D-S 数据手册
BOTTOM MOUNT SOCKET STRIPS (2.54 mm) .100" PITCH • BSW SERIES BSW Mates: TSW, MTSW, HTSW, MTLW, TSM, EW, ZW, HW, DW, PHT BSW - NO. PINS PER ROW 1 - LEAD STYLE 02 thru 36 ­­– 04 Insulator Material: Black Thermoplastic Insulation Resistance: 5000 MΩ min Contact Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin Withstanding Voltage: 1000 VRMS @ 60 Hz Insertion Depth: (3.68 mm) .145" to (6.35 mm) .250" plus board thickness ­­­­– L = Low Insertion Force ROW OPTION ­­–S = 10 µ" (0.25 µm) Gold contact, Matte Tin on tail ­­–24 • Bottom mount socket strips accept .025" SQ terminals. • Ideal for soldering and plugging from the same side of the board. • For low profile connections and high temperature soldering. - PLATING OPTION = Standard Lead FEATURES SPECIFICATIONS - = Single Row ­­– D = Double Row –G = 20 µ" (0.51 µm) Gold contact, Gold Flash on tail ­–T = Matte Tin (Not available with Low Insertion Force) 1RRI3RV;          —S   ROW OPTION Z –S (4.31) .170 –D (4.32) .170 —D = PROCESSING Lead-Free Solderable: Wave only   —S —D ALSO AVAILABLE MOQ Required Other Platings APPLICATIONS BSW (SINGLE ROW) BSW (DOUBLE ROW) COMPONENT SIDE EW (SINGLE ROW) PC BOARD SOLDER SIDE PC BOARD Note: Some lengths, styles and options are non-standard, non-returnable. F-224 (Rev 10JAN24) TSW (SINGLE ROW) TSW (DOUBLE ROW) BSW (SINGLE ROW) samtec.com?BSW Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
BSW-135-04-L-D-S 价格&库存
很抱歉,暂时无法提供与“BSW-135-04-L-D-S”相匹配的价格&库存,您可以联系我们找货
