MMSD-20-22-L-80.00-S-K
    SAMTEC(申泰)
    SAMTEC - MMSD-20-22-L-80.00-S-K - Cable Assembly, IDC Receptacle to Free End, 40 Ways, 2.54 mm, 2 Ro...
MMSD-20-22-L-80.00-S-K 数据手册
REVISION AT DO NOT SCALE FROM THIS PRINT NOTES: MMSDX-XX-XXX-X-XX.XX-X-X-XXX 1. C REPRESENTS A CRITICAL DIMENSION. FEP CABLE OPTION 2. BURR ALLOWANCE: .003[.08] MAX. 3. PARTS TO BE MOLDED TO POSITION. OPTION -T: FEP INSULATION 4. MINIMUM PIN PULLOUT FORCE: 4.000LB[17.79N] (LEAVE BLANK FOR STANDARD 5. CONTACT MUST BE INSERTED UNTIL RETENTION SINGLE PVC INSULATION) FEATURE LOCKS INTO PLACE. (SEE NOTE 14) -M: METAL LATCH (USE IPD1-XX-D-X-M) 6. ALL FINISHED GOODS ARE TO BE ELECTRICAL TESTED INCLUDING HI-POT TEST No OF POSITIONS (LEAVE BLANK FOR PLASTIC) @ 1000 VOLTS DC. AFTER FINAL ELECTRICAL TEST, LABEL EACH ASSEMBLY -02 THRU -25 WITH (1) ET STAMP ON THE BODY. C DOUBLE (PER ROW) 7. TINNED COPPER WIRE IS ROHS COMPLIANT. -LUS: PLASTIC LATCH UP, STRAIGHT 8. FOLLOW CO-RF-WI-3001-M AND SAMTEC PACKAGING STANDARDS. WIRE GAUGE (AWG) -LDS: PLASTIC LATCH DOWN, STRAIGHT 9. MINIMUM METAL LATCH RETENTION FORCE: 1.000LB[4.45N] PVC: -20, -22, -24, -26, -28, -30 10. REFER TO CRIMP SPECIFICATIONS PRINT FOR CRIMP AND STRIP -LUX: PLASTIC LATCH UP, CROSSED FEP: -20,-24-28-30 DIMENSIONS, TOLERANCES, TOOLING AND ITS REQUIREMENTS. -LDX: PLASTIC LATCH DOWN, CROSSED 11. FOR LENGTHS LESS THAN 12 IN, TOLERANCE SHALL -MUS: METAL LATCH UP, STRAIGHT COLOR CODE BE ±.125[3.18]. FOR OTHER LENGTHS, TOLERANCES SHALL BE ±2%. -MDS: METAL LATCH DOWN, STRAIGHT C (SEE TABLE 3, SHEET 3) 12. LOCATION OF GATE PAD IS AT THE DISCRETION OF THE VENDOR. -MUX: METAL LATCH UP, CROSSED 13. GOLD PLATING IS NOT REQUIRED ON THE OUTSIDE OF THE CONTACT (LEAVE BLANK FOR STANDARD -MDX: METAL LATCH DOWN, CROSSED BOX OR ON THE SIDE WITH THE RETENTION LANCE. BLACK CABLE) 14. ASSEMBLIES USING THE FEP OPTION ARE FOR CRIMP APPLICATIONS ONLY. POLARIZATION OPTION (NOT AVAILABLE WITH FEP OPTION) 15. CUT LENGTH IS ASSEMBLY LENGTH MINUS OVERALL LENGTH SUBTRACTOR. (-P, -K, OR -G OPTION IS REQUIRED.) PLATING SPECIFICATION -P: POLARIZATION (SEE FIG 3, SHEET 2) -F: 3 µ" SELECTIVE GOLD IN CONTACT (NOT AVAILABLE WITH -LUS, -LDS, -LUX, -K, -G OPTIONS) AREA, BRIGHT TIN ON TAIL. (No OF POS x .100[2.54]) -K: KEYED POLARIZATION -L: 10 µ" SELECTIVE GOLD IN CONTACT + .058[1.47] REF (USE IPD1-XX-D-K) (SEE FIG 4, SHEET 2) AREA, BRIGHT TIN ON TAIL. C (NOT AVAILABLE WITH -P, -G OPTIONS) -S: 30 µ" SELECTIVE GOLD IN CONTACT 05 01 -G: GUIDE POST AREA, BRIGHT TIN ON TAIL. (USE IPD1-XX-D-GP) (SEE FIG 6, SHEET 3) C ASSEMBLED LENGTH (NOT AVAILABLE WITH -LDS, -LUX, -P, -K OPTIONS) .353 8.97 .250 6.35 SPECIFY IN INCHES [USE DWC-XX-XX] REF REF (SINGLE END: 03.00 INCH MINIMUM, (LEAVE BLANK FOR NO POLARIZATION; DOUBLE END: 03.25 INCH MINIMUM) AVAILABLE TO EXISTING CUSTOMERS ONLY) 10 .100 2.54 REF END OPTION -S: SINGLE END -D: DOUBLE END (MUST CHOOSE FROM LUS, LDS, LUX, LDX, MUS, MDS, MUX, OR MDX) 06 "A" IPD1-XX-D C .505 12.83 REF .285 7.24 REF C C XX.XX (SEE NOTE 11) XX.XX (SEE NOTE 11) FIG 1 "A" MMSD-05-22-X-XX.XX-S SHOWN FIG 2 SECTION "A"-"A" MMSD-05-22-X-XX.XX-D SHOWN UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: F:\DWG\MISC\MKTG\MMSDX-XX-XXX-X-XX.XX-X-X-XXX-MKT.