MTSW-104-08-T-S-310-LL
    SAMTEC(申泰)
    插件,P=2.54mm
    排针 间距:2.54mm 1x4P 直插
MTSW-104-08-T-S-310-LL 数据手册
F-218 (Rev 12JAN18) HMTSW–126–23–L–S–237 MTSW–117–09–G–D–383–RA (2.54 mm) .100" MODIFIED .025" SQ POST HEADERS Board Mates: SSW, SSQ, ESW, ESQ, BCS, BSW CES, SLW, HLE, SSM TYPE STRIP Cable Mates: IDSD, IDSS, SMSD, SMSS Modified .025" strips permit custom post heights. (0.13) .005 Samtec offers the greatest stacking flexibility in the industry. The “M” stands for Modified. You tell us the post height you need and we’ll deliver it. –1 MTSW = Modified Strip = (5.08 mm) .200" Pitch (2.54) .100 = Hi-Temp Modified Strip LEAD STYLE –2 = (2.54 mm) .100" Pitch HMTSW (0.13) .005 NO. PINS PER ROW PIN PITCH (5.08) .200 (0.13) .005 SPECIFY “LEAD STYLE” FROM CHART (2.54) .100 x No. of Positions (2.54) .100 50 02 MTSW SPECIFICATIONS For complete specifications see www.samtec.com?MTSW or www.samtec.com?HMTSW Insulator Material: MTSW: Black Glass Filled Polyester HMTSW: Natural Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Au or Sn over 50 µ" (1.27 µm) Ni Operating Temp Range: -55 °C to +125 °C with Gold -55 °C to +105 °C with Tin RoHS Compliant: Yes Lead–Free Solderable: MTSW: No, Lead Wave Only HMTSW: Yes RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality Straight Pin Versions (2.54) .100 01 03 (2.54) (5.02) .100 .198 –D (2.54) .100 (5.08) (7.56) .200 .298 –T 148 150 (5.08) (7.56) .200 .298 (7.62) .300 01 MTSW –Q Right (3.02) (1.78) .119 .070 Angle Versions (8.12) .320 = (2.54 mm) .100" Center Version –S 01 100 50 (2.54) .100 (6.10) .240 (1.78) .070 01 99 03 150 (2.54) .100 (5.08) .200 (8.10) .319 –D 02 thru 25 = (5.08 mm) .200" Center Version –T (1.78) .070 (1.78) .070 01 148 03 150 (5.08) .200 (8.12) .320 (8.10) .319 –Q (1.78) .070 (1.78) .070 01 MTSW OVERALL LENGTH (OAL) (2.54) .100 TAIL (0.00).000 MIN 148 (3.09) (1.78) .120 .070 02 01 thru 50 HMTSW (2.54) .100 x No. of Positions HMTSW –S & –D (5.56) .219 (1.78) = 36 .070 positions maximum POST (0.00) .000 MIN 99 150 01 03 FILE NO. E111594 Note: These Series are non-standard, non-returnable. –S 100 (5.08) .200 (7.62) .300 (2.48) .098 01 HMTSW LEAD STYLE OAL –06 (7.62) .300 –07 (10.92) .430 –08 (13.46) .530 –09 (18.54) .730 –10 (21.08) .830 –11 (23.62) .930 –12 (26.16) 1.030 –13 (31.24) 1.230 –21 (36.32) 1.430 –22 (16.00) .630 –23 (11.30) .445 –24 (12.19) .480 –27 (33.78) 1.330 –28 (28.70) 1.130 148 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. MTSW–115–09–L–S–229-RE MTSW–126–08–T–S–229–RA MTSW–108–28–G–D–920 HMTSW–110–23–L–S–237 MTSW, HMTSW SERIES ROW OPTION PLATING OPTION –F POST HEIGHT OTHER OPTION POLARIZED OPTION –S = Gold flash on post, Matte Tin on tail –“XXX” = Single –L = Polarized (Specify ‘XXX’ as position number) –D = 