RUGGED RELIABLE
MICRO SOCKETS
(1.00 mm) .0394" PITCH • CLM/MLE SERIES
CLM
Mates:
FTM, FTMH, MW
CLM
-1
MLE
- 02 -
NO. PINS
PER ROW
02 thru 50
Mates:
FTM, FTMH, MW
–F
PROCESSING
= Bottom Entry
(Required for bottom entry)
–K
–L
= (3.50 mm) .138" DIA
Polyimide film
Pick & Place Pad
(7 positions minimum)
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
PIN/ROW
No. of positions x (1.00) .03937
+ (0.318) .0125
04-15
(3.56) .140
16-50
(7.11) .280
–PA
= Pick & Place Pad with
integral Alignment Pin
–TR
= Tape & Reel
–FR
= Full Reel Tape & Reel
(must order maximum
quantity per reel;
contact Samtec for
quantity breaks)
–PA
(3.81)
.150
(2.26)
.089
(2.12)
.084
–P
MLE
-1
- 01 -
NO. PINS
PER ROW
02 thru 50
PLATING
OPTION
DV
–G
OPTIONS
–A
= 10 µ"
(0.25 µm)
Gold
= Alignment Pin
(3 positions minimum)
Metal or plastic
at Samtec discretion
–K
= (4.00 mm) .1575" DIA
Polyimide film
Pick & Place Pad
(5 positions minimum)
MOQ Required
No. of positions
x (1.00) .03937 + (0.20) .008
Alignment pin
Other Gold plating options
–P
= Metal Pick & Place Pad
(3.07)
.121
–TR
= Tape & Reel
10 YEAR MFG
WITH 30 µ" GOLD
EXTENDED LIFE
PRODUCT
F-224
= Pick & Place Pad
(8.26) .325
by A
ALSO AVAILABLE
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
–P
A
(2.54)
.100
Lead-Free Solderable:
Yes
SMT Lead Coplanarity:
(0.10 mm) .004" max (02-25)
(0.15 mm) .006" max (26-50)*
*(.004" stencil solution
may be available; contact
ipg@samtec.com)
HIGH MATING
CYCLES
OPTIONS
–BE
= Gold flash on
contact,
Matte Tin on tail
SPECIFICATIONS
Insulator Material: Black LCP
Contact Material:
CLM: Phosphor Bronze
MLE: BeCu
Plating:
CLM: Au or Sn over
50 µ" (1.27 µm) Ni
MLE: Au over 10 µ" (0.25 µm) Ni
Current Rating (CLM/FTM):
3.1 A per pin
(2 pins powered)
Current Rating (MLE/FTM):
2.9 A per pin (2 pins powered)
Operating Temp Range:
-55 °C to +125 °C
Max Cycles:
CLM: 100 with 10 µ" (0.25 µm) Au
Voltage Rating:
CLM: 270 VAC
MLE: 310 VAC
Insertion Depth:
CLM:
Top Entry = (1.40 mm) .055" min.,
Bottom Entry =
(2.41 mm) .095" min.
(Add board thickness for
correct post OAL)
MLE:
(1.63 mm) .064" to
(3.18 mm) .125" with
(0.38 mm) .015" wipe,
pass-through, or (2.44 mm) .096"
minimum for bottom entry
-D-
PLATING
OPTION
–FR
(4.32)
.170
(3.12)
.123
(3.30)
.130
–P
–A
(must order maximum
quantity per reel;
contact Samtec for
quantity breaks)
samtec.com?CLM or samtec.com?MLE
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“MLE-145-01-G-DV-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+139.919101+17.94613
- 10+132.4735910+16.99116
- 25+127.4985025+16.35306
- 50+124.3897150+15.95432
- 100+89.98226100+11.54120
- 250+80.98032250+10.38660