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING HOUSING: NYLON 66, COLOR: WHITE CONTACT: PHOS BRONZE CABLE; INSULATION: SEE CALLOUT WIRE: TINNED COPPER LATCH: NICKEL-PLATED BeCu, #25, 1/2 HT SHEET SCALE: 1:0.666667 DESCRIPTION: .100[2.54] SOCKET DISCRETE CABLE ASSEMBLY DWG. NO. MMSDX-XX-XXX-X-XX.XX-X-X-XXX BY: DEAN P 07/16/2004 SHEET 1 OF 4 REVISION AT 01 N N/2 + 1 N N/2 (SEE TABLE 2) N/2 N/2 + 1 01 (SEE TABLE 2) LATCHEND 2 N/2 N N/2 + 1 01 LATCHEND 1 LATCHEND 2 N/2 + 1 N/2 (SEE TABLE 2) N N N/2 N/2 + 1 01 (SEE TABLE 2) LATCHEND 2 N -LDS [LATCH DOWN - CABLE STRAIGHT] (SEE SHEET 3, TABLE 4 FOR PIN MAPPING) N N/2 N/2 N/2 + 1 01 (SEE TABLE 2) LATCHEND 1 LATCHEND 1 LATCHEND 2 .022 0.56 REF 01 (SEE TABLE 2) LATCHEND 1 N/2 + 1 -LUX [LATCH UP - CABLE CROSSED] (SEE SHEET 3, TABLE 4 FOR PIN MAPPING) N/2 N/2 + 1 (SEE TABLE 2) -LUS [LATCH UP - CABLE STRAIGHT] (SEE SHEET 3, TABLE 4 FOR PIN MAPPING) 01 N 01 (SEE TABLE 2) -LDX [LATCH DOWN - CABLE CROSSED] (SEE SHEET 3, TABLE 4 FOR PIN MAPPING) .022 0.56 REF (TYP) (2 PLCS) 02 01 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, IPD1-XX-D-P 07 IPD1-02-D-K (MMSDX-06-XX-X-XX.XX-X-P SHOWN) (NOT AVAILABLE WITH -LUS, -LDS, -LUX OPTIONS) AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR IPD1-XX-D-K FIG 3 -P: POLARIZATION MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY (MMSDX-06-XX-X-XX.XX-X-K-XXX SHOWN) (NOT AVAILABLE WITH -P OPTION) (SAME AS FIG. 1, UNLESS OTHERWISE STATED) -02 POS (DIFFERENT AS SHOWN) FIG 4 -K: KEYED POLARIZATION F:\DWG\MISC\MKTG\MMSDX-XX-XXX-X-XX.XX-X-X-XXX-MKT.SLDDRW OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.25:1 DESCRIPTION: .100[2.54] SOCKET DISCRETE CABLE ASSEMBLY DWG. NO. MMSDX-XX-XXX-X-XX.XX-X-X-XXX BY: DEAN P 07/16/2004 SHEET 2 OF 4 REVISION AT .260 6.60 REF IPD1-XX-D-X-M .618 15.70 REF .310 7.87 REF .109 2.77 REF IPD1-XX-D-GP FIG 6 FIG 5 (MMSDX-06-XX-X-XX.XX-S-G SHOWN) (NOT AVAILABLE WITH -LDS, -LUX, -P, -K OPTIONS) (SAME AS FIG 1, UNLESS OTHERWISE STATED) (MMSDX-06-XX-X-XX.XX-S-M SHOWN) (SAME AS FIG 1, UNLESS OTHERWISE STATED) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\MMSDX-XX-XXX-X-XX.XX-X-X-XXX-MKT.SLDDRW DESCRIPTION: .100[2.54] SOCKET DISCRETE CABLE ASSEMBLY DWG. NO. MMSDX-XX-XXX-X-XX.XX-X-X-XXX BY: DEAN P 07/16/2004 SHEET 3 OF 4 REVISION AT CABLE CUT IN-PROCESS "A" (SEE TABLE 1, SHT 1) "A" (SEE TABLE 1, SHT 1) OVERALL LENGTH (SEE TABLE 5) OVERALL LENGTH (SEE TABLE 5) "A" (SEE TABLE 1, SHT 1) -S: SINGLE END -D: DOUBLE END * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2:1 DESCRIPTION: .100[2.54] SOCKET DISCRETE CABLE ASSEMBLY DWG. NO. MMSDX-XX-XXX-X-XX.XX-X-X-XXX F:\DWG\MISC\MKTG\MMSDX-XX-XXX-X-XX.XX-X-X-XXX-MKT.SLDDRW BY: DEAN P 07/16/2004 SHEET 4 OF 4
MMSD-20-22-L-80.00-S-K 价格&库存
很抱歉,暂时无法提供与“MMSD-20-22-L-80.00-S-K”相匹配的价格&库存,您可以联系我们找货
