PETC-04-12-04-01-L-RA-SD 数据手册
HIGH POWER SYSTEMS
20-60 A
p er bla de
FEATURES & BENEFITS
• Current Rating: 23 A - 58.7 A per power blade
• 3.81 mm, 5.00 mm and 6.35 mm pitch
• Dual blade contact system
• Power only or power/signal combinations available
• Right-angle and vertical orientations
• Rugged screw down and locking clip options
• Discrete wire cable assemblies with 10-16 AWG wire
(see pages 246-248)
• “Hinged” for unique mating in any orientation
from 0° to 90° and space confined applications
CREEPAGE & CLEARANCE
Hermaphroditic options
samtec.com?MPPT and
samtec.com?UPPT
Hinging options available
samtec.com?FMPT and
samtec.com?FMPS
PITCH
CREEPAGE
CLEARANCE
UPT/UPS/UPPT
5.50 mm
1.51 mm
MPT/MPS/MPTC/MPSC
2.95 mm
2.71 mm
PET/PES/PETC/PESC
3.66 mm
3.31 mm
Selectively loading contacts achieves customer specific
creepage and clearance requirements.
KEY SPECIFICATIONS
SERIES
SERIES
INSULATOR CONTACT
MATERIAL MATERIAL
PLATING
OPERATING
TEMP RANGE
CURRENT RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
UPT/UPS
(3.81 mm)
.150"
Black LCP
BeCu
Sn or Au over
-55 ºC to +105 ºC (Sn)
50 µ" (1.27 µm) Ni -55 ºC to +125 ºC (Au)
23 A
(1 pin powered)
438 VAC
Yes
UPPT
(3.81 mm)
.150"
Black LCP
Copper Alloy
Sn or Au over
21.4 A
(1 pin powered)
425 VAC
Yes
MPT/MPS
(5.00 mm)
.1969"
Black LCP
Copper Alloy
Sn or Au over
28.8 A
(1 pin powered)
575 VAC
Yes
(5.00 mm)
.197" (pwr)
MPTC/MPSC (2.00 mm)
.079" (sig)
Black LCP
Signal:
Phosphor
Sn or Au over
Bronze
Terminal:
Copper Alloy
28.8 A
(pwr - 1 pin powered)
5A
(sig - 4 pins powered)
250 VAC
Yes
PET/PES
(6.35 mm)
.250"
Black LCP
Copper Alloy
Sn or Au over
58.7 A
(1 pin powered)
450 VAC
Yes
PETC/PESC
(6.35 mm)
.250" (pwr)
(2.54 mm)
.100" (sig)
Black LCP
Copper Alloy
Sn or Au over
31.4 A
5.7 A
650 VAC (pwr)
450 VAC (sig)
Yes
F-224
samtec.com/PowerStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(6.35 mm) .250" PITCH • 40 A HIGH POWER/SIGNAL SYSTEM
PETC
POWER
PINS
–01,
–02, –04
SIGNAL
PINS
–12, –40
POWER
PINS
01
–01,
–02, –04
PLATING
OPTION
–L
TAIL
–VT
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–SD
= Vertical
= Screw Down
(Right-angle only)
– RA
–LC
= Right-angle
–T
OTHER
OPTION
= Locking Clip
(Manual placement required)
= Matte Tin
PETC
Board Mates:
PESC
POWER
PINS/ENDS
Note:
Some lengths, styles and
options are non-standard,
non-returnable
PESC
POWER
PINS
–01,
–02, –04
A
12 SIGNAL
PINS
40 SIGNAL
PINS
–01
(39.37) 1.550
(57.15) 2.250
–02
(52.07) 2.050
(69.85) 2.750
–04
(77.47) 3.050
(95.25) 3.750
View complete specifications at: samtec.com?PETC
SIGNAL
PINS
–12, –40
POWER
PINS
–01,
–02, –04
01
PLATING
OPTION
–L
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
–T
PESC
TAIL
–VT
= Vertical
– RA
= Right-angle
= Matte Tin
Board Mates:
PETC
OTHER
OPTION
–SD
= Screw Down
(Right-angle only)
–LC
= Locking Clip
POWER
PINS/ENDS
Note:
non-returnable
A
12 SIGNAL
PINS
40 SIGNAL
PINS
–01
(39.37) 1.550
(57.15) 2.250
–02
(52.07) 2.050
(69.85) 2.750
–04
(77.47) 3.050
(95.25) 3.750
View complete specifications at: samtec.com?PESC
F-224
PETC-04-12-04-01-L-RA-SD 价格&库存
很抱歉,暂时无法提供与“PETC-04-12-04-01-L-RA-SD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 18+176.2345018+22.73571