10 µ" (0.25 µm) Gold on post, Matte Tin on tail = Double (4.19) .165" Contact Area –T –G –RA = Triple = 10 µ" (0.25 µm) Gold on post, Gold flash on balance Tail = Locking Lead (N/A with –RE, N/A in single row 1 or 2 positions. Available on tails from (2.29 mm) .090" to (10.16 mm) .400" only) = Double Row .200" (5.08 mm) row space = Matte Tin –RE = Right-angle –LL –Q –T or ALSO AVAILABLE (MOQ Required) Two leads per strip crimped in opposite directions on or near centerline. See TSW for availability. –RA Option with –LL Option • Other platings Contact Samtec. –LA = (Maximum “C” = (13.46 mm) .530) –“XXXX”= “C” Dimension (Specify post height in INCHES – .005" (0.13 mm) increments) FOR A = (2.29) .090 LEAD STYLE OAL – 06 (7.62) .300 (10.92) .430 (13.46) .530 (18.54) .730 (21.08) .830 (23.62) .930 (26.16) 1.030 – 07 – 08 – 09 – 10 – 11 – 12 * – 13 * – 21 – 22 C C (31.24) 1.230 (26.42) 1.040 (23.62) .930 (21.08) .830 (36.32) 1.430 (31.50) 1.240 (28.70) 1.130 (26.16) 1.030 (16.00) .630 (11.18) .440 (8.38) .330 (5.84) .230 (11.30) .445 (6.48) .255 (3.68) .145 * – 23 * – 24 * – 27 28 * *– Styles –21, –23, –24, –27 –S C MAXIMUM MAXIMUM MAXIMUM STRAIGHT with/–RA with/–RE (2.79) Not Not .110 Available Available (6.10) (3.30) Not .240 .130 Available (8.64) (5.84) (3.30) .340 .230 .130 (13.72) (10.92) (8.38) .540 .430 .330 (16.26) (13.46) (10.92) .640 .530 .430 (18.80) (16.00) (13.46) .740 .630 .530 (21.34) (18.54) (16.00) .840 .730 .630 Straight Pin Versions A = OAL–C– (2.54) .100 –D C OAL (2.54) .100 (7.37) .290 (4.57) .180 (33.78) 1.330 (28.96) 1.140 (26.16) 1.030 (23.62) .930 (28.70) 1.130 (23.88) .940 (21.08) .830 (18.54) .730 not available with –D Right-angle Styles –13, –21, –23, –24, –27, –28 not available with –T or – Q Right-angle C OAL (2.54) .100 A OAL (2.54) .100 A C (2.54) .100 A A (5.33) Styles –21, –23, –24, –27 N/A with –D Right-Angle Versions (– RA Options) A = OAL–C– .210 Styles –13, –21, –23, –24, –27, –28 N/A with –T or – Q (1.78) .070 (1.78) .070 C A (1.52) .060 (2.54) .100 A (1.52) .060 (1.78) .070 C (2.54) .100 C (2.54) .100 (2.54) .100 (2.54) .100 (1.78) .070 (4.06) .160 C (1.52) .060 A (5.08) .200 Right-Angle Versions C A (1.78) .070 A (1.52) .060 (2.54) .100 Not Available (12.19) .480 C OAL –Q –T (2.54) .100 (– RE Options) Single Row Only (7.87) A = OAL–C– .310 Due to technical progress, all designs, specifications and components are subject to change without notice. WWW.SAMTEC.COM All parts within this catalog are built to Samtec’s specifications. Customer specific requirements must be approved by Samtec and identified in a Samtec customer-specific drawing to apply. (2.54) .100
MTSW-104-08-T-S-310-LL 价格&库存
很抱歉,暂时无法提供与“MTSW-104-08-T-S-310-LL”相匹配的价格&库存,您可以联系我们找货
  • 1+2.913201+0.37636
